  • June 14, 2025, 10:44:37 AM
Author Topic: New Ringmaster (just in time)  (Read 3947 times)
Offline Bob Johnson
  • Lone Eagle Stunt Flyers -Have stooge. will travel.
« on: October 04, 2013, 02:09:10 PM »
I thought I'd post a few shots of my new Ringmaster. I hope to maiden flight this weekend for the Ringmaster fun fly In Burlington IA. Not much special( S1 from plans). OS 20fp in the nose, (sorta BBTU setup) also drilled for a Fox 35 stunt. weighs 28.5 oz less fuel. silkspan with Krylon (citrus green and purple) and Lusterkoat clear topcoat. I did do build up wing tips to accommodate the adjustable leadout and tip weight box. Same airfoil, better structure. All the best to all who fly RMs this weekend.. and to everyone else as well.
Offline ray copeland
Re: New Ringmaster (just in time)
« Reply #1 on: October 04, 2013, 02:21:22 PM »
Very nice Bob!! Hope it does well for you this weekend.   :)
Offline John Cralley
« Reply #2 on: October 04, 2013, 02:23:28 PM »
Beautiful RM Bob!!!
Are you taking it over to Burlington for their Fly-A-Thon tomorrow?? I am going to miss the gang over there. I think they like our group over here at Bloomington/Normal will be trying to get in flights between the showers. I hope no thunder storms because I, for one, will not fly if T storms are near by.
John Cralley
AMA 52183
Central Illinois
Offline MarcusCordeiro
« Reply #3 on: October 04, 2013, 02:56:34 PM »
Very nice!!! ;)
Marcus
Live to fly, fly to live
Aces High!
Here comes Marcus, man..."
Offline Duke.Johnson
« Reply #4 on: October 04, 2013, 03:26:24 PM »
That's really Nice!
Offline rich gorrill
« Reply #5 on: October 04, 2013, 03:35:28 PM »
nice lookin ship bob. A quick question, where do you get your hooks to hold the fuel tank. I'm having trouble finding suitable hooks for profiles.
Thanks, Rich
Online Tim Wescott
« Reply #6 on: October 04, 2013, 03:55:59 PM »
Rich:
I use cup hooks.  You can get them down to about 3/8" across.  I make the holes, screw in the hooks, verify that everything fits, then I unscrew the hooks, put a drop of 5-minute epoxy on each screw, and screw them back in.  I have had exactly zero problems with tank mounting when I do this.
If you want to be really anal retentive about getting an Absolutely Perfect Tank Mounting, then get some thin aluminum (1/32" is best).  Cut a piece out that's about 3/4" wider and longer than the tank.  Bend it into a channel that cradles the top and bottom of the tank and cut slots into the front and back of the sheet.  Then screw that channel into the fuselage with about 1/4" of kick-out in the back and hold the tank on with cable ties.  You'll be able to exactly adjust the height of the tank with ease.
For a Ringmaster, I use cup hooks...
Offline Bob Johnson
« Reply #7 on: October 04, 2013, 04:03:17 PM »
Thanks for the kind words. The tank hooks are just small, hardware store, L hooks that I add an extra bend too.(vise grips and pliers) I use a strip of bicycle inner tube instead of rubber bands to fasten as it lasts longer.
« Reply #8 on: October 05, 2013, 07:03:11 PM »
I love that color scheme.   Should be able to see it real good.   I too have used the cup hooks from the local hardware store.
Offline Crist Rigotti
« Reply #9 on: October 05, 2013, 07:07:08 PM »
The airplane flew very well!  Nice job Bob.
Offline Bob Johnson
« Reply #10 on: October 19, 2013, 11:22:30 AM »
Maiden flight video link if your interested. Lost a wheel, but got it back. 7 flights for the day. thanks
Bob
www.youtube.com/watch?v=0qSWW-PNtTs&feature=youtu.be[youtube=425,350][/youtube]
« Reply #11 on: October 19, 2013, 12:00:51 PM »
Cool!!
Marcus
Aces High!
« Reply #12 on: October 19, 2013, 01:58:23 PM »
Bob,
You did a great job with your Ringmaster. Kudos!
Complementary colors are exciting, good choice.
Also looks like you painted the pinstripe between the colors.
Gotta teach me how to finish a model.  ;D
Charles
Offline Jimmy L Dodson
« Reply #13 on: November 22, 2013, 01:43:45 PM »
That color scheme and the detail is awesome!  Did you say this is normal silkspan?  Medium weight?  I love what you did with this!  Looking forward to seeing the video.
Jimmy Dodson
Beaufort, SC
Offline Akihiro Danjo
« Reply #14 on: November 23, 2013, 05:37:56 AM »
Will this tank setup work correctly?
I think it is OK now because you use FP20 and the 4 (or 3?) oz tank might not be full.
It is a vent tank, but when the tank filled full and inverted, it may act as a uniflow tank because the vent (pressured) tube is in the fuel.
Aki
Offline Bob Johnson
« Reply #15 on: November 25, 2013, 08:27:38 AM »
Hello Aki,
Thank you for your interest. The tank is a Hayes 3 oz. clunk type. What is not visible is the pressure tap on the muffler. I run muffler pressure to the tank. The tank can be filled to capacity by tipping it up during filling. This gives a very constant and stable engine run.(see video) The prop is an APC 9x4. On a separate note, I recently flew this set up in 20 mph wind conditions. Too windy for stunts but I was surprised how well it stayed out on the lines.
Best
Bob
« Reply #16 on: July 02, 2019, 07:22:51 AM »
That is very cool looking.  Love the paint scheme.
