  • June 19, 2025, 10:33:10 PM
Author Topic: Joining laser cut fuse sides.  (Read 1270 times)
Online James Mills
« on: July 20, 2010, 04:54:14 PM »
 I have a set of laser cut fuse sides and am wondering what is the best way to join them and not have the glue joint show through the finish (CA, epoxy, elmers)?
James
AMA 491167
Re: Joining laser cut fuse sides.
« Reply #1 on: July 20, 2010, 05:32:17 PM »
James,
personally, I would use Titebond to join them, though I have used CA before, but it isnt recomended by all , if you are a little messy with it, it CAN cause some finishing issues,,
« Reply #2 on: July 20, 2010, 06:38:32 PM »
James,
  Better triple-glue that thing  - the end grain is going to really soak up the glue, no matter what kind is used.
« Reply #3 on: July 20, 2010, 08:06:36 PM »
Good point Brett, I might even think about a thin doubler on the inside just cause,,
Offline Leester
« Reply #4 on: July 21, 2010, 06:40:42 AM »
James :! :! how about some pictures of that bad boy when you get a chance, or a building thread. y1 y1 y1
Leester
ama 830538
Online James Mills
« Reply #5 on: July 21, 2010, 07:39:37 AM »
Will do, will be a few weeks yet.  I'm putting my Formula S together (hope to finish before we leave for Denver tomorrow) and then wrap up the Legacy.
James
AMA 491167
Offline Allan Perret
  • Proverbs
« Reply #6 on: July 22, 2010, 06:25:50 AM »
Epoxy has little to no shrinkage, but I think this issue is more related to your finisihing process.   If the joint is block sanded flat and you cover with silkspan, it should not show thru.  Glue choice does have some effect on this, but a tight joint with a minimun glue line is more of a factor in how much it will show thru.  I use Titebond or Elmers wood glue.
« Last Edit: October 22, 2010, 07:12:32 AM by Allan Perret »
Allan Perret
AMA 302406
Slidell, Louisiana
