  • August 01, 2025, 09:05:00 AM
Author Topic: novice questions  (Read 1429 times)
Steve Kientz
novice questions
« on: November 28, 2006, 05:40:53 AM »
I have several questions,first what wing jig can be used on production(SIG) kits?The center area of the ribs is already diecutso I assume you can't use a rod wing jig.
My second question concerns different methods of building wings.I built a Skyray and pinned the bottom spar down,but the Twister I just started they want you to pin the TE down.I assume the pinned spar is a better method?
Offline Ken Deboy
    • Silk and Dope
Re: novice questions
« Reply #1 on: November 28, 2006, 07:06:51 AM »
I haven't seen a Twister kit, but on a Skyray the tabs on the back of the ribs substitute for the jig. If you wanted to use a rod type jig to build the wing, all you need to do is stack the ribs and drill holes outside the cutout area, ANother alternative would be the leveling bar system used in Brodak kits. When I first saw it I was doubtful, but my Shark 402 wing came out really straight, and the method is a lot easier than the instructions made it sound.
cheers,
There is a fine line between "hobby" and "mental illness"
Steve Kientz
« Reply #2 on: November 28, 2006, 08:50:05 AM »
Thanks for the info, will try c/l central
