  • July 16, 2025, 12:07:48 AM
Author Topic: Lightening holes in profile fuse - worth it?  (Read 9323 times)
« on: March 01, 2021, 02:55:49 PM »
Rebuilding a profile fuse and looking to save some weight. This will be full electric so no full length hardwood motor mounts  but it will still have plywood doubler on the nose. I am thinking about using a 3/8" core and laminating 1/16" cross grain on each side to get to 1/2" and have some stiffness. I am considering cutting lightening holes in the core and wonder if this really saves a significant amount of weight? The core is medium balsa and weights around 1oz. What has been the experience of the group?
Update: I just weighted the piece that I cut out for the wing, it weights 3.3gm (just under 1/8 oz.), the whole core weights 25gm (0.88 oz.). Not sure it is worth it but it might save the weight of the laminating glue?
Best,     DennisT
« Last Edit: March 01, 2021, 03:30:18 PM by Dennis Toth »
Re: Lightening holes in profile fuse - worth it?
« Reply #1 on: March 01, 2021, 04:46:44 PM »
Dennis,
If you think you have a heavy model have at it. A hole weighs nothing. What was in the hole has weight.
The more holes you make the more weight is removed and the model gets lighter. "Science."
Best kept secrete in the Forum is this Build. And boy, did I ever make some holes! ;D
You've seen the finished model, comes in around 54 oz, tank, engine and finish included.
Here's the build,
https://stunthanger.com/smf/cfc-graphics/'mig-3-reconnaissance-aircraft-and-warbird!'/
Holes start around page 3 or 4.
« Reply #2 on: March 01, 2021, 05:05:46 PM »
Not really related to weight savings for holes in the nose of a profile fuselage, but I sometimes wonder if lightening holes are worth the trouble.
Next time you assemble built up wing with cut out made in the ribs.  Weigh the rib before and after the holes are made.  The material removed from the holes does not weigh very much.  Yes, a gram saved here and a gram saved there adds up, but those cutouts do not make much difference.  More weight can be saved by simply using lighter wood.
« Reply #3 on: March 01, 2021, 05:34:12 PM »
   Making holes in balsa wood after the fact doesn't really safe a whole lot and you might be surprised at how little it saves. If a hollow structure is designed to be that way and has proper structure it can still be light and quite strong and resist twisting. Like Keith points out, better wood selection is a better option if possible, but if you are using a kit supplied piece of wood and have no other option, keep the wing/engine section more solid and sand the aft section a little thinner. Drilling and cutting holes interrupts the grain and that is most of the strength. If you cut a bunch of holes then you have to cover them with something else and you are just putting weight back on with that wood and the required glue.  You build in lightness right from the start. It's almost impossible to take away significant weight as an after thought. You are better off trying to save some weight with the finish by keeping it simple and not so busy.
« Reply #4 on: March 01, 2021, 07:03:54 PM »
If you cut large holes in the tail area, consider:
--You will need ribs or truss structure to support any external skins. They need to be sized to handle buckling loads (compression induced bowing) Gluing to the overlying skins prevents buckling until the glue line fails or the wood crushes. Thinner and harder internal struts might be considered better if well glued to the skins
--If you choose to leave out the wood skins, then be aware that the covering is now supplying much of the stiffness. Or, the stiffness removed is not actually replaced if the modulus of the finished covering is poor. However, I've seen some pretty "holy airplanes" that performed way better than I expected them too. Around here, Tim Meeks was a proponent of this kind on construction, I believe.
--If you leave out the wood skins, also be aware that people handling your plane will have to be advised, repeatedly, where they can hold it. Or you will get holes. An after the fact, unintended holy airplane. Trust me on this one....
--Orienting balsa skins with the grain pure fore/aft direction may improve the lateral stiffness and help avoid tail whip, but it is not as good in torsion. If your plane handles corners funny, ask someone to watch from behind as you pull out of a square corner. Does it have pronounced stab tilt? How much is it interfering with your trim? If memory serves, when you twist the fuse you will get some max stress aligned at 45 degrees to the longitudinal axis. (Balsa is a non-isotropic material. Stronger and stiffer along the grain. In composites, they layer uni materials to take advantage of that. You can also do it with wood. That's why plywood is so versatile.)
--The best way to figure out a building style is to keep weighing everything and keep records. Build it one way, but compare what you likely would have gotten the other way. I've done some studies like this and as Keith pointed out, you can get pretty fancy and not save much. Worse, you can get fooled into using more zoot, like carbon fiber pushrods and such when they are not needed and simply get heavier. Weight is a touchy subject, especially during the design of full scale aircraft where careers are at stake. Just ask any Mass Props guy....
The Divot
« Reply #5 on: March 01, 2021, 10:57:43 PM »
Before you start saving weight consider where you are saving it and how you build.  If you build nose heavy then saving weight in the tail only means adding it back in the form of lead later.  Opposite is just as true.  Only place saving weight is neutral is in the center.  I once thought that the lightest plane possible was going to be the best plane possible until I built two pigs that outperformed all of the feather lights I had built in the past.  We are no longer limited by the vertical lifting weight of a Fox 35.  Twist in a profile fuselage will do more pattern damage than the extra ounce or two you saved by cutting holes.  If you want it light you are going to have to use a built up profile.   Some of you out there will remember giving me that exact advice, well you were right.   I am not against cutting holes, it is where you cut them.  I still grind away everything that doesn't add to strength so that I can beef up areas that commonly fail.
I am probably in the minority - Ken
Offline Gerald Arana
« Reply #6 on: March 02, 2021, 07:56:36 AM »
Dennis, Short answer.....................No!
See Ted's post about his ultra light (Can't think of the name) plane that he added weight to before it would do a decent corner.
If I can think of the name, I'll post it. Jerry (Got old timers!)
Ah got it! "Tucker Special"
« Last Edit: March 02, 2021, 07:14:22 PM by Gerald Arana »
Offline Serge_Krauss
« Reply #7 on: March 02, 2021, 12:52:54 PM »
First off, you can compute your weight savings, if you know the density of your chosen fuselage blank, but weight savings is not the whole story.  I have cut out sections from behind the wing's trailing edge of 1/2" balsa and used 1/16" balsa laminations to complete the 5/8" thick box, without going quite to the accepted extreme of just using balsa strips for the fuselage outline. The 1/16" sheet butted against 1/16" ply nose doublers for a smooth surface. I did not bias the 1/16" balsa grain, but used biased-weave, .56-oz fiberglass over it in finishing. Then with diagonal truss pieces in the cutouts, the structure was amazingly stiff in torsional loads, while saving some weight. I did keep track of the weights of all parts, as construction proceeded, but I don't have those notes anymore. My purpose was more to achieve the structural stiffness, than save weight, but with this structure and a slimmed down profile, I saved over four ounces in overall weight over my original P-Force fuselage. The opening was only a small part of that. The stiffness is what counted for me.
Online Howard Rush
« Reply #8 on: March 02, 2021, 01:37:43 PM »
Dennis,
Here's the build,
Wow.  That airplane has enough holes to fill the Albert Hall.
« Reply #9 on: March 02, 2021, 01:37:53 PM »
OK, I tried it. The fuse core with only the wing section cut out weights 25g. After adding holes through the back and bottom I saved a whopping 3g. It took about 20 mins to do as I had to clean out the hole saw after every 2 holes were cut. I hope this save at least half the weight of the glue for the 1/16" overlays to bring me up to 1/2" total (didn't have 1/2" in stock). The ship is using a fairly light power package that on the original fuse was bordering on tail heavy so a little lighter back there won't hurt.
For the overlay what glue have you used? I was thinking of doing the card-scraped expoy method like putting on wing skins.
Best,   DennisT
« Reply #10 on: March 02, 2021, 05:12:10 PM »
Best,   DennisT
Dennis,
You could dope some glass cloth on the fuselage eliminating the 1/16.
.75 or something a bit thicker.
Remember, you'll have to put something over the 1/16 anyway.
Finish it without the 1/16.
I'd leave out the 1/16 but that's me.
Charles
« Reply #11 on: March 02, 2021, 06:07:37 PM »
Dennis, I've done this a couple of times, and had good results using the card-scraping epoxy method, only with Sig-Bond.  Things that folks will tell you will happen are, (1) the glue will never dry, (2) your fuselage will warp up because of the water in the glue, and (3) it'll be heavier because of all the glue.
As to (1) -- I build slow.  If you're going to glue it today and cover it tomorrow, use epoxy!  I'd give it at least a week for the water to wend its way out of the 1/16" sheet.  As to (2), put it on something flat and weigh it down.  I've taken to building on glass (1/2" thick), but this works on a regular ol' building board.  I did have one fuselage come out warped -- and it un-warped by counter-warping it with 1" thick blocks at each end and a weight in the middle for a day or two, whereupon it released to flat.  As to (3), don't use much glue.
I've got a plane with well over 500 flights on it, including some not-too-bad-for-a-profile flights in Expert (and it's the one that got warped and was corrected), so I think the method's OK.
« Reply #12 on: March 02, 2021, 08:54:18 PM »
I'm with the Timmer on this.
An appropriate amount of TiteBond (original), which I like to thin with water, applied with a brush gives good penetration. It will dry out just fine if let sit for a few days. Thinning the glue does a couple of things: it increases the open time of the joint, and allows you to more easily control the amount of glue which is the weight left behind after drying.
Just lay it out flat (in my case I was using a forming jig) and let it thoroughly dry. No warps. And much more stable than a single piece of wood that goes thru humidity cycles (or rain), or heat cycles. Just like air-drying lumber cut from standing trees, you should allow air to pass all around the wood to let it come to equilibrium with your shop humidity. A layer of fabric does a pretty good job here. You need something if you are working over a glass tabletop. And don't do this over a cast iron table saw top. You won't like the rust damage as the moisture comes out.
In my experiments with laminated elliptical leading edges, I was very pleasantly surprised how little weight was added by this gluing method. No strength appeared to be lost. (Refer back to the old "the wood will fail before the glue" logic.)
The Divot
Online Mike Griffin
« Reply #13 on: March 02, 2021, 10:19:11 PM »
For what it is worth, I never bored holes in a profile fuselage, flaps, stab etc etc.  I built several of Pat Johnson's designs which have framework and the core is 1/2 Styrofoam and sheeted with 1/16 balsa.
They were incredibly light and straight.  I think we get a little OCD about weight sometimes.
Sorta like chasing the 16 ounce Ringmaster.  I built many in the 24-26 ounce range and they flew good for a Ringmaster and i never bored a hole in any of them.
But i defer to the Ringmaster GOD Joe Gilbert.
« Reply #14 on: March 03, 2021, 08:16:02 PM »
If one uses the epoxy scrape method to laminate the wood do you apply a coat of dope to both surfaces? Does this reduce the strength of the joint? I read the Hunt article on laminating the molded leading edge caps he didn't indicate that they are using any dope or scraping off of the Z-poxy finishing resin.
Best,   DennisT
« Reply #15 on: April 05, 2021, 02:11:49 PM »
I finished laminating the 1/16" cross grain balsa to the 3/8" fuse core (with holes) using the finishing resin. The first side I did the brush and scrap but really didn't get much off. On the second side I just brushed it on smooth but thin and add the cross grain wood. Both sides seemed to be on very solid but I had one piece on the first side that didn't adhere well so I needed to apply a bit of resin to get it down solid. Now that is has cured the fuse is 1.6 oz. It is very very stiff.
Has anyone tried using gel CA for laminating? Just interested?
Best,   DennisT
« Reply #16 on: April 05, 2021, 03:51:50 PM »
Drilling holes is a waste of expensive balsa and it makes a mess and the grain ends up wrong.
It's better to build a truss and cover it with sheet wood.
« Reply #17 on: April 06, 2021, 03:14:58 PM »
I wouldn't make any lightening holes, especially on larger-.40 + size profiles.  Fuselage twisting aft and vibration issues forward can be hard enough to deal with as is.  In a couple of cases I've had to strip off the finish and fiberglass the fuselage to eliminate vibration issues causing bad engine runs.  It's pretty difficult to build a profile over weight.  You aren't starting with much balsa anyway.  I'd prefer to use balsa that is pretty stiff, then covering it with a layer of carbon to minimize stab twist in the wind.
« Reply #18 on: April 06, 2021, 05:35:33 PM »
I vote YES.  Strength comes from the outside surface., If you drill holes, you remove weight which doesn't add to stiffness.  Covering the core (holy core) with 1/16" sheet provides greater stiffness than a single plank would offer.  You end up with slightly more weight, but that is easily offset by using lighter wood all around.
« Reply #19 on: April 06, 2021, 06:00:48 PM »
  If you were able to add up the weight of the material you drill out I think you would be disappointed. Everywhere you drill a hole, you interrupt and sever the wood grain and remove a lot of strength doing that. When you g to spread epoxy over the structure, you wipe epoxy into those holes and unless you go to great measures to some how remove it, you just replaced what miniscule bit of weight you drilled out. I think better wood selection in both weight and wood size and proper construction techniques is a better way to go.
  PS to add: If you think strength comes from the outside surface, which some call a monocoque (my spell checker doesn't know how to spell it correctly either!!) type of construction, but a square or rectangle shape doesn't lend itself to that very well. I think you are better off have each piece in the construction doing it's fair share of carrying the load. That way the strength in the fuselage is the sum of it's parts.
Offline mccoy40
« Reply #20 on: April 13, 2021, 10:42:48 AM »
I use the built up truss method. Not because of strength or lightness but because of cost. Oh  and availability.    It is very hard ti find 1/2 inch sheets around here  - I use 1/4 and cover with !/8 inch sheet. I am also going to try 1/4 with 1/16 by 1/4 cap strips with 1/16 inch sheet soon.  y1
I'll crash compare the relative strength of each and get back to you with the results.   <= %^@
Joseph Meyer
Philadelphia, PA
Offline L0U CRANE
« Reply #21 on: April 16, 2021, 03:00:51 PM »
Might glance at my reply #4 to the Wing Sheeting thread...
The method of laminating sheeting to structure  puts glue only at glue-joints. That can be a weight savings.
Cure of white or yellow glues is quick and certain.
Balsa is expensive. Much less is wasted in cutting useless holes.
\BEST\LOU
Online Howard Rush
« Reply #22 on: April 19, 2021, 03:05:34 PM »
I have nothing to offer, but it's good to see "lightening" spelled correctly.  Onward to "lose" and "loose".
Dan spelled "monocoque" correctly.  I should know this because I have only one myself.
Offline John Carrodus
« Reply #23 on: May 22, 2021, 03:34:25 PM »
Dave Hull put his finger on it....er...um - through it maybe! I have used copious holes of various sizes and shapes wherever I see wood that is redundant. This can make a significant difference at the end of the day, especially if you have to mess around adjusting CG with weights on a finished model. I always point out to anyone handling the model to "No touch" areas.- usually on the rear fuz. I don't cover holes with thin balsa, I use silkspan or shrink wrap. I have also lightened tail surfaces, elevators and flaps, but only where there results no loss of rigidity.
« Reply #24 on: May 22, 2021, 07:09:08 PM »
John,
I enjoyed reading this.
You should read my Threads or Builds where I use the removal, "removal," an important word, of wood material, using various size holes.
As you well know, it works wonders.
CB
« Reply #25 on: May 22, 2021, 07:31:03 PM »
 LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~
Good one Howard!
Jerry
« Reply #26 on: May 22, 2021, 08:09:25 PM »
I have mixed feelings about removing wood in the aft fuselage.  For years I have carved out the sides, Nobler style.  On my last ship I had all of the holes cut and the stab mounted when I was admonished by my flying group that it was a mistake.  The plane felt strong and the stab didn't want to move any more than normal but I caved to the group pressure.  But before I glued the cutouts back I clamped the fuselage in a vise and measured how much the stab moved (twist).  Glued them back in and measured.  At least half of the twist was gone.
Another benefit was that I almost always end up nose heavy and have to add lead in the tail.  Why cut out balsa only to replace it with lead?
The rest of the plane is fair game.  If it is internal and not load bearing, it still goes but I am beginning to question this whole fetish we have with light planes.  Isn't the real goal wing loading vs power?  A Fox 35 on the 2 of a 4-2 setting would lift a 42 oz Nobler if held pointed straight up.  A Cobra 3520 will literally pull a 65oz plane from your hands if you let it.  Wing loading on the Fox was probably around 11-12.  The Cobra was lifting about 13 and could probably handle 15-16.  I for one have stopped worrying so much about weight and more about design.
Just me and I could be wrong - Ken
Offline kevin king
« Reply #27 on: May 30, 2021, 10:52:14 PM »
The short answer? NO no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no no. And....no.
Offline Warren Wagner
  • Bradenton, FL
« Reply #28 on: May 31, 2021, 10:43:26 AM »
Hi gang,
I'm in the process of building a Fancher "Imitation" kit that was produced by Mike Griffin.  My main consideration
was to make the rear of the fuselage as 'twist resistant' as possible....any weight reduction would be a bonus.
The plans called for 1/8" x 38" geodetic stringers in the open bay.  I used firm wood here, and used CA glue get
a rigid joint.   Also use 30 minute epoxy for adding the 1/16" skin applied at a small bias.
When I get to the finishing stage, I will cover the entire fuse with carbon veil.
My conclusion:  It does appear that this structure provides for a more "twist free" rear section of a profile fuselage
(purely subjective).
When the model is complete, I have a Prowler that I can compare it to.   The Prowler twists so much that you can
see it during flight, so my money is going to be on the Imitation.  <g>
Cheers.
Warren Wagner
Warren Wagner
AMA 1385
« Reply #29 on: May 31, 2021, 01:11:17 PM »
Sandpiper Trifecta just prior to adding the side sheet.  There is virtually no twist once the glue dried (titebond).  Unless it is a kit and you have no choice, it is good to remember that the profile rules allow for a 3/4" width.  When using an internal "geodetic" structure that extra 1/8 - 1/4" width really makes a difference for little in weight gain.
« Reply #30 on: May 31, 2021, 02:13:19 PM »
   Now remember, you are injecting a rule that doesn't exist except for AMA C/L Profile Scale. There are no official C/L stunt profile rules unless you are trying to meet some local contest rules.
« Reply #31 on: June 01, 2021, 08:55:46 AM »
If you sheet it with 1/64" plywood it can be even 1/2" thick and be extremely stiff. Tom Morris built profile fuse's this way and they are very stiff strong and light.
Best,   DennisT
« Reply #32 on: June 01, 2021, 12:33:43 PM »
The only "rules" we go by here center around the Thumb.  I have never seen anything DQ'd locally and I have never seen anybody trying to stretch the rules here either.  If it has a thin flat fuselage, exterior controls and an exposed engine it is a profile.  My use of the 3/4 was only to illustrate that the wider you can make the internal bracing the less it will twist.
« Reply #33 on: June 07, 2021, 02:42:38 PM »
Strangely missing in this thread is a discussion of the "goal" of reducing weight by tiny fractional amounts...other than winning the lightest airplane trophy.
How light is light enough?  Can a stunt ship be too light?  What would the line tension be on a zero ounce Ringmaster at five second laps on Dad's good old 60' eyelet to eyelet set of lines?.  At five second laps how much line tension would be necessary to displace the zero oz Ringmaster's big elevator against the airloads at 50 or so MPH?  Where would that line tension come from? What angle of attack would be necessary to fly a loop on a zero ounce Ringmaster?  How well, at that angle of attack would the angular relationship of the zero ounce Ringmasters fuselage match the flight path of the rule book loop...especially at the intersection of round eights...of which we have bountiful numbers?
etc!
The "answers" to these (yeah, I know) "silly" questions were pretty much the bottom line results of our experiment with "adding" weight to the "very" light when naked Tucker Special that Brett and I have addressed numerous times on Stunt Hangar.
Truth be told, in my experience as power train development has accelerated and "control" of that power source's "form" as it is delivered to the airborne air-frame the ratio of porkers to feather weights in the winners' circles has pretty much tilted in favor of the more "developed" approach...something like the ultimate merits of "Marilyn (in my day) versus Twiggy" in the sales of Playboy mags      y1 y1 Z@@ZZZ Z@@ZZZ.
On the other hand.........
Just being a Smart A$$ guys.  But it doesn't do any arm to consider some of that stuff and, as a result, balance where we utilize our available time at the work bench.
« Reply #34 on: June 07, 2021, 03:01:53 PM »
To even make that comparison you have identified yourself as "multiphobic"  That ringing sound you here is your neighborhood WOKE representative at your door.  ~^   It will probably not know who either of them were. LL~
ps.  To your point, IMHO it is the power to weight ratio along with wing loading/lift that matters.  If those are right and the plane weighs 10 lbs it will fly a decent pattern.  We needed planes to be light when the Fox 35 was king of the hill because it had to practically lift the dead weight of the plane through the last "loop" of the square 8 on a calm day.  Not so today.
« Reply #35 on: June 07, 2021, 03:52:09 PM »
Maybe one of those feather weight stunt ships would be suitable for the zero stroke engine that I once saw a picture of.  (Really, there was a picture of it in one of the magazines years ago.)
I am not sure of the technical problems here, but maybe almost limitless RPM.  Probably need a very low pitch prop, like 0.1" pitch.  Fuel usage is unknown but should be very very low, so would only need a very very small tank.
« Last Edit: June 08, 2021, 11:19:35 AM by Trostle »
Offline Chris Wilson
« Reply #36 on: June 08, 2021, 09:09:23 PM »
Drilling holes in an existing structure is simply correcting mistakes at best and ruining it at worst.
If you want it lighter then build it that way from the start.
Chris.
MAAA AUS 73427
Offline mccoy40
« Reply #37 on: June 29, 2021, 08:07:52 AM »
Someone, Somewhere, said that the weight of the plane should be less than the displacement of your engine.
Allen Brickhaus or Tom Dixon, I'm not sure which, or if the were repeating it from someone else.
I think this is a good rule to go by.
I try to get my ringmasters, flite streaks, etc to come in at two pounds or less. 24 ounces is ideal, 28 is what I typically end up with.
It seems to work for me.
Now if I could somehow lighten them enough to not crash from pilot error ......     HB~>
Joseph Meyer
Philadelphia, PA
