  • July 15, 2025, 08:21:07 AM
Author Topic: Leather Fillets  (Read 2175 times)
Offline Darren James
Leather Fillets
« on: August 06, 2020, 09:07:47 PM »
I have some questions on leather fillets.
1. What kind of leather are they made from? I assume it is "veg tan" (not "chrome tan", as it forms and glues nicely. (Veg tan is the unfinished leather, chrome tan is the colored, softer stuff).
2. Are they a triangular cross section?
I ask because I do leather work and have lots of thick veg tan which can be cut to a triangular cross section to try out. I cut a sample (just under 1/2 across).  I understand one can order it from some tool making suppliers but I thought I would have a go at making my own
Thanks!
Darren
MAAC #22730
Re: Leather Fillets
« Reply #1 on: August 06, 2020, 10:45:21 PM »
Thanks!
Darren
Are folks still using leather?  I haven't used them since the 60's.  Too heavy and too flexible.
Offline Norm Furutani
Re: Leather Fillets
« Reply #2 on: August 07, 2020, 12:11:41 AM »
While going to college I also began an apprenticeship in a foundry pattern shop. So one of my jobs was to add fillets to the wood patterns. They were either wax or leather. I believe the leather fillets on stunt models are  the same as the pattern fillets. They are still used and available, see: https://www.freemansupply.com/products/foundry-tools-supplies/freeman-leather-fillets
In the catalog photos, you can see the fillet inner faces are slightly concave. The result is the finished fillet is radiused in shape and not triangular. Both the wax and leather were shaped with a polished steel ball ( like a ball bearing) welded to a steel handle. In either case, the ball was heated with an alcohol lamp and the fillet was burnished to shape. In our shop we used aliphatic glue on the leather. The fillet stock came in many sizes.
To finish the patterns, they were shellacked then lacquered.
Norm
Re: Leather Fillets
« Reply #3 on: August 07, 2020, 07:50:33 AM »
I will try this safety skiver knife- it has a radius built in.
MAAC #22730
Re: Leather Fillets
« Reply #4 on: August 07, 2020, 10:00:02 AM »
I would order from Freeman but they have a $250 minimum order (for international, I am in Canada ☹).
I found this place as well, which sells by the foot:  http://www.filletexpress.com/store/c1/Featured_Products.html
For now, I will try to make some.
MAAC #22730
Re: Leather Fillets
« Reply #5 on: August 07, 2020, 05:15:57 PM »
Awhile back, one of the CL suppliers past away and his wife was selling fillet material. Maybe that rings a bell?
Norm
Re: Leather Fillets
« Reply #6 on: August 15, 2020, 08:28:25 PM »
Bob Sawyer sold leather fillets in small quantities.  His widow is/was selling the inventory.  This e-mail is old, but hopefully OK
Estelle Sawyer  degs@earthlink.net
Offline Steve Dwyer
Re: Leather Fillets
« Reply #7 on: August 20, 2020, 06:42:37 AM »
This topic has come up before. I cannot see leather used as a fillet if it's intended where the wing meets the fuse. I go back to the late 50s as a youngster and have never seen it used even by the expert builders of the time. Was the fillet glued in place and then filled with a filler or covered with a fabric? Can anyone produce some photos?
Re: Leather Fillets
« Reply #8 on: August 20, 2020, 10:45:59 AM »
I have been using leather fillets on many of my models since 1948, when I built two JC Yates "Madman" from kits.l  The kits supplied leather fillets.  I do not cover the fillets with silkspan or silk.  They accept all of the usual model finishes.
This is how the fillets look, just prior to covering.
Offline Steve Dwyer
Re: Leather Fillets
« Reply #9 on: August 28, 2020, 06:47:37 AM »
Thanks Floyd,
Seeing is believing, they actually don't look half bad.
