  • July 06, 2025, 10:33:56 PM
Author Topic: landing gear blocks, wing sheeting? Easiest way?  (Read 2020 times)
Offline dave siegler
  • sport flier
    • Circlemasters Flying club
« on: January 21, 2021, 06:57:28 AM »
So one of the things I have struggled with is the bottom wing sheeting and cutting around the landing landing gear blocks.
The blocks are glued in and are about 1/16 proud of the wing.
How do you deal with it and make it accurate?  Over the plans? multiple small pieces?  or trim and fit?
Dave Siegler
NE9N extra class
AMA 720731
Offline gene poremba
Re: landing gear blocks, wing sheeting? Easiest way?
« Reply #1 on: January 21, 2021, 08:53:41 AM »
 I simply measure and transfer those numbers over to the balsa sheeting. I guess you could lay down paper in place of the sheeting, mark the paper, cut it out and lay that over your sheeting. ...gene
Offline Ken Bird
« Reply #2 on: January 21, 2021, 09:27:22 AM »
I use Bob Hunt's method. He's posted a great overview here:
https://stunthanger.com/smf/building-techniques/mounting-landing-gear-in-a-foam-wing/msg132117/#msg132117
Although Bob's post mainly focuses on foam wing installation, his approach to built up wings is similar.
« Reply #3 on: January 21, 2021, 11:15:20 AM »
I set the blocks with 4 2-56 blind nuts even with the plywood half ribs and sheet over them.  Then I cut out a 1/8" smaller section than the block and replace it with a 1/32 plywood covered by a 1/32 balsa cap cover plate held by 4 small bolts with tapered heads.  That way my gear mount doesn't become a VG where I don't want it.
