  • June 20, 2025, 01:42:23 AM
Author Topic: Melamine Top VS Glass Top Bench  (Read 966 times)
Offline Dick Pacini
« on: April 27, 2010, 12:42:16 PM »
I purchased a set of aluminum wing and fuselage jigs but they will need to be mounted on a melamine or similar material bench top.  I have read here where many builders use a glass top right over the plans to build upon.  That isn't possible without gluing the jig parts to the glass, which wouldn't allow adjustment.  It seems that one must make a choice between building over glass protected plans or jig building over the bench top.  Your thoughts will be welcomed.
AMA 62221
Re: Melamine Top VS Glass Top Bench
« Reply #1 on: April 27, 2010, 01:42:46 PM »
buildign on glass gives you a flat level surface to build OVER plans - if you are using jigs and fixtures, you do not need the glass, so long as whatever you are using to set the jigs up is level - relative to itself........if that makes sense
« Reply #2 on: April 27, 2010, 04:19:28 PM »
Dick,
I took a chunk of Melamine (1") and used a router to cut slots for my jig legs. I level the board with a laser level using shims. Once it's level I adjust the jig legs. Works.
Eric Viglione
« Reply #3 on: April 27, 2010, 09:23:23 PM »
If you do end up looking for glass... one tip is to find your local custom glass/window shop.
Most of them seem to have a free scrap pile out back. My current glass top came from that source, and it's a super thick double lamination of hurricane proof glass.
Price tag was still on it for $475.00 !!!  y1 Had one small chip in the corner, and my planes don't seem to care.  LL~
EricV
