  • July 06, 2025, 07:26:59 PM
Author Topic: Nothing on height gages?  (Read 1939 times)
Offline kevin king
« on: December 28, 2021, 07:06:23 AM »
I was finishing a combat kitten while waiting for Winder 2 to arrive. My uncle built it years ago. I had to glue the wing back on. Could not tell by eyeballing if the wing was straight. Did a search for height gauges to find out what you are using and the search turned up nothing? That's surprising. What do you all do to check  for trueness? hold a ruler up on the bench?
Offline Ken Bird
Re: Nothing on height gages?
« Reply #1 on: December 28, 2021, 09:10:05 AM »
Hi Kevin,
I use a digital height gauge from Lee Valley. I’m quite happy with it.
https://www.leevalley.com/en-ca/shop/tools/hand-tools/marking-and-measuring/61612-digital-height-gauge?item=88N9001
« Reply #2 on: December 28, 2021, 09:25:13 AM »
All you need are dividers or a good straight machine ruler.
Well, you do need a really flat slab and perfect ink lines here and there.
https://www.google.com/search?q=machine+ruler&rlz=1C1SQJL_enUS900US900&oq=machine+rule.&aqs=chrome.1.69i57j0i22i30l5j0i10i22i30j0i22i30l3.5802j0j15&sourceid=chrome&ie=UTF-8
Offline Mark wood
« Reply #3 on: December 28, 2021, 09:25:52 AM »
A few guys are using laser levels. I have one which is two axis and it seems to be fairly good. A simple straight edge built up with shims is likewise sufficient.
The attached photo is of when I used it to tram in the AOA vane I made for calibration. You can see how well the laser line follows the LE. These can be found on Amazon, Harbor Freight, Lowes, Home Depot and others between $35 and $200.
https://www.amazon.com/Laser-Self-Leveling-Cross-Line-Horizontal-Rotatable/dp/B096329HKT?pd_rd_w=7LZEz&pf_rd_p=306cc3dd-f716-4afe-8aeb-47781d60c63f&pf_rd_r=YMGYQ063VJGFY19KFNED&pd_rd_r=a2206522-e7c3-42d2-980a-1ed9d246fedf&pd_rd_wg=iMdCD&pd_rd_i=B096329HKT&psc=1&ref_=pd_bap_d_csi_vtp_1_t
Life is good AMA 1488
Online Dave Rigotti
« Reply #4 on: December 28, 2021, 09:50:36 AM »
This has worked for me the last 45 years.....
PERFECT for comparing "this" to "that".
3/32 music wire and a 1" piece for 1/8 brass tube "smashed" just right to hold in it place but allow movement.  Cost?  Check the scrap bin!
Dave Rigotti
AMA 66859
Chesterland, Ohio
Offline Mark wood
« Reply #5 on: December 28, 2021, 10:09:22 AM »
So, ah, what's that dolly gonna launch?
