  • June 17, 2025, 10:06:01 PM
Author Topic: Hinge detail  (Read 1302 times)
Offline RC Storick
Hinge detail
« on: January 13, 2014, 02:44:05 PM »
I am working on the flaps now and I told you I would do a hinge detail .
First cut and sand to this shape 7 ply 1/8 AC plywood and drill a hole for the bushing. Next cut a slot into the flap the same thickness as the flap in this case 3/8. Then 1/2 inch each side recess 1/2 the thickness of the flap in this case 3/16. this is the hinge pocket and balsa will be epoxy will hold the LE cap and sanded to the shape of the LE of the flap. Do a test piece first to get the depths before doing in on your flap or elevator. I hope this explains it.
Easy to do hard to write about.
Offline RC Storick
Hinge pocket
« Reply #1 on: January 13, 2014, 03:18:25 PM »
Here they are cut into the flap
