  • July 15, 2025, 12:20:04 AM
Author Topic: New model details - Raptor 2011 Edition build.  (Read 5265 times)
« on: February 11, 2011, 06:46:01 AM »
Well building is progressing nicely on my Raptor 2011 Edition which i'l have at this years Nats. I have been busy building away trying to get her in paint by Middle of April - As well as trying to finish off my classic ship.
I was buidling this at the same time as I was finishing:
The ares
The 2010 Raptor
My 2011 Classic model - the shop was certainly Crowded !!!!!! HB~> Still is ... with another model in the pipe line getting close to finish.
The design of the model is my own set of numbers but Im using alot of Idea's from other successful model designs The wing on this specific model is a planiform I have not tried - I used Paul Walkers Miss america mustang wing design but with the flaps identical in size and dimension to the Dave's T.G. The only real changes made were making the wing area 630 sq and not having the Kick out at the front of the wing like the mustang. But the 1/4 Chord Root / tip is identical.
Tailplane design is similar to what I had built for my last Raptor however I again consulted with Dave on the TG design and took many of the design ques. I wouldnt say Copied because I dont have a copy of te TG plans.. I did get some accurate measurements from the man himself. One of the design features I like to have on all my designs is a very slight swept back hinge Line in the Elevator ( 1/4"ish..).  You can see it on one of the photos if you look hard. Its one of those design features that I have run now for the last few ships - I like how it feels. Although I dont have any aeronautical reasons or maths to back up my findings - I did take some elements of that design from looking at larger planes like the airliners where the sweep is far more sever. I put it down to efficient design and aerodynamics. airflow would roll off the elevator so sweeping it back slightly maintains airflow for a brief amount longer. I have built several models that were VERY close to design almost identical but with this difference in stab design, and I found it more accurate, more responsive. - The same sort of effect I encountered with the Gieseke Bear tabs on the Stab - I choose not to run those- however have experimented with them on and off similar models and that was the best way I can describe the sensation - more positive and accurate through the turn.
As mentioned before I dont have any plot data however I have seen 3D wind tunnel plotting of a similar design tail and you can clearly see where the air flows, and where it doesnt . Again I'm just a Flyer and Graphic designer with no engineering background at all - so my reasons may be completely off the mark but I like how it looks and it may or may not make any " real world " difference, Call it artistic License.
Carbon Torque tubes for the flabs and Elevators - Triple carbon layer of Flaps - 5/8 Assymetry. Dual Flap tabs Rush boost tabs. I found I didnt like the feeling of full span flaps I never have - there are various threads about the merits of Full Span. I know the reasons why but Its comes down to feel in the end.
Target weight will be between 60 - 62 oz - The last Raptor pictured bottom and featured here a few weeks ago finished in at 62.5 oz ready to fly. I try to document where the weight goes at every main stage and they are along the same weight paths. I doubt it will be Sub 60..
Ball link controls used all throughout. Upon Brett's recommendation Im using the Titanuim threaded inserts inside the carbon pushrob.and Rocket #87 for the first time on this ship.  All Control systems by Kaz minato. Engine is Stalker with custom head modifications done in Ukraine.  Carbon tank. New Carbon/Kevlar undercarts +  carbon wheel pants.
Thats about all until paint.
I only have 1 set of plans for this edition which were drawn by myself, I could get copies made if there were any credible requests.
« Last Edit: February 11, 2011, 07:13:50 PM by PJ Rowland »
Re: New model details - Raptor 2011 Edition build.
« Reply #1 on: February 11, 2011, 07:33:12 AM »
Hi PJ,
Looks good!
How are you handling the elevator horn with the swept back elevator TE?  I have been looking over several of Jack Sheeks plans lately and he used split horns when he used the sweep back.
I know there are a few ways of dealing with it, but after seeing your stuff for a while, I figure you have the most reliable method already worked out.  I am looking forward to your reply as it will help on a future project! ;D
Thanks!
« Reply #2 on: February 11, 2011, 07:45:12 AM »
Its VERY simple.
The horn itself it still at 90 ' as far as its concerned it thinks its a normal Straight trailing edge.
I make up a little triangle wedge block that sits where the  2 halves meet. I in effect make where the elevator sits a regular join but where the elevator goes is then on the angle.
You aren't talking about alot of sweep anyway. - Its no difference IMO to making a wing with a swept forward Hingeline *( like that one.. ) I do that the same way.
DONT bend the horn to suit......  you end with all sorts of weird geometric issues.
Offline Matt Colan
« Reply #3 on: February 11, 2011, 08:46:26 PM »
It looks great PJ!  Might I ask about the sections of ribs in the flaps, is there any reason you did that?  H^^
« Reply #4 on: February 11, 2011, 08:54:17 PM »
Matt :
As in why they are there? Or why there are sections missing?
The answer to the first : Why are they there is weight saving.
The answer to why there are sections missing is for strength near the root and in the centre sections provide central strength when I cut out my Rush boost tabs. - The flap is triple carbon layerd anyway One could argue the weight I save is small - every little bit helps.
I find it easier to build flaps with ribs. Dont forget the carbon torque tube also adds rigitidty so one can go lighter on the materials.
« Reply #5 on: February 11, 2011, 10:17:05 PM »
PJ,
Very professional looking effort, PJ. Can't wait to see the final product.
« Reply #6 on: February 11, 2011, 10:19:52 PM »
Randy - since this photo i redid all the fillets with SuperFil :)  y1 Thanks for the compliment final product should look much nicer than the previous. Im taking my time and trying to get it to USA standard.
Also since this photo - I've added a sweeping fillet ( like the front of the wing ) to the stab for continuity.
« Reply #7 on: February 11, 2011, 10:21:50 PM »
PJ,
More tiger stripes? or maybe leopard spots?   ;D
« Reply #8 on: February 11, 2011, 10:50:28 PM »
Identical to my previous model paint scheme but with more detail - Im choosing not to airbrush I feel the solid tiger stripes give a better effect. I will change the paint colour to a more Orange Metallic Called " Electric Orange "
This is " Electric Orange "
Metallic base. - I will fade the orange into a nice Yellow also.
I have been going alot of R&D on Weathering techniques and have perfected my technique courtsey of a fellow modeller whom does space ship modelling. Here is a link of the sorts of techniuqes we have experimented with. Ive been able to reproduce this style with great sucess. - I prefinished a flap that allowed me to try 30 seperate sections and the final 3 were to my satisfaction.
Its a more realistic streaking and weathering effect for my panel lines. I will also take more time to do the line work. My last model was really jsut a proof of visual design concept. I did visualize it on paper and breifly in 3D without chopping into work time to much, but I had this model ready to go So I through paint on it and tested some idea's from a Visual perspective.
Just need to sit down and start - Im taking 3 days off work next week to get a good crack on it.
Leopard spots are harder than they appear...... HAHA
« Reply #9 on: February 11, 2011, 10:55:21 PM »
just to add to that.
The previous model was painted in " BLOOD ORANGE "
I thought it looked to dark in the end- but thats the 2010 Raptor paint colour as pictured above Pic # 4
Offline Matt Colan
« Reply #10 on: February 12, 2011, 08:05:22 AM »
Matt :
Thanks PJ,
My question had to do with the 2nd question, why there are sections missing.
« Reply #11 on: February 12, 2011, 09:25:08 AM »
Its VERY simple.
Thanks, PJ.  I do use a single horn on the swept forward TE, just flatten off the section of TE where the horn goes.  Wasn't sure about the swept back TE since I have not done one. ;D
Looking good, and I await he "finished product"!
« Reply #12 on: February 12, 2011, 06:57:37 PM »
Bill : Its the same technique.
Matt : No Problem - Its for weight and strength - When is your TP going to be finished??
Latest update : Just stopped for lunch and am working on final stage before primer - was hoping to get it in primer today.. Might not happen.
Offline Matt Colan
« Reply #13 on: February 12, 2011, 08:14:17 PM »
I'm hoping to have it done around the same time as yours.  I just posted pics of the updated cowling a little while ago on the topic in the open forum.
What motor is going in this? As I recall you have a Stalker 81 going into the backup plane.
« Reply #14 on: February 12, 2011, 09:29:31 PM »
Same engine. Stalker .81 Ive got 4 of them . The one that went into the Backup was my No #1 comp engine - with the modified Head, The backup was really done so I can get the engine setup in that one and just transfer it out once '11 is ready . Get the settings spot on and not have to fiddle with tank heights and shims and venturis too.
I've run stalkers for along time I know the runs, I know how to set them up - I hear great things about the Ro-Jett and PA engines - many successful fliers use them. Current World champ used ST 60 - So for me the key is consistant engine runs and setups. ( no electric jokes !! )  %^@
- Ill check out your new cowl, sounds like your building quite a ship.
« Reply #15 on: February 13, 2011, 06:44:56 PM »
Should hit it with Primer tommorow.
Yesterday's build went quite well - and long, final stage sanding of top coat - getting ready for primer, installed some hardward on the wings for trim tabs.  finalised gaps and did a complete dry fit.
Now im just working on my Carbon undercarts, they have taken alot longer to get right than I expected, will post photo's of thme tonight once the last coat is sanded - also very close to primer.
« Reply #16 on: February 14, 2011, 07:00:59 AM »
Carbon undercart now finished and ready for primer.
Close up - I wanted to get the blend of Arch into Spat seamless as possible.
Offline John Sunderland
« Reply #17 on: February 14, 2011, 07:10:06 AM »
 ;D Nice detail work PJ. For me, it just isnt CLPA if it is not faired in and filleted nicely such as you have done here. H^^
« Reply #18 on: February 15, 2011, 12:10:24 AM »
Hi PJ,
So far, my only Stalker experience has been with plain bearing .46.  Excellent engine!
How much fuel does the Stalker .81 usually use, as you run them?  Prop, fuel nitro %, venturi size?
Thanks!
« Reply #19 on: February 15, 2011, 04:21:15 AM »
Well today was primer day for the Raptor.
Got into the shop at around 8 am and went solid till 4:30 when It finally got a splash of primer.
Not the greatest photo angle but after 8 hrs I didnt care..
Bill : Im afraid to say - Ive got no idea EXACTLY in fuel ( I measured try  7.5 oz ) Depends on weather. Venturi Size - I have a custom set made up ranging from 7.4 - 8.8 So whatever the conditions cater for. Prop - Eather undercamber 12 " Pitch varies depending on the day. Fuel is a Blend Castor and Coolpower with 10 - 17 % Nitro depending on conditions. Ive run as low as 5 and as high as 20 but with that much power its usually not needed. - I lvoe the stalkers.
« Last Edit: February 16, 2011, 08:45:01 PM by PJ Rowland »
« Reply #20 on: February 15, 2011, 05:58:32 PM »
Now the fun part.  Sanding it all off.   LL~ LL~  By the way it is looking good.  The plane not the guy behid the mask. LL~ LL~ LL~
« Reply #21 on: February 17, 2011, 09:10:09 PM »
In the shop today sanding primer - I dislike 6 hour sanding sessions with wet dry, it gets everywhere.
I do have a stand to paint on, but I prefer holding the model and sanding looking over every part.
Joys of sanding
Should have the base coat of paint on next week - I probably wont update photo's of painting
« Reply #22 on: February 18, 2011, 11:30:45 AM »
Love a guy that dives right in.  ;D
« Reply #23 on: February 18, 2011, 03:23:41 PM »
Live, breath, eat, sleep, wear stunt.
 y1
« Reply #24 on: March 02, 2011, 08:15:49 PM »
This have been put on hold for a few days - I find it difficult to do 2 things at once, and in the last few days I've been trying to ge tmy Classic ship in 1st stage of Paint.
Both planes were in primer at roughly the same time, and both will be in 1st stage paint at about the same time, however its takign me a few days to get the surface prepared for paint. ( Which I did yesterday )
Once that is done I will then move back to this model and repeat the process - Somedays I wish I have 3 weeks off to get things done.
« Reply #25 on: March 03, 2011, 12:10:13 PM »
This is why I build one plane at a time. I do poorly going back and forth.
« Reply #26 on: March 03, 2011, 04:29:14 PM »
Hi Randy,
I REALLY do wish I could do that.  Do you have any experience with adult ADHD in your field?
« Reply #27 on: March 03, 2011, 05:34:53 PM »
Bill,
Ask your doctor about Adderall or Vivance.
« Reply #28 on: March 03, 2011, 06:39:09 PM »
Bill,
Next appointment is Monday the 7th.  At least the body has gotten rid of most of the pitting edema that had my legs from the knees down looking like an elephant's!  Seems that was from a blood pressure med I was on.  Dr. took me off that med and didn't replace it.  BP has been low for a while now.  I guess getting out of teaching was good for something! LOL!!
But I haven't been able to concentrate on a single project for years (actually, probably never).......... and I would like to know how to do that.
(oh yeah, it's Vyvanse ;D )
Big Bear
Online Lauri Malila
« Reply #29 on: March 04, 2011, 01:21:29 PM »
 Hi PJ.
 Where did you get that landing gear? What are the main dimensions (height from wheel axles to highest point at top & width)? L
« Reply #30 on: March 04, 2011, 03:35:34 PM »
Lauri,
These are Carbon/kevlar half moon undercarts avaliable from Kaz minato.
« Reply #31 on: March 04, 2011, 09:14:00 PM »
Lauri,
Hmm.......... looks about 12" across and 5 1/2" high...........
Big Bear
« Reply #32 on: March 04, 2011, 09:52:56 PM »
11.5 x 4.5 actually.
« Reply #33 on: March 04, 2011, 10:19:38 PM »
Joys of sanding
Next time I read another BOM argument, I will post this picture.
« Reply #34 on: March 04, 2011, 10:23:03 PM »
Wont get that experience with a Shark ..  #^
Online Lauri Malila
« Reply #35 on: March 05, 2011, 12:42:34 AM »
 Yes we can!
 I started by removing the primer with #320.
 Then I brusher 5..6 coats of 2 component primer (Spies&Hecker Percotex thinned 1:1) with wet sanding between each coat. After that, paint and the other decoration. Then clear, #2000 sanding and polishing.
 They are seally not that nicely finished as they come. L
