  • June 18, 2025, 05:47:04 PM
Author Topic: Transferring Laser Printer Drawings to Wood  (Read 2200 times)
« on: February 25, 2014, 02:46:39 AM »
A cool trick I learned here awhile back is that you can take something printed with a copier or laser printer, put it face down on a piece of wood, and transfer the printing to the wood by rubbing the paper with a rag with a dab of acetone or MEK on it.  This worked fine with my HP laser printer, but not with my Brother printer.  I am pleased to report that toluene works great with the Brother's toner.  This may not be worth posting, but it's a big deal for me.
Re: Transferring Laser Printer Drawings to Wood
« Reply #1 on: February 25, 2014, 06:29:35 AM »
There is time-honored technique of using a hot iron to transfer photo-copied plans to balsa.
« Last Edit: February 28, 2014, 07:43:18 AM by Paul Smith »
Offline Curare
« Reply #2 on: February 25, 2014, 06:48:21 AM »
This is also a tried and tested way of making balsa pretzels
Greg Kowalski
AUS 36694
Offline Mike Lauerman
« Reply #3 on: March 25, 2014, 03:27:18 PM »
Big deal for me too, Howard. (I also have a Brother printer) Tried the transfer method with a hot iron, nada. Dink. Zip.
Toluene sounds like the ticket. You have shot me out of the bag. Country music seems to have that word in it...
Livin' in Toluene time,
Livin' in Toluene time;
and:
Toluene, Toluene; Toluene, Toluee-ee-en,
I'm beggin' you, please don't take my man...
Yeah!  It oughta work!
Offline Curare
« Reply #4 on: March 25, 2014, 04:10:49 PM »
I use el cheapo lacquer thinners too. Not sure if that's available in all the states of the US though.
Greg Kowalski
AUS 36694
Offline Phil Krankowski
« Reply #5 on: March 25, 2014, 08:18:31 PM »
If it is a printout, I kinda prefer scissors and those new "no-bleed" sharpie extra fine pens.
If a full size plan, or you need to copy many times, go to the fabric store for some template plastic.  Use the same sharpie to trace onto the plastic, then scissors, and trace to wood.
I won't do plywood templates again for how easy this plastic sheet is!
Phil
Offline Doug Moon
« Reply #6 on: March 26, 2014, 12:32:54 PM »
My wife and I tried a wood burning tool made for this very thing.  We went to a printer shop and had copies made on a laser printer but never could get the image to transfer.  Not even a mark or anything.  What gives??
Doug Moon
AMA 496454
Dougmoon12@yahoo.com
« Reply #7 on: March 26, 2014, 01:53:03 PM »
I print my part (inkjet, copy paper), then cut out oversize, spray the back side with 3M Spray mount, and stick it to the wood.  Then I can rough cut the part with the scroll saw and zip it down to the line with the disk sander.  Then the pattern can be peeled off and filed for reuse or tossed in the trash.  Makes for very accurate parts, assuming the plans are accurate.
Offline Allan Perret
  • Proverbs
« Reply #8 on: April 20, 2014, 06:11:19 AM »
Will this work with inkjets also ?
Allan Perret
AMA 302406
Slidell, Louisiana
