  • August 03, 2025, 03:25:25 AM
Author Topic: Paint Stencils  (Read 3237 times)
Paint Stencils
« on: December 21, 2012, 12:41:41 PM »
For a long time, I have been ordering paint stencils from RG GRAPHIX.  Now, paint stencils come as a 3-part set-up. The backing is peeled off and the vinyl stencil is applied to the model.  Finally, a top paper is pulled off, exposing the vinyl stencil for spraying.  When dry, the vinyl stencil is pulled off.
RG GRAPHIX stencils work perfectly on a doped surface.
I recently ordered some stencils from a local shop.  They looked OK.  When it came time to pull off the vinyl from the dry sprayed surface, the vinyl didn't want to come off!  I tried a little heat from a hair dryer.  That only made the vinyl gooey.  Finally got the vinyl off, but it left a lot of sticky adhesive that didn't want to come off.  I had to use a combination of alcohol and 6000 grit sandpaper, and it still isn't completely smooth.
Moral of this story:  Get your paint stencils from a supplier that understands model work and butyrate paints!
\Floyd
Re: Paint Stencils
« Reply #1 on: December 21, 2012, 01:26:33 PM »
Floyd,
I don't mind if you call them stencils when they are not.  No harm in that, but professionals my be thinking stencils just for a bit.
Vinyl transfers are more preferred. No big deal.
Gotta be careful with heat, I supply vinyl graphics to scale model builders who actually use a "bit" of heat to burnish vinyl into wing stitching. Vinyl can be destroyed easily if heated improperly.
The "transfer paper" to which you refer, is available in a couple of contacts, heavy and medium. I always use medium when I send vinyl to modelers. Never had one complaint after 17 years of providing modelers with vinyl graphics and lettering.
Here's the thing and I'm surprised you weren't aware of it?
After the graphic is applied, the surface transfer or "release" paper can be wet. Wet it with a sponge! When it is wet, it looses it's adhesive abilities and is really easily removed. Falls apart, not like toilet tissue, but close.
Modelers with graphics on open bay wings take advantage of this trick. I always give up this information.
Yes, I would say most professionals know this also.
Adhesive residue. Easily removed without hurting the substrate if the proper chemicals are used. I use a special remover. 3M makes a product that is offered at automotive supply stores. Used for vinyl removal and the removal of vinyl pinstripes. Works like a charm.
I stay with all my customers right up until the last graphic is applied, helping in any way I can.
I've been a modeler my whole life. A very happy modeler!
Charles
Online Howard Rush
Re: Paint Stencils
« Reply #2 on: December 21, 2012, 02:34:17 PM »
Specify low-tack material.  The best I've seen is made by Avery.  I forget the part number.
Re: Paint Stencils
« Reply #3 on: December 21, 2012, 03:28:05 PM »
Howard,
You're correct, Avery makes great materials for that industry.
I don't get a brake in price from my distributor with Avery.
Transfer Rite is one of the brands I use. R Conform is another. I have stuff now my distributor says is their label?
Keeping in mind these are just transfer materials and get 'spent," my interest is a product that removes itself easily from the roll when it gets low on the tube. This is why I recommend that modelers, who elect to make their own vinyl graphics and lettering, ask sign shops for their short rolls. Most toss them anyway. When I lived up north I gave them to an art school.
I send mine to a few modelers who are making their own stuff with good results. Send out my vinyl scraps also.
I did a short Thread on doing your own vinyl. It's not as difficult as one might think.
Charles
Re: Paint Stencils
« Reply #4 on: December 21, 2012, 03:55:47 PM »
"For a long time, I have been ordering paint stencils from RG GRAPHIX.  Now, paint stencils come as a 3-part set-up. The backing is peeled off and the vinyl stencil is applied to the model.  Finally, a top paper is pulled off, exposing the vinyl stencil for spraying.  When dry, the vinyl stencil is pulled off."
Floyd wrote "stencils" when, to me, he clearly meant "masks", and I don't think there's any need to argue with either term. There was no implication of applying permanent vinyl trim, IMO. Read more carefully!   y1 Steve
Re: Paint Stencils
« Reply #5 on: December 21, 2012, 04:35:00 PM »
"For a long time, I have been ordering paint stencils from RG GRAPHIX.  Now, paint stencils come as a 3-part set-up. The backing is peeled off and the vinyl stencil is applied to the model.  Finally, a top paper is pulled off, exposing the vinyl stencil for spraying.  When dry, the vinyl stencil is pulled off." Floyd wrote "stencils" when, to me, he clearly meant "masks", and I don't think there's any need to argue with either term. There was no implication of applying permanent vinyl trim, IMO. Read more carefully!   y1 Steve
Steve,
A "stencil" doesn't come in a three part set up. That is, by it's true definition, meaning and use.
A stencil is something "entirely different." Like that line in the movie The Phoenix.  ;D
Google it.
Stencils were around and used, long before vinyl was introduced and used, in the industry which I make my living in, only for over 40 years.
There was a graphics guy, "Get Stencils." He might still be around. I'm not mad at him for reinventing the term. He could have gone by, "Get Masks." Masks is what he offered, not stencils.
There's a really big difference.
Now here's something interesting. One could make a "one time" graphic used as a mask and call it a stencil. Even out of vinyl. And they do. But it's really a mask.
Charles
Re: Paint Stencils
« Reply #6 on: December 22, 2012, 09:51:50 AM »
PJ, where's our definition of "stencils".   I was always taught it was a pattern that you use to cover the areas you didn't want painted the color you are going to use.   Go look at lettering stencils in the office supply.
Re: Paint Stencils
« Reply #7 on: December 22, 2012, 02:24:33 PM »
Perhaps the definition of "stencil" has changed since my military days.  These were re-usable plastic "things" you taped on a box, then rolled over with a paint roller.  Removing the "stencil" left the printing just as desired.
"potatoes", or "potatos" ?
Re: Paint Stencils
« Reply #8 on: December 31, 2012, 11:36:25 AM »
I use "spray mask" from signwarehouse.com. It is low tack and the surface has a matte finish so the paint sticks. This creates a very clean line when removed.
They also sell a "stencil film" that is very similar....
Derek
Re: Paint Stencils
« Reply #9 on: December 31, 2012, 12:01:30 PM »
I use "spray mask" from signwarehouse.com. It is low tack and the surface has a matte finish so the paint sticks. This creates a very clean line when removed. They also sell a "stencil film" that is very similar....Derek
Derek,
I don't know of any "mask" material that has a shine to it?
I prefer the yellow in color.
Charles
Re: Paint Stencils
« Reply #10 on: December 31, 2012, 12:46:51 PM »
When days were old and Knights were bold, and masks, stencils, stuff like that, wasn't really invented,  :##
We used rubber cement, in "some" areas, for our airbrush detailing.
I say we because, in most cases, I learned from talented others.
Of course until I progressed well beyond them.  LL~ LL~ LL~
That didn't take long!   ;D
Charles
Re: Paint Stencils
« Reply #11 on: December 31, 2012, 01:36:10 PM »
Derek,
Charles
I use to order my masks from a local vinyl shop and the mask material they had was shiny. I had to sand the edges to make the paint stick.
Derek
Offline Alan Resinger
Re: Paint Stencils
« Reply #12 on: January 20, 2013, 08:37:53 AM »
I use a product called Mac Mask made by MacTac.  It is by far the best of all the products I've used.  I get it from H & H Sign Supply.  The cost is about $3.50 a yard that is 24 inches wide.  I can usually unmask the paint in about 30 to 45 minutes when using Randolph dope.  I let it set for a day or so and then clean up the edges before starting clearcoats.
Alan Resinger
Re: Paint Stencils
« Reply #13 on: January 20, 2013, 09:23:36 AM »
Alan,
Nice work. Kudos!
Do you live in Canada?
My wife and I would take our Holidays in Quebec and Old Quebec, been there many times. They wash the streets!
MacTac, is a fine product. The best advantage is you can see through it, if it's still the same stuff?
No thinner than the more common products on the market and really doesn't give you a better edge.
Gallery artists, like myself, would use it on our stretched canvas for masking. Been a while since I've used their products.
Can you still buy that stuff by the foot?
I purchase whole rolls, not that brand, so I pay much less.
Mac was used on this image.
Charles
