  • July 14, 2025, 03:35:05 PM
Author Topic: Laser Burn and CA?  (Read 2090 times)
Offline Ward Van Duzer
Laser Burn and CA?
« on: January 15, 2007, 10:13:08 AM »
OK, I know this has been covered before, but not being a kit builder I guess I didn't pay much attention. I just started a quickee laser cut kit for a special event and guess what? My CA doesn't stick! I don't use the CA for glue per se, but rather as pins to hold things down while the Pica white glue dries. Seems I remember seeing something somewhere about sanding off the burnt stuff. But that didn't seem to work too well either. Am I missing something?  HB~>
Offline Leester
Re: Laser Burn and CA?
« Reply #1 on: January 15, 2007, 11:29:49 AM »
How old is the glue ? They say refridgeration prolongs it's life.
Leester
ama 830538
Offline Dennis Moritz
« Reply #2 on: January 15, 2007, 08:43:32 PM »
Accelerator.
Offline peabody
« Reply #3 on: January 16, 2007, 05:45:26 AM »
Ward....I believe that a light hit with some sandpaper would heal things....
I had the same results once...and the response shouldn't be to "use more" or to add accelerator...
« Reply #4 on: January 16, 2007, 07:05:21 AM »
HI Ward,
Very interesting!  I have not run into the problem................
Let us know what you find out!
Bill <><
« Reply #5 on: January 16, 2007, 12:08:12 PM »
Problem solved! I think...
It appears the Leester was right. The glue died. It was Sig thin. It was on my bench (used, but closed up) for about a year or so. (I don't build with it, just use it to pin things down.) I tried it on fresh clean balsa and no cure. The only way I could get it to kick was to soak one piece of wood with kicker and lay a bead between each piece. I've had thin go bad before, but it usually manifested itself by getting too thick to flow.
Oh well.... HB~>
Offline Bob Reeves
    • Somethin'Xtra Inc.
« Reply #6 on: January 17, 2007, 09:04:39 AM »
Looks like you have already discovered the problem. First time I ran into that I was a bit shocked as like you the CA always thickened up when it went bad. This stuff looked fine but wouldn't kick, almost drove me crazy till I tried a new bottle.
I have built a bunch with laser cut wood and CA, never had a problem, in fact I read someplace to not sand off the burnt areas. Guess you just have to do what you feel is right for you.
