  • July 06, 2025, 05:04:27 PM
Author Topic: Mo best wing  (Read 1821 times)
Online Fred Quedenfeld jr
Mo best wing
« on: December 09, 2020, 07:27:09 AM »
Have you built a Mobest wing
what did you use on your Mobest wing for leading edge and spars
thanks
Fred Q
Offline Perry Rose
Re: Mo best wing
« Reply #1 on: December 09, 2020, 01:39:52 PM »
I bought the kit from Mike Griffin laser cut by RSM. The plans show laminated leading and trailing edges that fit into notches in the ribs and 1/4 square for the spars. The designer used 1/4 square for the spars and 3/8 square for the leading edge, and 1/4 square for the trailing edge with 1/16 sheet over that. Pretty standard.  If you are scratch building one the flaps have an arc for the trailing edge. I tried to figure out the arc and it's about 10 feet. Maybe RSM would cut a short kit.
« Last Edit: December 14, 2020, 06:22:05 AM by Perry Rose »
