Building Tips and technical articles. => Building techniques => Topic started by: Vincent Corwell on December 19, 2010, 02:42:14 PM
Title: Leadout & bellcrank construction ?
Post by: Vincent Corwell on December 19, 2010, 02:42:14 PM
Im looking for a pictorial of leadout end to bellcrank using 1/16" tubes, and the
external end of line wrapping the thimble
anybody have a link please ?
Thanks to all who read
Vincent
Title: Re: Leadout & bellcrank construction ?
Post by: Alan Buck on December 19, 2010, 03:18:28 PM
Vincent, try www.Tulsacl.com  web site for gluedubbers they have a very good site with links on bellcranks you are looking for
Post by: Lee Thiel on December 19, 2010, 08:27:36 PM
Here is a link that will get you right to what your looking for.
http://www.tulsacl.com/Bellcrank.html
Lee TGD
Post by: ray copeland on December 19, 2010, 09:12:42 PM
Is the tubing 1/16 od annealed copper? Oh yeah, where is the best place to buy annealed 1/6 od thru 1/8 od copper at a reasonable price?
Post by: Bill Little on December 19, 2010, 10:17:30 PM
HI Ray,
I always heat the brass tubing with a little butane torch I got from Radio Shack.  Always worked fine for me. ;D  Never used the 1/16th copper.  And the 1/8th" O.D. K&S copper bends real easy once I put the Weed Eater line inside it..  I heat the brass to use for fuel filler/vents on built ups and use the Weed Eater line to keep it from kinking.
Post by: Vincent Corwell on December 20, 2010, 01:37:51 AM
Many thanks Alan & Lee
Exactly what I was looking  for
Vincent
Post by: Mark Scarborough on December 20, 2010, 09:15:45 AM
Heres a photo essay (?) I put together, maybe it will help
http://www.brotherhoodofthering.info/flightline/photos/photo-thumbnails.asp?albumid=120
Post by: Don Hutchinson AMA5402 on December 20, 2010, 10:54:26 AM
I  just run the leadout wire through 1/16 brass tubing and then wrap it around a suitable sized drill bit, feed it through the bellcrank and then close up the ends and wrap about 1 inch of the leadout pair with copper wire. This avoids softening the brass tubing.
Don
Post by: john e. holliday on December 21, 2010, 08:45:29 AM
I have a pictoral on here called, "Leadouts My Way".   Do a search for "leadouts".  I use the swagging method of doing the ends, but wrapping with copper wire can be done as the tubing holds the cable in place better.
