  • July 26, 2025, 07:27:32 AM
Author Topic: New build Thread SV 11  (Read 25033 times)
Online RC Storick
« on: September 30, 2012, 07:36:54 PM »
First I laid th plans out to see what it was going to take
Then I started to gather parts and wood from my supply
Then I squared up 1 side of 1/8 X 4 X 48 Balsa
Then I started to transfer stations to the sides and lay out parameter
Measuring down I drew the center line of the airfoil. I cut both fuse sides together. I cut the doubler's and found out I have no glue. So tomorrow I will glue the .5 CF mat and let sit to dry.
Re: New build Thread SV 11
« Reply #1 on: September 30, 2012, 08:18:17 PM »
I thought your camera was busted!
Looks cool.  I love this stage of a building project.
Offline Jason Greer
« Reply #2 on: September 30, 2012, 09:13:00 PM »
Thanks for posting this Robert.  Looking forward to watching this come together.
Jason
El Dorado, AR
AMA 518858
Offline Jeff Traxler
  • T-Bone
« Reply #3 on: September 30, 2012, 09:38:56 PM »
Sparky,
            That Tiger don't look very electric ;D ;D ;D
Online Crist Rigotti
« Reply #4 on: September 30, 2012, 10:06:46 PM »
Gonna follow this one Sparky!
Offline Gene O'Keefe
« Reply #5 on: October 01, 2012, 08:33:51 AM »
looks like Tom Morris "See-Temp" (spelling?)
Gene O'Keefe
AMA 28386
Offline Allen Brickhaus
  • ACE
« Reply #6 on: October 01, 2012, 02:26:55 PM »
Loooooookin' good.
Allen
« Reply #7 on: October 01, 2012, 02:52:42 PM »
OK, Sparky,
I figure you already have the fuselage framed up!  Will it be a built up or a foam wing?
« Reply #8 on: October 01, 2012, 02:55:57 PM »
I'm setting notify on this thread!!
Getter Dunn!!!!!
As Larry the cable guy would say.
« Reply #9 on: October 01, 2012, 05:23:32 PM »
OK, Sparky,
I'm guessing it'll be a foam wing.   y1 y1
Dwayne
« Reply #10 on: October 01, 2012, 07:30:28 PM »
Lost foam I'm guessing.
Offline MarcusCordeiro
« Reply #11 on: October 01, 2012, 07:37:05 PM »
Live to fly, fly to live
Aces High!
Here comes Marcus, man..."
« Reply #12 on: October 01, 2012, 09:58:20 PM »
 Sparky with a foamie? I'm thinkin' not, at least I hope not. ;D
 Great to see some build stuff from you again Sparky, this will be a good one to watch. y1
Online RC Storick
« Reply #13 on: October 01, 2012, 10:49:46 PM »
Crist is right its a foamie. I glued the doublers and waiting for them to dry. I will post some pics Tue. Been working on Shirt orders. We need to get those last 12 filled.
« Reply #14 on: October 01, 2012, 10:58:26 PM »
 Well I'll be, I'da never guessed that one!
Online RC Storick
« Reply #15 on: October 02, 2012, 09:45:59 PM »
Life sometimes gets in the way. I was not able to do much today. I cut the bulkheads and hollowed them. Cut the firewall and got motor mounts ready. I will follow with some pics when I get some more progress done. I would expect to have this framed up in 2 weeks but its moving slow.
« Reply #16 on: October 03, 2012, 08:41:42 AM »
That happens to me all the time  y1
So I'd say keep building, just do it and I'm lovin' it!
Marcus
Aces High!
Online RC Storick
progress and weights
« Reply #17 on: October 09, 2012, 08:34:28 AM »
first photo is fuse crutch
Notice the plywood squares for cowl mounting screws. I have found this method to work well.
Second photo is fuse less turtle deck at 6.4 oz
last shot is stab complete at 2.7 oz
So lets do a little projected weighs add a 12 oz wing and a few oz for turtle deck and rudder wood work should be around 25 oz and add LG blocks lets say 29 oz total. Paint another 10 oz. Add engine prop spinner tank and the rest of the crap that it takes should be just under 60 oz.
« Last Edit: October 09, 2012, 10:27:15 AM by Robert Storick »
Eric Viglione
« Reply #18 on: October 09, 2012, 09:03:37 AM »
I like the hammer and pry-bar, two essential building tools in my shop too!  LL~
Looking good. You've caught up and will probably have passed me shortly Sparky... After agonizing over alignments and controls for several of my last shop sessions, I finally tacked my stab in last night. *Sighs*
Well, it goes a little quicker from here out and starts to look like a plane when I get the fuse closed up, etc. Then on to the fun part, finishing, oh joy!
Have you thought up a new paint scheme for this one, or are you going a more traditional SV11 paint job?
EricV
Offline Rafael Gonzalez
« Reply #19 on: October 09, 2012, 09:44:12 AM »
Geeeezz!!!!! How did you get so much built? Looks good....
Online RC Storick
« Reply #20 on: October 09, 2012, 10:20:38 AM »
Hollowed blocks this nose block started out 1.5 oz. I have hollowed it and its now 18 grams. I am going to keep sanding till its 15 grams. I left the front part UN touched till after install, to then be hollowed. Sand the inside perfectly smooth stronger and lighter. This is almost complete.
 when this block is done it will be as smooth inside as outside. Two reasons first is its lighter second is when you crash it doesn't look like you took shortcuts. But lets hope the second one needs not be looked at.
Eric Viglione
« Reply #21 on: October 09, 2012, 11:06:01 AM »
Hey, that looks like mine, I gotta go check my shop and see if it's missing... Only mine is 19 grams... but the Katana does have a 1/2" longer nose moment.
I've never hollowed under the engine, and since I usually end up adding a smidgen of nose weight anyways, I see no reason to. I'm certainly not hollowing that extra gram on my new 75 plane, I figure it needs a little cusion for the pushin there. LOL!
But I do sand my interior blocks smooth also thinking that it's stronger somehow. I know it applies to polished connecting rods, etc. Not sure if we're correct on balsa, but it does look nicer and makes it easier to see if your hollowing is consistent.
To keep the saw dust down when I do the rough hollowing, I use the exacto circular draw knife and pull out strips of balsa best I can until all that's left is the fine work for the dremel with one of those diamond ball bits that looks like it was dipped in magnetic filings. Then it's down to some sandpaper by hand to smooth out. How do you do it Sparky?
Keep on keepin on!
EricV
« Last Edit: October 09, 2012, 03:11:14 PM by Eric Viglione »
« Reply #22 on: October 09, 2012, 12:41:40 PM »
Hi Eric,
Not sure what Sparky does, but I use a piece of old shaped LE (Ringmaster??) w/40 grit to finish sand all the irregularities down smooth.  Then hand sand wit finer just to smooth the sanding marks.
Offline Aaron Little
« Reply #23 on: October 09, 2012, 01:26:01 PM »
Super Tiger 60?
« Reply #24 on: October 09, 2012, 02:57:02 PM »
Super Tiger 60?
It does look like one.
Robert, are you going to carbon-veil it? I mean, the nose...
Great work!
Marcus
Aces High!
« Reply #25 on: October 09, 2012, 03:10:20 PM »
definitely is one.
also cool to see the little yellow icon i made years back still in use.
Online RC Storick
« Reply #26 on: October 09, 2012, 04:22:04 PM »
Great work!
Marcus
I would bet the PA.75 runs smoother than the ST.60 I plan on using but I will glass the nose with .5 glass cloth
Online RC Storick
« Reply #27 on: October 09, 2012, 09:40:59 PM »
tonight I molded the LE and got the sheeting ready for the wing. Tomorrow I will sheet the wing and post some pics. I should have the airframe together by Monday or Tuesday night. Im getting slow in my old age 2 weeks to build a airplane is slow.
« Reply #28 on: October 09, 2012, 10:16:27 PM »
 Thanks for the pics Sparky, keep 'em comin'! ;D
 I used to have a blue head ST.60 R/C engine way back when. I see yours is a natural finish here. I don't even know, were the blue heads just R/C motors or?
Online RC Storick
« Reply #29 on: October 09, 2012, 10:21:04 PM »
not the same beast. The V.60 was the top of the line stunt motor in the 80tys and 90tys.
« Reply #30 on: October 10, 2012, 06:20:20 AM »
Sparky,
How about more detail on building this model?  It would be appreciated.
Online RC Storick
« Reply #31 on: October 10, 2012, 07:39:50 AM »
Sparky,
More to come as I get closer to getting it done. I can't build and type at the same time with any speed.
« Reply #32 on: October 10, 2012, 10:07:07 AM »
Where I'm coming from is that you show the stab and elevators done.  How did you build them?  What weight wood?  How are you doing the hinge slots, type od glue, etc.
Offline Steve Fitton
« Reply #33 on: October 10, 2012, 03:38:15 PM »
Super Tiger 60?
Hey Aaron, did you get the tail fixed on the Satona yet?
Online RC Storick
« Reply #34 on: October 10, 2012, 04:43:30 PM »
I am now sheeting the wing per the Bob Hunt method show here
How to Sheet a Foam Wing - AeroManiacs
www.aeromaniacs.com/pdf/Bob%20Hunt%20Sheeting%20Wing.pdf
« Reply #35 on: October 10, 2012, 05:26:38 PM »
Not fixed.
I have lived in three different places and really haven't had a lot of desire to fix it.
I will bring my vector to huntersville and go from there.
« Reply #36 on: October 10, 2012, 05:54:34 PM »
Thanks for the link Robert
I was looking for this how to...
Marcus
Aces High!
Online RC Storick
« Reply #37 on: October 10, 2012, 11:42:43 PM »
Tonight I glued the LE to the foam cores and let cure overnight. Tomorrow I will skin the wing and by Sunday it should be up on its wheels.
These are the mold bucks. While waiting on skins I will be molding the turtle deck and I will do a how to in detail on this. What I am doing now has been covered in other threads. See Derek's thread.
« Last Edit: October 11, 2012, 07:13:43 AM by Robert Storick »
Offline Gordon Tarbell
« Reply #38 on: October 12, 2012, 08:46:09 AM »
I did not see any plywood doublers in photos of the nose section. Is this just balsa with carbon veil sandwiched inbetween?
Gordon Tarbell AMA 15019
« Reply #39 on: October 12, 2012, 08:53:54 AM »
That is how Randy normally does it and it seems to work very well.
Online RC Storick
Slower as I get older
« Reply #40 on: October 15, 2012, 10:22:44 AM »
I looked at the dates and to get all the major parts built it has taken 2 weeks. 2 more shots
« Reply #41 on: October 15, 2012, 08:45:26 PM »
 Still pretty fast if you ask me. y1
Online RC Storick
« Reply #42 on: October 18, 2012, 11:21:02 PM »
well the 3 main components are done and the details start now. I will be adding a ellipse fiberglass patch to center of wing before installing it into fuse. what you see here is 22 oz. I am shooting to just under 60 or at 60 OZ. It might happen. the wing complete weighs just under 15 oz 14.9. I would have like to see 13 or so but I used my second choice wood. Guess its time to reorder. This build now is 20 days old.
I am building it exactly to plans and you have no idea how hard that is for me. I do want a base line to see just how much things have changed.
« Reply #43 on: October 19, 2012, 06:28:53 AM »
Bob,
It looks like you have the flap horn facing the wrong direction.  Be sure it gets installed correctly.  I'm here for ya!   y1
« Reply #44 on: October 19, 2012, 09:06:16 AM »
Look at the plans again in the first post.  Yes I am being an old grouch after this mornings crossing duty.   Did I mention I hate DST this time of year.
« Reply #45 on: October 19, 2012, 08:03:11 PM »
 Lookin' good Sparky! Got a paint job in mind yet?
 ...that reminds me, we have an opportunity here. When the time comes on this one I'd be very interested in seeing a detailed step by step of your complete finishing process, starting from the bare wood. y1 y1 y1
« Reply #46 on: October 19, 2012, 11:15:14 PM »
The last couple I did went something like this:
1) Vacuum the wood
2) Apply Monokote
3) Admire your finished model.   y1
I'll quit mucking up Bob's build thread now.   :)
« Reply #47 on: October 20, 2012, 11:44:52 AM »
The SV11 is a REALLY popular plane for guys stepping up. This is a great build thread to learn and see how a pro does it.
Also, I applaud Sparky's use of the venerable ST60 because, guys can extrapolate his setup to their less expensive EVO 60's and pick up valuable tips.
Top performance starts on the building table,(like Windy always says) and Sparky is going to show you how to get there.
P.S. If you want to progress past this build thread when it's over, ask Windy for his Strega build DVD start to finish. That will take you all the way.
Between stuff like Spark's build thread, and Windy's DVD, there should be NO reason why we should have a BOM problem.
« Reply #48 on: October 20, 2012, 04:25:27 PM »
Sparky going old school. I like it.
Online RC Storick
« Reply #49 on: October 20, 2012, 04:44:57 PM »
I have a EVO.60 too that fits right in place of the ST.60
