  • July 12, 2025, 09:18:55 AM
Author Topic: My MC 72  (Read 26588 times)
Offline Duke.Johnson
Re: My MC 72
« Reply #50 on: October 29, 2013, 10:39:02 AM »
Duke Johnson said " I wish I could build that well. I have a Yates Dragon I'd like to build but I don't think I could do it justice."
My father used to say "If someone else can do it, I can too"
I have lived with that advise.
Don't sell yourself short. The best part of this forum is that so much knowledge is shared.
Thanks, I think I'm going to build a built up fuse and finish the best I can this winter to get ready for the Dragon. Now back to Robert's cool plane after this short message. :)
Re: My MC 72
« Reply #51 on: October 29, 2013, 11:10:53 AM »
I certainly see most of Robert's logic. But like everything  else, you take logic and do experiments then decide if it is logic. If Robert has done his experiments and is happy, regardless of "the math", I say Rock On.
Offline RC Storick
Re: My MC 72
« Reply #52 on: October 29, 2013, 09:25:38 PM »
Robert said that the photo was copied and saved as a .PDF file, nothing else, thus the question. Meanwhile, I'll look forward to seeing how close both the vertical and lateral CG's comes out.  Oops, Spell Check wants to change "CG's" to "cogs". Damnit!   H^^ Steve
I should have been more clear. The small red photo was doctored in PS with my numbers. The full size plane was brought into Adobe and a PDF was made from the plans at 150% of original size. Then traced on to white paper and center lines and wing locations were drawn. As I said before this will be as close to scale as one could get for a full blown stunt plane. Even the spinner is the right size.
I choose this airframe because I thought it would fall close to scale.
Offline RC Storick
Re: My MC 72
« Reply #53 on: October 29, 2013, 10:32:31 PM »
There is hope
Re: My MC 72
« Reply #54 on: November 01, 2013, 06:45:18 PM »
 Got that thing ready for primer yet? ;D
Offline RC Storick
Re: My MC 72
« Reply #55 on: November 01, 2013, 08:33:32 PM »
Starting the wing tonight
Offline RC Storick
Re: My MC 72
« Reply #56 on: November 03, 2013, 01:11:56 PM »
Here is 2 shots of the wing. I should put the airframe together this weekend
Offline RC Storick
Re: My MC 72
« Reply #57 on: November 03, 2013, 05:11:46 PM »
Wing weight 3.1 ounces. I might have to add ballast say 10 ounces.
Offline Dan Bregar
  • Field Marshall
Re: My MC 72
« Reply #58 on: November 03, 2013, 05:14:21 PM »
You do good work Robert, and lots of it !!!  :)
AMA 33676
Re: My MC 72
« Reply #59 on: November 03, 2013, 09:57:40 PM »
  Why not a I-beamer this time? And what wing are you using, looks like lost foam method?
Re: My MC 72
« Reply #60 on: November 03, 2013, 10:18:38 PM »
 Are those laser cut ribs?
Offline RC Storick
Re: My MC 72
« Reply #61 on: November 03, 2013, 11:23:38 PM »
Its my design lost foam wing and no they are hand cut ribs
Online john e. holliday
Re: My MC 72
« Reply #62 on: November 04, 2013, 08:57:30 AM »
Sparky you are an artist beyond compare.
Offline RC Storick
Re: My MC 72
« Reply #63 on: November 06, 2013, 05:32:04 PM »
Forth set of wing tips. These are molded and built up.
Re: My MC 72
« Reply #64 on: November 06, 2013, 06:01:28 PM »
That's very cool.  I might have to try that on the new dog.  Oughta take me a couple of months.
Offline RC Storick
Re: My MC 72
« Reply #65 on: November 06, 2013, 06:07:13 PM »
I have 30 hours in tips and still don't have one done yet. The first 2 sets were too heavy and the third set was not well thought out. So this one was re thought and I started on them this morning. Lots of work! But I want a super cool MC 72. More scale like than any I have seen.
Offline RC Storick
Re: My MC 72
« Reply #66 on: November 06, 2013, 10:20:45 PM »
almost
Re: My MC 72
« Reply #67 on: November 06, 2013, 10:41:27 PM »
 After studying the previous pic that shows the tip outline on the foam cradle, I was wondering how you were going to finish the wingtip outside of the last rib.
 Looks like this plan will work, and it gives you some meat to work with for the leadout slot opening. y1
Offline MarcusCordeiro
Re: My MC 72
« Reply #68 on: November 07, 2013, 03:31:22 AM »
As always, very nice Robert.
Marcus
Live to fly, fly to live
Aces High!
Here comes Marcus, man..."
Offline Doug Moon
Re: My MC 72
« Reply #69 on: November 07, 2013, 07:16:39 AM »
Can you show the mold you used for the skin of the rib?
That looks cool.
Doug Moon
AMA 496454
Dougmoon12@yahoo.com
Offline RC Storick
Re: My MC 72
« Reply #70 on: November 07, 2013, 07:28:03 AM »
That looks cool.
No sorry. How it was done is I took a 6 inch section of the male plug. Cut it into a circle and sanded the tip shape into the foam. After I had 2 skins I sectioned it at the rib stations for the rib templates.
Offline RC Storick
Re: My MC 72
« Reply #71 on: November 07, 2013, 08:57:41 AM »
Well thie is how its going to look. So far 3 days into one tip. This is the best also the hardest thing I have ever done.
Re: My MC 72
« Reply #72 on: November 07, 2013, 09:00:29 AM »
It is looking great Robert.  You're inspiring me to refine my building skills.
Offline RC Storick
Re: My MC 72
« Reply #73 on: November 07, 2013, 09:07:07 AM »
Thanks I'm really getting my stride back.
Re: My MC 72
« Reply #74 on: November 07, 2013, 09:12:04 AM »
I go through phases, sometimes I hit it hard and sometimes I can't get going.  I've had the PT-19 on the kitchen table for a week and haven't touched it.  The repairs are made and all I need to do is cover it.
Re: My MC 72
« Reply #75 on: November 07, 2013, 04:53:30 PM »
 Probably a stupid question but I'm assuming you hollowed the tip block?
Offline RC Storick
Re: My MC 72
« Reply #76 on: November 07, 2013, 08:29:02 PM »
Yes it weighed 3 grams
Offline Doug Moon
Re: My MC 72
« Reply #77 on: November 08, 2013, 01:27:21 PM »
That explains it well.  I was wondering how you were gonna make the ribs.
That is a cool idea on how to make those tips.
They look great.
Thanks for the info.
Doug Moon
AMA 496454
Re: My MC 72
« Reply #78 on: November 08, 2013, 06:56:03 PM »
 And he says he's "just a mechanic". ;D :##
Re: My MC 72
« Reply #79 on: November 09, 2013, 04:28:24 PM »
Yea, I'm in one of those spots right now. Can't seem to get going again. And with a plane near completion that's unusual.
Offline RC Storick
Re: My MC 72
« Reply #80 on: November 09, 2013, 06:57:56 PM »
Wing progress. Weight of this wing is 5.6 ounces including weight box, lead out adjuster and tips. With un sanded  flaps its 7.25 no hinges or horns or BC.
Re: My MC 72
« Reply #81 on: November 09, 2013, 07:29:51 PM »
 Looks good. Maybe I missed it, what's the wingspan and area?
 This is first constant chord wing I've seen you do Sparky, it'll be interesting to see how you like it in the air.
 Looks like you'll be painting next week! S?P ;D
Offline RC Storick
Re: My MC 72
« Reply #82 on: November 09, 2013, 07:38:13 PM »
56 WS. 9.75 cord 2.25 flap. Aprox area is 650.
Re: My MC 72
« Reply #83 on: November 10, 2013, 10:02:27 PM »
 That's a real nice size Sparky. A big enough model that it could be a solid contender in competition, but yet not so big it's that it's overly difficult to transport. That's a perfect compromise for a lot of flyers.
 "Heads-up" to all of you kit builders out there, hopefully you're watching and considering this one. Just don't forget the glow power option on the plans. S?P ;D
Offline RC Storick
Re: My MC 72
« Reply #84 on: November 11, 2013, 04:19:30 PM »
Well complete wing with flaps is 10.1 ounces. Is that light enough? LL~
Offline RC Storick
MC 72 All parts done. PIC
« Reply #85 on: November 11, 2013, 09:53:25 PM »
All sub assembly's complete. I should have it on its wheels this weekend.
Re: My MC 72
« Reply #86 on: November 11, 2013, 10:10:49 PM »
That fuse looks really nice!
Offline RC Storick
Re: My MC 72
« Reply #87 on: November 11, 2013, 11:15:40 PM »
Thanks it's scale. I was looking back and see that this plane is not 30 days old yet. I should have it all framed up in less than 30 days. The painting on the other hand will take some time. The oil tank behind the spinner will be gold leaf and it will be painted Miss Ashley Red with gold radiator's in all the scale places. It might have working stacks. I took my Mattel Vac-U-Form and made a pilot but I think I will do a detailed cockpit instead. I have seen some great work here and that has inspired me to do it. I also think I can do the details lighter than a pilot.
I am still thinking how I can hide my AMA number like I did on my Tbolt and still be legal. I'm sure it will come to me as I am painting.
Re: My MC 72
« Reply #88 on: November 11, 2013, 11:29:40 PM »
 Cool stuff. y1
 Just an idea for the AMA number...if you're going to do panel lines you could do the AMA number using the same thin black outline. It would be there, but it wouldn't really be noticeable until you got up very close to the model.
Offline RC Storick
Taped together (pic's)
« Reply #89 on: November 13, 2013, 12:15:03 PM »
Well I am starting to fit everything together. Here is two shots of what it's going to look like. Airframe is 18.5 ounces.
I just ordered dope from Wicks. The gold paint for the radiators must have real gold in it. 28.00 per quart where clear and colors are only 15.00 so almost twice the cost. Thinner is 53.00. I have 3608 but I like to use the same thinners when painting. Less chance for problems.
« Last Edit: November 13, 2013, 12:39:16 PM by Robert Storick »
Re: My MC 72
« Reply #90 on: November 13, 2013, 02:29:53 PM »
 8) 8) 8) 8) 8) 8) 8)
Marcus
Aces High!
Offline Douglas Ames
Re: My MC 72
« Reply #91 on: November 13, 2013, 06:05:16 PM »
There's actually 3 CG's - Longitudinal, Lateral & Verticle.
Lateral CG (along the wing span) is more of a dynamic thing as half your line weight comes into play, plus the Cent. force applied to your tip weight. Above my head mathmatically...
I saw a picture of Al Rabe on SSW, hanging his model by the leadouts against a wall to check Verticle CG. If the wing is parallel with the wall, you got it!
Checking Long. CG is a given.
AMA 656546
Offline RC Storick
Re: My MC 72
« Reply #92 on: November 13, 2013, 06:44:15 PM »
There's actually 3 CG's - Longitudinal, Lateral & Vertical.
Someone has been listening!  CLP**
Re: My MC 72
« Reply #93 on: November 13, 2013, 07:00:09 PM »
And they're in the same place.  The classic way to find them (it) for a rigid body is to hang it separately by three different points.  The CG will be at the intersection of the three lines that go straight down from the places it's hung from.  Play the cartoon, "Where is this guy's centre of gravity?" at http://www.s-cool.co.uk/a-level/physics/moments-couples-and-equilibrium/revise-it/centre-of-gravity-and-centre-of-mass .
Offline RC Storick
Re: My MC 72
« Reply #94 on: November 13, 2013, 07:06:32 PM »
Is he being slung around on a wire?
Re: My MC 72
« Reply #95 on: November 13, 2013, 07:14:09 PM »
Lateral CG[/b] (along the wing span) is more of a dynamic thing as half your line weight comes into play.
That one again.  See post 17 of http://www.clstunt.com/htdocs/dc/dcboard.php?az=show_topic&forum=103&topic_id=382606&mesg_id=382606&listing_type=search#382738 .
Re: My MC 72
« Reply #96 on: November 13, 2013, 07:41:09 PM »
That is actually a good point, as we discussed elsewhere.  Lots of us take for granted that gravity is an acceleration and so is what the wire by which an airplane is slung does.  It wasn't (the details weren't anyhow) obvious to people before Newton figured it out.  I looked a little on the Web for a good explanation, but didn't find one.  I probably saw it justified somewhere long ago, but I don't remember the justification.  Serge explained this for a living, so he can probably explain it rigorously enough to satisfy the skeptical student.  It works, though, and we use it to design airplanes and inertial navigation systems, and Brett uses it to steer satellites.
Re: My MC 72
« Reply #97 on: November 13, 2013, 10:37:15 PM »
Agreed.
I was thinking of a "3D ball" that represents the CG with 3 lines running through it - Vert./ Lat. / Long. ...and it moves.
Your chart is interesting but trimming wings level with a buddie/spotter outside the circle is a quicker solution.
AMA 656546
Re: My MC 72
« Reply #98 on: November 13, 2013, 11:18:19 PM »
Very Interesting
KT
Not so interesting. At the time, we were then looking at Robert's 2-view drawing, so vertical was up/down, lateral was left/right. Had nothing to do with airframes or aeronautics at that point. In a 3-D situation, it's different, of course.
I'm mostly interested in where the fore/aft CG will be, before trimming commences...and after. It's got to be correct, not close enough. Secondarily, is the constant chord wing going to be a deal killer in turbulent conditions?  ??? Steve
Offline RC Storick
Re: My MC 72
« Reply #99 on: November 13, 2013, 11:21:39 PM »
I bet it will be fine.
