  • June 17, 2025, 06:07:03 AM
Author Topic: New build  (Read 103631 times)
Re: New build
« Reply #50 on: January 19, 2013, 10:29:51 PM »
Wayne,
Never noticed a problem. This is not a true I-Beam. It's a Millennium type of structure. Sort of. It does use strip ribs but you'll notice the start of the spar. It's built in the wing after the ribs are in.
It will also be partially sheeted.
Re: New build
« Reply #51 on: January 20, 2013, 08:32:24 AM »
If you are ham fisted like me, they are fragile until you get the covering on them.   With that type construction they are very rigid also.
Re: New build
« Reply #52 on: January 20, 2013, 09:07:23 PM »
 Hmm. Maybe I'm just thinking too hard about it. ;D
Re: New build
« Reply #53 on: January 20, 2013, 09:44:54 PM »
Wayne,
I've been using this sort of structure for awhile. Lot of little parts, but it tends to be light and straight. When I can keep my finger off the paint trigger.
By the way, the colors will be metallic white, yellow jacket metallic, dark red metallic, metallic camero blue and some pearl black.
Should be fun.
Re: New build
« Reply #54 on: January 21, 2013, 09:08:35 AM »
No wonder your finish comes out heavy.   Look at all that metal in the paint.   LL~ LL~
Re: New build
« Reply #55 on: January 21, 2013, 09:16:03 AM »
Hmm.  I seem to remember you saying, either here on Stunthanger or to Mark Scarborough at the 2011 Stunt-a-Thon, that you were never going to paint another plane metallic, because of weight.
Oh well, I must be misremembering.
(I shouldn't tease -- I have rolls of various 'coats in various colors, and Rustoleum in red, white and blue.  So I'm hardly the paint sophisticate).
Re: New build
« Reply #56 on: January 21, 2013, 04:21:54 PM »
Tim,
Yea, that's why the white will probably end up just being white and any metallic will be in minimal trim. But the truth is, metallic paint isn't the culprit, it's putting on multiple coats. I will use a blocking coat and a very thin coat of white. In the mean time, I want to keep the weight down on the structure. And I have these cool new toys to try for the landing gear.
Re: New build
« Reply #57 on: January 22, 2013, 06:08:43 PM »
I've got an idea for the leadouts. WooHoo!
Re: New build
« Reply #58 on: January 22, 2013, 07:10:07 PM »
Some people claim to cover one or both sides of the balsa sheet with tissue/dope to strengthen the ribs or bulkheads, before cutting out the parts. Just a coat of clear on both sides would help quite a bit. Can't say I've ever stooped to such trickery, but it's not a bad idea. Watch the grain direction on the tissue, if you use it. Would .2 oz carbon mat work? I dunno, but an experiment with some scrap would tell the tale.  H^^ Steve
Offline MarcusCordeiro
Re: New build
« Reply #59 on: January 22, 2013, 07:58:29 PM »
No more pics?? :'(
Marcus
Live to fly, fly to live
Aces High!
Here comes Marcus, man..."
Re: New build
« Reply #60 on: January 22, 2013, 08:53:28 PM »
I'd want to weigh the result, and compare it to just using a bit heavier balsa.
It'd certainly keep the balsa from splitting, particularly if the tissue grain runs crossways to the balsa's grain.
CF may dull your knife blades extra-fast.
Re: New build
« Reply #61 on: January 23, 2013, 02:26:10 PM »
A solution for no known problem?
Re: New build
« Reply #62 on: January 23, 2013, 02:45:49 PM »
Here's a suggestion for what to do if your idea doesn't pan out.  Do not let it be said that I am not without suggestions when a technological problem presents itself.
Given that your plane is electric, with training this may even work for voice-activated, in-air adjustment.
Re: New build
« Reply #63 on: January 23, 2013, 10:39:25 PM »
Cute.
Offline Steve Bakac
Re: New build
« Reply #64 on: January 26, 2013, 12:49:02 AM »
G/day Randy
                   Just a quick question ,how do you get the true air foil shape on the rib lay out on the angle ribs? do you just cut the trailing edge off ribs like normal or do you have a secret in keeping the high point of rib in line? haha. just wondering as i got a plan here that i like to build and has a angle rib lay out. thanks
Re: New build
« Reply #65 on: January 26, 2013, 02:30:33 PM »
Steve,
Due to this being strip ribs, sort of like an I-beam layout, I mark each rib with the high point span-wise based on original design parameters. then I cut the ribs front and back to maintain the high point in the desired location. It's gets even more complicated since this is an elliptical wing so the high point isn't a straight line and has an elliptical vertical taper.
Fun stuff.
Re: New build
« Reply #66 on: January 27, 2013, 08:26:37 PM »
I'll post some more pics in a few days. I want to thank Tim Wescott for some pictures that triggered the idea that led to my leadout configuration. While not really like Tim's idea, it certainly gave me the idea. Hope it works OK. It's done and seems to work really well. Guess we'll see.
The blocks are done and fit the fuse like a glove, so that's cool. Need to build gear mounts next then I can finish dropping the half ribs in and get the bottom sheeted, flip the wing over and do the other side. Pretty cool so far.
So, I'm plugging through. While not brilliant, I have been able to figure my way around some knotty problems. It's what makes this fun.
Re: New build
« Reply #67 on: January 27, 2013, 09:23:02 PM »
 Cool, it's great to see you're "up and running" again here Randy. y1
Re: New build
« Reply #68 on: January 27, 2013, 09:36:49 PM »
Wayne,
Weeee!!!!!!!!!!
Re: New build
« Reply #69 on: January 27, 2013, 09:42:24 PM »
I am filled with great trepidation.  I sincerely hope it was the Banshee wingtip, and not my drawing of Esmeralda here, that got you going.
Re: New build
« Reply #70 on: January 28, 2013, 09:31:43 AM »
Tim,
He, he.
Re: New build
« Reply #71 on: January 28, 2013, 08:24:15 PM »
Here's a couple more pics from a journeyman builder for anyone interested.
Re: New build
« Reply #72 on: January 28, 2013, 08:28:11 PM »
What is the top picture?  Molds for fuselage pieces?
Re: New build
« Reply #73 on: January 28, 2013, 09:37:37 PM »
Those are the molded decks. I guess I should have flipped them over to show the support formers.
Re: New build
« Reply #74 on: January 29, 2013, 09:04:15 AM »
This old man can't figure out the middle pic.
Re: New build
« Reply #75 on: January 29, 2013, 09:30:08 AM »
My guess is it's the adjustable leadout guides, but I wouldn't bet $ on it!  :-[ Steve
Re: New build
« Reply #76 on: January 29, 2013, 09:39:04 AM »
It does look like leadout slides, and he's adjusting from the bottom of the wing, like the ones that I schlopped onto the Gift Banshee I have.
If the wing is thin, and if those guides are buried well inboard of the tip, aren't there going to be problems if the plane rolls?  Even if it doesn't bang on corners, I would expect that in turbulent conditions you'd get quite a bit of roll.  I'd be worried about the actual exit point at the tip cracking out, or otherwise responding badly to having leadouts pushed up or down into it.
Offline John Miller
Re: New build
« Reply #77 on: January 29, 2013, 10:13:47 AM »
Nice post, and it looks like a really nice "Randy Dandy Design". (Donoldo's words, not mine) Way to go. HH%%
I look forward to seeing it in person this next flying season.
Re: New build
« Reply #78 on: January 29, 2013, 10:24:20 AM »
" I'd be worried about the actual exit point at the tip cracking out, or otherwise responding badly to having leadouts pushed up or down into it."
A lot of guys line the leadout tunnel in the tip with 1/64" plywood. Not saying that Randy does or doesn't do that.
John...We'll look forward to seeing you around this season also. Does that mean you'll be at NW Regionals at Eugene? Try to get Patrick to show. I intend to go, 'cause I have no plans to drive to Tennessee again next May! I'm trying to get Gary Gingerich to go also.  H^^ Steve
Re: New build
« Reply #79 on: January 29, 2013, 01:56:38 PM »
Randy,
Has anyone built this model before?
Be interesting to see what it looks like.
Charles
Re: New build
« Reply #80 on: January 29, 2013, 03:10:09 PM »
Tim,
I thought about that, too. The reason it's done this way is that I could really come up with an adjustment device that would work with the wing tip layout. Due to this being an electric, I was concerned about being able to get the leadouts far enough forward. That put the possibility that the leadouts would exit the leading edge into play. so I put in this device and have the path lined with 1/64" plywood. I've also reinforced the wing top and bottom to withstand a certain amount of torque that might happen if I hit the wind wrong and get some roll. The system is very free moving so I don't expect any problems, but you never know, I guess.
Oh, almost forgot. This whole thing will have a hatch over it so no, it won't be a turbulence device.
Charles,
It's a new design, but it's based on some other stuff I've done and a lot of listening to very good designers.
Re: New build
« Reply #81 on: January 29, 2013, 03:53:58 PM »
Randy, it sounds like you've got everything covered.
I shoulda figured.
Re: New build
« Reply #82 on: January 29, 2013, 05:48:32 PM »
Tim,
As Justin Wilson said, I'm a safety man. I wear a belt AND suspenders.
Re: New build
« Reply #83 on: January 29, 2013, 07:18:25 PM »
 Hmm, looks like the "102nd" way to do a leadout adjuster, great idea Randy! y1
 What are the white nylon "thingies" connecting the leadout wires and the bellcrank? How do you have them attached to the wire?
Re: New build
« Reply #84 on: January 29, 2013, 09:24:44 PM »
Electric-plane leadouts seem to want to be pretty far back, so leave some room there, too.
Re: New build
« Reply #85 on: January 29, 2013, 11:25:32 PM »
Tim,
Those are actually PC board ala Brett Buck.
Howard,
No worries, it will go a long way back, too. To be clear, this was just a way to get around a problem. I would not do this if I had another way, but this works.
Re: New build
« Reply #86 on: February 02, 2013, 10:52:38 PM »
OK, I'm machining the gear mounts. The stab is framed up. Just need to shape it. Should be able to finish up the gear tomorrow and get the stab done.
Re: New build
« Reply #87 on: February 03, 2013, 07:54:53 PM »
So, I machined gear mounts out of aluminum. They are pretty light (under a 1/4oz each for the whole assembly). Now I have to figure out how to attach them so they stay in the wing. I have an idea to lock them in so that they aren't dependent on glue to hold them in. The stab is done. I'll post some pictures in a couple of days.
Re: New build
« Reply #88 on: February 03, 2013, 09:47:56 PM »
 Um, just wondering, why aluminum?
Re: New build
« Reply #89 on: February 03, 2013, 10:11:08 PM »
Light, strong, takes epoxy well, the machinable alloys are easy on the tooling and easy to get a good finish -- what's not to like?
Re: New build
« Reply #90 on: February 04, 2013, 09:19:51 AM »
What Tim said. Plus, you can drill and tap it for gear retention clips. Lot of work to machine out a lot of the material to keep the weight off, but in the end makes a nice piece.
Re: New build
« Reply #91 on: February 04, 2013, 11:43:04 AM »
Randy,
Didn't know you had machine capabilities. Kudos!
Got a photo of that?
Charles
Re: New build
« Reply #92 on: February 04, 2013, 02:31:39 PM »
Charles,
Primarily a bench top mill along with a ton of tooling. Nice as you can do a lot of stuff yourself. I'll take some pictures before I glue them in the wing.
Re: New build
« Reply #93 on: February 07, 2013, 03:50:54 PM »
more photos !!!
 ;D
Re: New build
« Reply #94 on: February 07, 2013, 04:55:52 PM »
more photos !!!
 ;D
I second that  ;D ;D
Marcus
Aces High!
Re: New build
« Reply #95 on: February 07, 2013, 05:30:16 PM »
I will try to take some tonight. I haven't been able to get out to the shop this whole week due to work stuff. but tonight is free!
Re: New build
« Reply #96 on: February 07, 2013, 06:55:36 PM »
OK, this is tonight before I get started. Notice the hinge pockets in the stab training edge. The tips of the stab are just sitting there. I'll shape them once the stab is sheeted and the twin rudders are on. And the molded block flipped over is for Tim. The gear blocks are not finished, but you get the idea.
Re: New build
« Reply #97 on: February 07, 2013, 07:44:17 PM »
Those gear "blocks"(?) are absolutely fantastic!!!
Congrats˛!!!!
Marcus
Aces High!
Re: New build
« Reply #98 on: February 08, 2013, 06:08:28 PM »
Marcus,
they are still a bit rough and I think I'm going to hog them out a bit more, but that's the idea. They are right around a 1/4oz right now and I think I can shave another few grams off before gluing them in.
Re: New build
« Reply #99 on: February 09, 2013, 07:22:46 PM »
A delay in production. I broke my last decent bandsaw blade. Have to make a trip to the tool store to get another.
Sigh....
