  • July 30, 2025, 03:40:09 PM
Author Topic: Making stencils, instead of friskit  (Read 2406 times)
Offline brucefinley
« on: May 02, 2006, 08:29:29 AM »
I have use low and high tack friskit in the past--don't use high tack, too tacky!  The low tack is good but expensive.  I have found a product at Office Depot that has work well for me.  It is called Clear Cover.  Not really shelf paper, they advertise it as a book covering, document covering, etc.  I have used it with dopes and works really well.  And it is only $1.99 for 13.5" x 5 '. This product cuts very well with a number 11 exacto knife.   Sometimes you will get a bit of pull-away-shrink after the first coat of color if your surface is not really smooth and providing good adhesion.  I usually shoot two light coats of color and then quickly remove the mask.  That's my take, your mileage may vary........
Offline Ironbomb
Re: Making stencils, instead of friskit
« Reply #1 on: May 02, 2006, 12:17:57 PM »
A good tip, thanks, I'm gonna look for some  8)
Greg
Beating the crap out of the ground, one airplane at a time
Greg Bossio
AMA 834382
Offline Mike Clark
  • Lets get together and burn some fuel!
  • ACE
« Reply #2 on: May 02, 2006, 02:25:42 PM »
Thanks Bruce,
Well yes, Friskit paper is expensive as I have just found out, OUCH %^ %^ %^ %^!
However it is 24" x 4 yards and will fit nicely into my HP plotter. I'll draw out the stencile in Design cad, plot it and cut it out by hand. Hopefully it will go OK.
However next time I'll go to Office Depot and  try some clear cover.
Bruce, what mil thickness is your product?
Mike Clark
Mike Clark
Offline brucefinley
« Reply #3 on: May 02, 2006, 04:37:00 PM »
Hi Mike,
The Clear Cover has a paper backing.  The membrane itself is .003" and cuts nicely.  Got the Jetx OK, it was a gift for a friend.  Take care.
Bruce
Offline Mike Clark
  • ACE
« Reply #4 on: May 03, 2006, 06:16:27 AM »
Hi Bruce,
Well I am glad someone could use it, I hate to see anything go to waste!
Mike Clark
Mike Clark
