  • July 16, 2025, 06:39:38 AM
Author Topic: Drilling new engine mounting holes in a profile airplane?  (Read 1212 times)
Offline frank mccune
« on: July 14, 2013, 06:54:54 AM »
    Hi:
    I find myself having to do this when I change engines on a profile airplane.  One can not  use a drill press as the wing seems to get in the way.  Drilling them by hand is a hit and miss proposition at best.
    Any suggestions?
        Tia,
        Frank
Offline Bootlegger
Re: Drilling new engine mounting holes in a profile airplane?
« Reply #1 on: July 14, 2013, 07:28:11 AM »
  Frank, I sent ya' a personel messaage,
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline GregArdill
« Reply #2 on: July 23, 2013, 03:57:42 AM »
Mount your replacement engine on a 4-5mm aluminium plate and screw that to your plane. The front holes will be easy, the rear holes .... Same problem as before but the mounting holes for the plate can be spaced wider than the engine.
If you start with a plate mount you can change engines as often as you like.
G
