  • June 16, 2025, 11:44:02 PM
Author Topic: Brodak Oriental (profile) Wing jig holes  (Read 1795 times)
Offline Leester
« on: February 06, 2022, 03:02:41 PM »
Anybody have this kit and can tell me which hole position on the Brodak wing jig are used for the ribs ??? Thanks !! I have a home made jig set up for the next to the widest holes on the Brodak jig. Just wondering if these will work or do I need to make a new one. Thought I'd get a jump on it since my kit won't get here for several days.
« Last Edit: February 07, 2022, 09:51:00 AM by Leester »
Leester
ama 830538
Re: Brodak Oriental (profile) Wing jig holes
« Reply #1 on: February 07, 2022, 10:37:00 PM »
Leester,
Hmmm.  I was curious about your question since the profile Oriental I have framed up didn't use a wing jig. I just looked at the wing (refresher training) and can tell you that one the older, non-laser kit there are twin slots on both the left and right side ribs. Not really suitable for a rod-type jig in my opinion.
The latest ones according to the Brodak website are laser cut and may be different--set up to use rods. Either way, you can build it straight if you have a flat surface and a rear spar shim.
Maybe someone who has the laser cut version will chime in...?
Offline Leester
« Reply #2 on: February 08, 2022, 09:12:59 AM »
Dave, the lazer cut kits now have holes for the wing jig. The leveling bar system does work well but I prefer the jig system. Thanks
Leester
ama 830538
« Reply #3 on: February 10, 2022, 01:09:50 AM »
Good to know.  Thanks, Lee
Offline Leester
« Reply #4 on: February 10, 2022, 03:08:59 PM »
  Received the kit today And one of my jigs matched the pattern so I'm all set.
Leester
ama 830538
Offline Crist Rigotti
« Reply #5 on: February 10, 2022, 08:02:05 PM »
I'm watching!
