  • July 04, 2025, 02:38:48 PM
Author Topic: Reinforcing a Leading Edge  (Read 1626 times)
Mike Griffin
« on: April 01, 2014, 10:33:52 PM »
Which would provide the most strength on a leading edge....glass cloth applied with resin or Carbon fiber veil applied with dope?
Re: Reinforcing a Leading Edge
« Reply #1 on: April 03, 2014, 04:28:54 PM »
I avoid resin because it is just too hard to scrape, sand, scrape, sand.  Usually, I get good strength with carbon veil and dope, or else thinned out Ambroid.  It doesn't take much surface stiffness to really improve things.
« Reply #2 on: April 03, 2014, 07:18:29 PM »
If you are talking about the leading edges of Eric's kits,  I see nothing weak about them if done the way he shows.   I know some will probably hog out material they think is not necessary and then wonder why the wing folded on a really hard corner or a hard bounced landing.
Offline Kim Doherty
« Reply #3 on: April 03, 2014, 08:07:59 PM »
Did someone forget the spar thingamajiggy???
I would focus my efforts there.
Kim.
« Reply #4 on: April 04, 2014, 05:29:01 AM »
Hi James,
From a pure "strength" standpoint, the glass cloth and epoxy is the winner by a good bit.  If you are not going for all out strength, CF and dope does add some strength, but mostly it gives you a harder surface than silkspan and dope.
BIG Bear
RNMM/AMM
Mike Griffin
« Reply #5 on: April 04, 2014, 06:17:16 PM »
Bill that was the answer I was looking for.  Thank you.
Mike Griffin
« Reply #6 on: April 04, 2014, 06:20:50 PM »
Hi Doc
I was not referring to the Ringmaster.  Just asking a general question about the two materials and their strength comparison.  I have lost count of the number of RSM Ringmasters I have built and flown and NEVER had a wing even crack on one.
