CLICK HERE--><--CLICK HERE
Ringmaster Reverse Wing
Started by Motorman, October 18, 2026, 03:20:38 PM
Previous topic - Next topic
0 Members and 1 Guest are viewing this topic.
Motorman
Please don't ask me why I want to do this, the answer is too stupid to believe.
I have a Ringmaster S1 kit. I want to build the wing so it's tapered in the front with a straight trailing edge.
Do you think I could just angle the center joints the way I want then turn the ribs around? Would there be unforeseen difficulties?
MM :)
Mark wood
I think there are no rules that specifically state you cannot do that. For the life of me I personally can't understand why you'd want to do such a thing but then I don't understand the infatuation with Ringmasters in the first place. The aft spar may produce some difficulty but there shouldn't be anything a few splices and doubler plates and judicious application of Exacto knife modifications won't fix.
With the taper being so significant from the front it's going to take on some A4 wing platform kind of appearance with an elliptical weirdness. Call it an S-4 somethingorothermaster.
I think you should do for the sole reason you can.
Life is good AMA 1488
"Physics is like sex: sure, it may give some practical results, but that's not why we do it." – Richard P. Feynman
Take off's are optional. Landings are mandatory, it's only a question of quality.
944_Jim
I actually said this as written. Of course, I giggled the first few failed times.
Sorry, nothing regarding the wing of topic.
Yeah, what Mark Wood said.
If this were a 1/2A model, I'd pay attention to the wing box. Maybe flip the bellcrank platform around to get the LE angles right and TE straight through. Back up the LE with balsa blocks or plywood gussets between the ribs. I'd cut new spar notches so the spars are straight through. Cut them a bit shallow and plane or sand the spar(s) to the ribs. Keep the balsa skin on 3 or 4 center ribs.
I'm watching. I want to see how this goes.
Good luck!
Dave Hull
No. You cannot build it as described with the ribs flipped around. First of all, it is October, and all projects like these must occur very, very early in April....
Ken Culbertson
Do you really want the TE to become the LE?  You are going to exceed my voyages into trying crazy stuff. But, just swapping the taper from back to front, I think Sterling already tried this.  They put flaps on it and called it the Mustang.
   Actually, that has sort of already been done!! J Roberts had three profile sport kits back in the day called the The Cobra, Swift, and the Sabre. These came out very near the time the Ringmaster did, and through the years I have read and heard of rum,ors that J Robert Smurthwaite copied the Ringmaster construction for these kits. They are really quite different , but the wing assemblies  do resemble the Ringmaster, but the airfoils a bit thicker. The Sabre is the airplane that has what I always thought, even from the first time I saw one, looked like a Ringmaster wing built with the taper reversed. I'll put a pic of the box art here. I see no reason why building a Ringmaster wing this was would not fly. In theory, wings with swept leading edges should turn better. Bell crank position and lead out rake will be different I think. I have thought of trying this myself, since the first time I saw a Sabre. I have collected a Sabre and a Cobra kits, but the Swift still eludes me!! The Swift looks alot like a Ryan ST. Of anyone out there has a Swift kit, you could make this old guy happy  and help me fill that spot in my collection!! The ads for them were not much more that the kit box art, but that was enough to grab my attention as a kid!. I have an assembled Sabre, a barn rescue airplane that I have been meaning to fix up and fly, and hope to get at that soon, like a lot of other projects!! It has tricycle landing gear also, a neat feature you didn't see a lot of back in the day. There is a lot of hard wood, pre-machined wood and such in these kits and I don't think they will build light at all, but maybe  scratch built version version with substitutions made here and there will do the trick. There are no full size plans for these, just assembly drawing sheets like the Sterling kits had. This may be what partly fueled the rumors that I mentioned, and that was Matt Kania was actually the designer of a lot of airplanes back then for Sterling, PGQ, J Roberts and even the Firecat for Jim Walker!! Interesting part of the history of the hobby!
Motorman
That's cool, looks like an F-86.
Agree Agree x 1 View List
Mark wood
Quote from: Motorman on October 19, 2026, 01:09:27 PMThat's cool, looks like an F-86.
My thoughts too. I remembered them after seeing the picture. I have a Saber Stunt on the shelf in the queue to be built someday.
Motorman
Does the Brodak Ringmaster kit have a solid leading edge or is it sheet wood like some of their other kits? My kit still has the plastic on it so I don't want to look.
MM :)
Jake Moon
I
Quote from: Motorman on October 20, 2026, 10:04:20 AMDoes the Brodak Ringmaster kit have a solid leading edge or is it sheet wood like some of their other kits? My kit still has the plastic on it so I don't want to look.
MM :)
It is 3 pieces of balsa stock that you then blend and sand to shape.
Quote from: Jake Moon on October 24, 2026, 10:03:37 PMIIt is 3 pieces of balsa stock that you then blend and sand to shape.
    I think the RSM Ringmaster kit started that trend, because the machined leading edges like the original kits had are difficult to find at best. I don't think they are as strong, but haven't gotten into my kit to look into it. My son Sean built the RSM kit and his fell victim to the weak spot on the outboard wing just at the end of the center sheeting like a lot of people had. It didn't completely break on him before he caught it and repaired it.  I don't know if the Brodak kit has the same construction as the RSM kit. The last Ringmaster I built was scratch built and I used some pre-shaped leading edge, but I didn't join the leading edges at the center section. I spliced it on at the outboard end. That helps conserve the leading edge stock and makes best use of it. Some of that stuff isn't that heavy. But having a solid leading edge in the center section instead of a joined one is stronger and if you ever dunked a Ringmaster event in a minor lawn dart manor, you know how the wing tips keep going forward and and breaks at the center section!! I need to check out the RSM kit I have and see what it is really like. I'm sure the weak spot can be addressed.
Motorman
I think I can still get the angle I need with the 3 piece leading edge then reinforce the center with a solid triangular Piece.
MM :)
Quote from: Motorman on October 25, 2026, 02:57:44 PMI think I can still get the angle I need with the 3 piece leading edge then reinforce the center with a solid triangular Piece.
MM :)
   I would still make the trailing edge one length of 36" and splice on rest you need on the outboard end.
944_Jim
MM,
Have you started the build yet? PM your email address. I'll forward the build sheet for the JRoberts Sabre Mr. Dan refers to. It describes how the swept LE wing was built for this 36" or so WS. I can include the center ribs and strengtheners so you can see how the pieces fit together. Then you do the same for your Swept-Wing-Master.
In fact, thank Dan for it if I find it. It was his kit I borrowed this time a couple years back. I'm still hunting the Swift from the JRoberts series.
