  • July 13, 2025, 03:28:01 AM
Author Topic: My Bell Crank Mount  (Read 3256 times)
My Bell Crank Mount
« on: February 26, 2015, 07:39:48 PM »
Been working on the planes and can't believe it took me most of the day to do the bell crank and getting it mounted.   This is on/in one of the designs of one of my heroes.  Got the wing tip guide in also.   Went to  my box for a bell crank and couldn't find them.  Now I have this one done they will probably show up.   Had these Perfect 3 inch bell cranks laying around and I know they are not strong enough by themselves.   So I doubled them up.  4-40 allen head bolts.   1/16 tubing for the lead outs to go through.   Should last as long as I will.   When I get further along will post pics as the fuse is framed up waiting for the wing and tail assembly.
Need to get fingers to hit right keys. jeh
Offline Geoff Goodworth
Re: My Bell Crank Mount
« Reply #1 on: February 27, 2015, 01:07:36 AM »
Doc, it's a good technique but do you have a plain bearing surface for the leadout loops to run on?
I would worry about threads cutting through the 1/16" tubing fairly quickly if you don't.
I remember Windy doing the ends of his carbon fibre bellcranks in a similar way but he used small shoulder screws which provided the plain bearing surface.
« Reply #2 on: February 27, 2015, 06:04:25 AM »
John,
You don't really need the brass tubing. A simple eyelet is fine. Do the ends any way you want, but we just did the ends the old school way, with a loop, pull and crimp on the copper tube.
I've never had one come apart as far back as 62 when we were all active. Did a great deal of flying back then. I wasn't the only modeler that did his bellcrank this way, I was just the first.
Glad it's catching on.
« Reply #3 on: March 02, 2015, 09:50:29 AM »
Definitely a real trend setter.
« Reply #4 on: March 02, 2015, 10:29:27 AM »
  I mean, where would stunt be without ripping off Chuckie? He also apparently can beam thoughts into people's heads,  since somehow we all managed to rip off *someone we never heard of until a few years ago* and has never done anything at all in stunt. I suppose that just makes his genius even more impressive!
    It's Charles' world, we all just live in it.
« Reply #5 on: March 02, 2015, 10:58:35 AM »
Brett,
 LL~
Sorry, this topic is locked. Only admins and moderators can reply.
