  • July 08, 2025, 07:08:02 AM
Author Topic: Mo Best Fusalage II  (Read 1201 times)
Offline Leester
Mo Best Fusalage II
« on: October 10, 2007, 12:47:31 PM »
Having finished the first fusalage Larry sent me new construction methods for the proposed ARF/ARC version.
This one is 3/8" sheet covered with 1/64" ply then the 3/32" nose doublers on top. It has lightening holes in the aft fus vs the built up aft section. The engine crutch and tank cut out are basically the same. It still has the rear weight hatch but tail wheel mount will be different.
Leester
ama 830538
Offline Crist Rigotti
Re: Mo Best Fusalage II
« Reply #1 on: October 10, 2007, 03:19:09 PM »
Looks nice Lee.
Offline Ken Deboy
    • Silk and Dope
« Reply #2 on: October 10, 2007, 03:20:14 PM »
Will it be offered as a kit as well? Or at least a rib set made available?
cheers,
There is a fine line between "hobby" and "mental illness"
Offline Leester
« Reply #3 on: October 10, 2007, 04:39:55 PM »
Not to speak for Larry or Brodaks but I don't believe a kit is one of the options. As far as ribs go you'd have to contact Brodak.
Thanks Crist.
Leester
ama 830538
Offline Leester
« Reply #4 on: October 12, 2007, 02:02:35 AM »
One side covered, now waiting for more ply.
Leester
ama 830538
