  • June 19, 2025, 05:29:40 PM
Author Topic: Foam wings  (Read 1604 times)
Offline James Mills
Foam wings
« on: April 05, 2009, 05:09:45 PM »
Would there be any benefit  laminating fiberglass between the balsa skin and ply spar and ribs around the wing gear for strength?
James
AMA 491167
Offline RC Storick
Re: Foam wings
« Reply #1 on: April 05, 2009, 05:20:38 PM »
Well the benefit would be extra weight. But its not necessary in my mind. Don't build it to crash build it to fly.
Re: Foam wings
« Reply #2 on: April 05, 2009, 06:41:04 PM »
    I am going to do something like that with the stabilizer on the next airplane, with graphite instead of fiberglass. I haven't decided about the wing.
     Strength is not that important but stiffness is, well worth a few ounces. Every time I make something stiffer, I get a better airplane, weight notwithstanding. As long as we have piped 75s I think that will be the case, within reason.
Offline James Mills
Re: Foam wings
« Reply #3 on: April 05, 2009, 07:17:40 PM »
Brett,
I'm going to ask a silly question, by graphite do you mean carbon fiber?  The main reason I would do it would be for strength in the spar and landing gear.
James
James
AMA 491167
Re: Foam wings
« Reply #4 on: April 05, 2009, 08:06:34 PM »
Brett,
   Yes, they are one and the same.
    There are probably more effective ways to beef up the landing gear than this. Adding a third half-rib, and putting in gussets from the spars and ribs to the landing gear block are more efficient, weight-wise.
Offline James Mills
Re: Foam wings
« Reply #5 on: April 05, 2009, 09:53:47 PM »
Thanks, that's a better idea I think (I guess you engineers come up with some good stuff from time to time LL~ LL~ S?P).
James
AMA 491167
Offline RC Storick
Re: Foam wings
« Reply #6 on: April 06, 2009, 09:00:14 AM »
James
Two light ply ribs one on each end have worked for 1000's of fomies. Why re invent the wheel?
Re: Foam wings
« Reply #7 on: April 06, 2009, 10:33:02 AM »
    I was just answering the question, not evaluating it. If you fly over grass the "conventional" method is marginal. And they are noted for the occasional breakout - and the typical failure mode is that the ribs break or the block breaks away from the ribs . Since you have to pass the leadouts through the ribs with enough clearance to permit free motion at the extremes of travel, you can't make them a lot bigger, so you need to make more of them, or provide extra connections from the ribs to the block to spread the load.
    An airplane that is 3 grams lighter is worthless if the landing gear is broken out of it.
Offline RC Storick
Re: Foam wings
« Reply #8 on: April 06, 2009, 11:44:58 AM »
Agreed.. I guess it depends on where your flying.
Offline Bob Reeves
    • Somethin'Xtra Inc.
Re: Foam wings
« Reply #9 on: April 07, 2009, 10:48:36 AM »
If you aren't prepaired to fly on grass in the mid south you severely limit yourself to what events you can attend.
