  • July 04, 2025, 06:37:01 PM
Author Topic: Now the trailing edge? How to do you shape it.  (Read 1655 times)
Online Paul Taylor
« on: March 27, 2011, 03:08:53 PM »
Allen gave me a great tip for sanding the LE. Is is all done.
Now what about the trailing edge of the wing. Any tips or tricks for sanding it?
Re: Now the trailing edge? How to do you shape it.
« Reply #1 on: March 27, 2011, 03:13:51 PM »
I carve things roughly to shape, first -- a good plane helps a lot, but a jack knife or a #11 X-acto blade works OK.  Then I sand with a flat bar.
Offline John Cralley
« Reply #2 on: March 27, 2011, 03:33:58 PM »
I cut them on my table saw. I set it up to slice through a sheet of the proper thickness of balsa at the correct angle using a high tooth count (plywood) blade. Use some scrap to get the setup just right. After the first cut yields one trailing edge turning the sheet flat with the blade vertical allows me to cut a second TE from the the same sheet. Slice off the rear edge to get the thickness on the rear margin you need and a bit of sanding gives a perfect TE.
There are lots of ways to skin a cat and I'm sure others will chime in with their methods.
John Cralley
AMA 52183
Central Illinois
« Reply #3 on: March 27, 2011, 04:04:05 PM »
I think Paul has the wing together already -- yes?
If the wing isn't together, then starting with something tapered, or making the "two sheets, meeting at a taper" style of trailing edge, is definitely a time saver.
Online Paul Taylor
« Reply #4 on: March 27, 2011, 07:49:03 PM »
Yea the wing is built.
Guess I need need to blend it in to the TE sheeting?
Offline Neville Legg
« Reply #5 on: March 28, 2011, 04:37:59 PM »
Make sure you put a centre line down the piece of wood you are shaping. If you've ever watched a carpenter put a centre line down a piece of timber using just his fingers and a pencil, that's the way I do it. It is very accurate with a bit of practice.
Cheers
(not) Descartes
Offline builditright
  • So happy to be alive!
« Reply #6 on: March 29, 2011, 07:01:09 AM »
here's a couple of pics to show how I did it using 1/64 ply, and what Ty and Neville suggest.
Thank you and God Bless
Walter
aka/ builditright
« Reply #7 on: March 31, 2011, 06:04:00 PM »
I've learned NEVER use a table saw on balsa! I've tried all sorts of fine-tooth blades, and the wood always comes out warped.  Heat of the sawing, I guess.  I cut all balsa with a band saw, which doesn't seem to heat the wood and make it warp.  Trailing edges are easy, remembering how wood shops do "re-sawing".  That is sawing the wood across the long side (i.e. a 1" X 4" cross section becomes two pieces of 1/2" X 4"). Clamp a fence next to the band saw blade.  It can be parallel to the blade, or tilted (for trailing edges).
F.C.
« Reply #8 on: April 03, 2011, 11:11:56 PM »
I use the razor saw recommended by Bob Hunt many years ago.  Comes from Hobby Lobby and is German made.  I will have to look up the brand name, but it is light metallic blue and uses double edge razor blades.  Much easier (blades are sharper) and more accurate than the Master Airscrew composite one.  Still I used that until I got the "good" one.  It will shave balsa down to where you can easily see through the strips so you don't take too much off in one pass.  Try to make a "complete", even, pass from end to end.  Try to hold the plane at the same angle as the TE sheeting at the rear edge to start.  You can see as the strip being removed is the same width all the way across the span and will get wider as you get down to the right shape.  Finish off with a long sanding block as others say.
Big Bear
« Reply #9 on: April 04, 2011, 09:55:08 AM »
Did you mean Razor Plane Bill ? Is it the little Zip plane you have, I have two ('cos I thought I'd lost one in the junk hole I call a workshop :)) they use the thicker double edge blades, I'd be lost without mine, fantastic little tool ;D
Cheers
(not) Descartes
