  • June 19, 2025, 01:17:54 AM
Author Topic: 35 size Flight Streak Lead Location?  (Read 1019 times)
Offline BillP
« on: November 28, 2013, 10:55:47 AM »
Can anyone give me the measurement at the wing tip for lead outs on the 35 size Flight Streak? Its an original Top Flight, not a Brodak. Inches from the leading edge or spar would be great.
bp
Bill P.
Offline Phil Krankowski
Re: 35 size Flight Streak Lead Location?
« Reply #1 on: November 28, 2013, 11:28:23 AM »
http://www.outerzone.co.uk/plan_details.asp?ID=2652
I measure 2 3/8 on the rib for the reprint of the top flite plan.  The CAD redraw measures 1 7/8 at the same position, in the file I linked to.
This measurement is on the rib.  I can extend the LE line and measure at edge of the wingtip if you need.
Hope this helps.
Phil
Offline BillP
« Reply #2 on: November 28, 2013, 03:12:52 PM »
Your info works for me.
Thank You,
Bill P.
