I've used it in my Pathfinders ARF...
Never had any problems at all, but for my Thundergazer, at first I was going to use it, then, some people said a few things and I changed my mind, and went with the old-fashion way. I'm powering this ship with one Enya 61 on a pipe, and the alu straps didn't seem Strong enough, or maybe they could bend with tightening and hold the engine just by the edges of the mount ears, like |I said, it didn't seem "right".
Oh, I just recalled the fact that to use a bigger engine in the Path's, like some Enya 45 and the ST 51, I had to grind the mounts wider, maybe 1/8 at each one for the engine to fit.
I'm sure you're not going to have any issues with the universal mounts.
One advantage is that if you crash, the mount ears don't break like they would with the bolts through them, and it absorbs the impact better as the engine can move back a little...
Don't ask how I got to know this...
Marcus
