Building Tips and technical articles. => Building techniques => Topic started by: Igor Burger on June 10, 2014, 01:39:17 AM
Several people asked about making my logarithmic controlls. Most pictures are also on facebook, but for those not having account there, I will make thread about making controlls and how I build them in model also here. The first picture shows steel parts. They are new, while following pictures shows older parts, so do not be confused with little different look.
Openings are little bit undersized, so it will need little work with a file to make proper fit, especially for no-gap and no friction ball bearing fit in slot.
Making horns. I use brass tubing and soft steel 1/8" rods. Soldered with Ag4SN96. I think pictures tell all. If not, ask.
EDIT:
I wrote it in messages, but I think it should be here:
That shiny wire is silver plated brass or copper wire (I am not sure, it is from hobby shop for decoration).
The rod is copper plated soft steel (therefore that color).
Those materials perfectly soak melted AgSn solder with water based soldering flux for copper tubing (white gel stuff).
hole for push rod is then dilled or filed for proper pushrod fit after soldering
making logarithmic bellcrank ... drilled nut is for better stability
classic main bellcrank is done the same way
push rods
installation in fuselage
Thanks Igor. Great tutorial.
Larry
Hello Igor,
What is the benefit of your logarithmic controls?
Derek
Beautiful Igor! Thank you.
No doubt! His workmanship is incredible.
Derek
Igor, how do you make the bends on the control horns so close to the bushing tubes without distorting them ?
Do you have a picture of the tool or jigging you use ?
Don't you mean control rods? If you look closely at the rod in the vise, it's in a tube.
Also, the rods look to be brass and not steel, which would tend to make them more malleable.
Thanks guys :- ))
Derek: it helps to make rounds round and squares square :- ))))
Tim: no it is not brass, it is soft steel rod. (not hardened, no piano wire, simply soft steel)
Allan, the brass tubes are tight on rods without notable free play, so it is easily fixable and soft steel will bend easily. You can see clearly part of untouched metal segment (which was in tube and fixed during bending) and bent segment with clearly to see plastic deformation on those hooks for pushrods as Tim mentioned. It works nice. I add few more pictures showing just what you asked.
may be this is even better visible
I was thinking that just using a regular vise would have caused enough distortion on the bushings that they would no longer turn free on the horn wire. I guess the difference is you use a softer wire which bends with much less force than I am accustom to with bending harder wires.
And yet more informations - that shiny wire is silver plated brass or copper wire (I am not sure, it is from hobby shop for decoration). Mentioned rod is copper plated steel (therefore that color). Those materials perfectly soak melted AgSn solder with water based soldering flux for copper tubing (white gel stuff). Therefore it makes so pretty joints. And do not worry about soft solder strength, I tested one horn and picture shows that join is stronger then rod itself.
Yes I think so ... however fixing in wood does not work well, it will allow rod to bend inside the tube and then it does just what you described. Guess how I know :- )))
LL~
Very good Igor.
Derek
:- )))) ... may be funny, but true ... I wrote it some time ago in SN
If it's not obvious just looking at the mechanism, the flap moves more with respect to the elevator around neutral, and less as the elevator deflection gets high. This would give you more immediate response in altitude around neutral with less rotation, and visa-versa at high deflection. So for level flight and the rounds, it more or less shoves the airplane up and down without changing the direction of flight (much), while for high deflection it lets the elevator take over and actually rotate the airplane.
Nifty.
I know you did, I guess I should go back and read that article.
Derek
Nifty.
Well, you do not need to be limited to be "just looking at the mechanism" photographs above. Check out Igor's website at
http://www.netax.sk/hexoft/stunt/the_max_ii.htm
This graphically shows the flap/elevator response.
Great website by the way.
Thanks Keith,
I understand how it works now.
Igor, do you sell that setup and if so, how much?
Derek
Thanks Keith,
Derek
I was wondering the same here.....
Marcus
Yes kits are regularly available for 25 Euro (as seen on picture)
If necessary, I can also arrange custom building of all parts (all horns, properly set slot to ball bearing, 4 hooks for pushrods with proper fit to bushings), it comes usually 120 euro. It is almost day of work, but I would not miss that fun of bulding it myself :- )))).
Igor,
About the lever dimensions;
With a quick look at your drawing, it seems that when flaps are in neutral position, the distaces from center of ball bearing to both pivot points is the same. Is it so?
Lauri
no, it is 45:55
(http://www.netax.sk/hexoft/stunt/images/max_46_dev.gif)
