  • June 16, 2025, 09:32:54 AM
Author Topic: Original Sterling Mustang CG?  (Read 2040 times)
Offline Terry Caron
« on: October 15, 2015, 07:49:59 PM »
Anyone have a measurement from the LE for the correct CG for the Mustang?
Thanks.
Terry
NACA member, Huntsville, AL
AMA 249824
NRA Life Member
Offline Terry Caron
Re: Original Sterling Mustang CG?
« Reply #1 on: October 18, 2015, 07:33:05 PM »
OK then - how about for the Brodak Mustang?  ;D
Terry
AMA 249824
NRA Life Member
Offline jim gilmore
« Reply #2 on: October 18, 2015, 07:59:21 PM »
In the absence of an actual location . I would start at about 3/4 of an inch behind the leading edge and add tail weight till it just gets a bit over reactive...going very slow with the adding. Somewhat nose heavy is a lot safer than a small amount tail heavy.
Offline Terry Caron
« Reply #3 on: October 18, 2015, 08:03:27 PM »
Thanks Jim - sounds like a safe way to start.  H^^
Terry
AMA 249824
NRA Life Member
Offline GregArdill
« Reply #4 on: October 19, 2015, 09:53:34 AM »
Terry,
I guess you're asking about the 38'' span version.
Hip Pocket forum has a CAD redraw of this version on its plan gallery. Shows the CG range.
Offline Terry Caron
« Reply #5 on: October 19, 2015, 11:02:52 AM »
Thanks Greg - appears to be ~1.5" to 2" from the LE.
Terry
« Last Edit: October 24, 2015, 02:40:23 PM by Terry Caron »
AMA 249824
NRA Life Member
