  • July 12, 2025, 06:38:37 PM
Author Topic: Must be Friday the 13th  (Read 948 times)
« on: July 13, 2007, 10:27:44 PM »
So, I'm out in the shop, minding my own business and just finishing up doing the rough sanding on the new plane. I was then filling in some small gaps at the rear of the elevator left with I made room for the horn. I probably should have been paying more attention, but I dribbled some CA on the little piece of filler balsa I put in the the little hole and managed to get it on the horn bearing. Now the controls and stiff (at least they aren't frozen). So I spent two hours trying to dig glue from arou the horn through the access hatch. I'm probably going to have to cut around the horn from the outside to fix it.
Man, what a pain. Must be Friday the 13th.
Re: Must be Friday the 13th
« Reply #1 on: July 14, 2007, 08:51:24 AM »
Randy,
that sucks, two steps forward one back,,,
good luck with that my freind, hope you can clear it without to much drama. However I have no doubt your surgical skills you will have it 100% n no time
now its off to the shop to work on a camaro, oh and bring my Vector home, got the fuse painted yesterday. Nothing spectacular just "fuel proofed" for the most part, didnt take a lot of time. will post pictures later if yoru interested
Its ok to go out to shop and work today,its not friday, nor the 13 anymore
« Reply #2 on: July 14, 2007, 11:49:44 PM »
Mark,
Yea, I finally got it cleared. What a pain. Controls are free again. Now, if I can just decide how I want to attach the cowls...
