  • August 04, 2025, 07:17:17 AM
Author Topic: Too heavy or just right?? Curious  (Read 2427 times)
Offline Ty Marcucci
« on: November 22, 2007, 01:41:01 PM »
  D>K
« Last Edit: August 15, 2017, 05:16:50 PM by Ty Marcucci »
Ty Marcucci
Re: Too heavy or just right?? Curious
« Reply #1 on: November 22, 2007, 07:35:58 PM »
Hi Ty,
I only believe in the final product, actually: How it flies!  If you're asking from a wing loading standpoint, then they are a tad heavy according to most.  But then, others will say they are great!  I say, see how they fiy. ;D
Offline Greg L Bahrman
« Reply #2 on: November 22, 2007, 10:25:44 PM »
Ty,
Tough one to answer. Kind of like when the wife asks,"does this dress make me look fat"
no dear it makes you look hot  LL~ LL~ LL~
Greg Bahrman, AMA 312522
Simi Valley, Ca.
Offline Bob Reeves
    • Somethin'Xtra Inc.
« Reply #3 on: November 23, 2007, 08:59:21 AM »
53-54 ounces with a ST 51
Offline Bob Reeves
« Reply #4 on: November 23, 2007, 01:21:56 PM »
I have given serious thought about replacing the ST .46 with a ST .51.  D>K
Mine started life with a very good ST 46 but just wasn't quite enough. The retrofit was a bit of a challenge but it came out pretty well. I drilled another set of rear holes in the 51 to match the 46 mounting holes. The engine shaft is a bit longer, had to go to a Dubro plastic spinner with the recessed back plate to make it look right.
The skylark is a great stunt ship but has a thick wing and needs a really strong engine to do it justice. If your Skylark is the same wing area as mine your wing loading is 13.37 oz/sq ft. That isn't too bad, I know one expert from Dallas that says he builds for 13 to 14 oz/sq ft and feels it helps in the wind.
You are going to add two ounces with a 51 which will push the wing loading to 13.84 oz/sq ft. still not bad enough to make it a wall hanger and with the extra power it will be fine. You will need at least a 5 1/2 ounce tank and maybe a little tail weight depending on how it balances with the 46.
Good luck and hope to see it at a contest some day..
BTW: The best flying stunt ship I have is 13.83 oz/sq ft.
Offline Balsa Butcher
  • High Desert Flier
« Reply #5 on: November 23, 2007, 01:58:53 PM »
Ty: Just for clarification - Is it the "46" size Skylark you are referring to (614 Sq inches) or the larger 60 size - as RSM calls it? The reason I ask is because an RSM Skylark kit is in the "on deck" circle - engine still to be decided.   ~>  Thanks
Pete Cunha
Sacramento CA.
AMA 57499
Offline Bob Reeves
« Reply #6 on: November 23, 2007, 04:41:28 PM »
HI Pete. Mine has 667 sq in of wing area. 58 x 13 x 10.  It is a Marks Models kit. I have three ST .60, so maybe one of them would be better  #^  I am sure the RSM kit would have come out lighter. Also UHP is coming out with the Lark by Ed Southwick. If theri balsa holds true, it will be very light.
That changes the picture.. forget everything I said except to say a 46 is for sure not enough motor.
« Reply #7 on: November 23, 2007, 08:39:17 PM »
"I have a model of which I am the fourth owner. It started out as  Shark 45, based on the printing on the ribs and its size. It had Imron paint on it and was oil soaked as the TE of the wing and stab. Lots of work later, still rather heavy. Long nice takeoffs, but tends to hinge in the square eights, no matter what I do. my guess is it is going too slow and stalling. It is a slow flier, very steady, (too steady??)  My intention is to dismantle it, recycle some of the parts and put the T&L ST .46 in a smaller plane."
Ty...I have something very similar in my basement, including the Shark heritage. I think Joe Dill or Bob Emmett was responsible for its creation.  It's ugly, it's oil soaked, and it's awful heavy. I'm not sure what to do with it, but flames (not painted on) may be involved!  y1 Steve
  • High Desert Flier
« Reply #8 on: November 23, 2007, 11:51:16 PM »
Thanks Ty:  The original plan shall remain unchanged - build the 614 Sq In version and use a ST-46 in it, that is why I am glad to hear that yours is the bigger version.  I remember seeing Ed fly his 60 powered Skylark at Whittier Narrows many moons ago.  A good flier, I think it did have an ST-60 and a Disney character for a pilot.  He is missed.  RE the Lark - Phil Granderson had one a few years ago - probably still does.  Like all of Phil's planes, first row finish and very light. I will look forward to the UHP version.   8)
Pete Cunha
Sacramento CA.
AMA 57499
Offline Bob Reeves
« Reply #9 on: November 24, 2007, 08:16:11 AM »
Just keep in mind the 60 size Skylark isn't classic legal. At least that is what I was told when I was trying to decide on which one to build.
« Reply #10 on: November 24, 2007, 02:10:06 PM »
I think the original Argus was in the 29-32 oz. range, with a Fox 29.  The extra power of the Aerotiger should help, but I wouldn't expect blazing sharp corners.
« Reply #11 on: November 24, 2007, 02:25:20 PM »
Ty,
My old turquoise Skylark was built from Ed's plans and came out at 44 oz without the tailweight.
It had a Tigre 46 and a Veco 3/4 inch extension (nose looked cool), so I replaced the Veco spinner and Veco wheels with modern, lightweight stuff and removed all the lead out of the tail so it was generally about 44 to 45 oz. It was a killer flying airplane but I wrecked it three times; no wind, wind and the leadout pulled out!
A couple of years later Bill Byles buil;t one that was a "bit" heavier than mine and it flew great on the Tigre 46 as well.
It seems the design does well in the high fifties.
Chris...
« Last Edit: November 24, 2007, 02:44:26 PM by Chris McMillin »
« Reply #12 on: November 24, 2007, 09:02:45 PM »
I guess the plane feels lighter kinda like the Mustang did with a new Rolls Royce Merlin in it. Purely in my mind and lonely too. LL~ D>K H^^
I don't know if you know this, Ty, but an Allison powered A model Mustang is thirty mph faster than a D at the same power settings. Set 36 inches and 2450 rpm on both, side by side, and the A model just walks away. It's lighter and smaller (really, the fuse is four inches taller on the D) with less drag, both induced and parasitic.
Chris...
« Reply #13 on: November 26, 2007, 08:08:52 AM »
Bill Byles is a member here, and he has told me a lot about him and Ed.  I never met Ed, personally, and I am sorry for it.
Bill has said several times that he and Ed flew their 56" Skylarks with the ST 46.  I have not weighed the ST G51 lately, nor the *regular* St 46 (as opposed to the 29/46). I need to just to see the weight difference.  By and large, I have found my T&L ST G51s to be a good bit stronger than the 46s when run as Tom Lay recommends.
« Reply #14 on: December 05, 2007, 06:33:28 AM »
Ty     You know I have used ST/46 in 90% of the planes I have flown since 1980. It's a great motor up to 55 ounces and 620 sq inch wing. Lots of people use them in 700sq" wings and 60 ounces but many problems start to come up with the motor when that is done. If used in a smaller model 610sq" they will go a 1000 flights with little problems. All the old problems are gone with the ABC conversion but they still have about the same power.Years ago when people flew 60 size models with the ST/46 they were constantly chasing a new ring.The USA-1 is a good example.Billy was always looking for more power but he made it work. The ST/51 is a great replacement for the ST/46. In the 80's I won a lot of contests with a 690 SQ" 60 oz 46 powered plane. I later gave it away and the guy put a ST/60 in it and it was a much better plane. I flew it and thought WOW if I had had that I would have done even better.
« Reply #15 on: December 05, 2007, 12:22:19 PM »
It is also worth mentioning (which Eddy forgot) is that Billy used a .51 variant of the St 46 in the USA-1.  I believe it was built for him by the Aloise Brothers.
He also was very happy to tip the nitro jug to enormous proportions, and wearing out the engine was of no real concern.
