  • June 16, 2025, 02:07:05 AM
Author Topic: laminating Balsa  (Read 7843 times)
Offline Phillip Kenney
laminating Balsa
« on: September 14, 2021, 06:58:39 PM »
kit I just bought uses 2 1/4" piece to make up the 1/2" balsa fuselage. What is the best glue to use to glue the two pieces of 1/4" together?
Re: laminating Balsa
« Reply #1 on: September 14, 2021, 07:12:03 PM »
If you're willing to hold it absolutely flat for 24 hours or so, and to give it a week to dry before painting, alphatic (yellow carpenter's) glue works well.  So does epoxy.
Either way make it a thin layer -- more glue = more weight.
Offline Dan Berry
« Reply #2 on: September 14, 2021, 07:15:06 PM »
I would use slow epoxy.
Offline Dwayne Donnelly
« Reply #3 on: September 15, 2021, 06:32:51 AM »
Either way I leave about a half inch of glue off at the tail and nose , when I put the two pieces together I use CA where the glue is left off, that way the two pieces won't shift when they are weighed down,  ask me how I know. Lol
« Last Edit: September 15, 2021, 08:54:02 AM by Dwayne Donnelly »
« Reply #4 on: September 15, 2021, 07:05:47 AM »
By virtue of the grain mismatch the fuselage will be more twist/flex resistant.  If you put some very light fiberglass or CF in-between it will be even more so.  I would use a thin slow cure epoxy (Z-Poxy for example) and weight it down overnight.
« Reply #5 on: September 15, 2021, 09:14:36 AM »
Or if you're scratch-building, rough-cut the pieces, glue them, then finish-sand.  That's worked well for me.
« Reply #6 on: September 15, 2021, 03:52:35 PM »
Nothing really stiffens if you put it on the central axis. You’d be much better off to cover the fuselage with that cf or gf. L
I was telling people that right up until the glue dried on the first fuselage that I used the technique on.  If you took two identical pieces of wood, with identical grain, and you put them together that way -- probably you'd see no change.  The key is the slight difference in grain between the wood pieces -- that seems to make all the difference in the world.
If you really want to get the full benefit, use two 1/8" sheets on the outside, with 1/4" in the center, and angle the grain by 15 degrees or so -- that should give you considerable stiffness.  Just go really light on the glue or whatever performance increase you get from a stiffer fuselage will get tossed out the window because of extra weight.
« Reply #7 on: September 15, 2021, 04:29:27 PM »
I disagree, even a slight difference will help.
Online Dave Hull
« Reply #8 on: September 15, 2021, 10:17:24 PM »
If you are trying to stiffen a profile fuselage in the lateral bending mode, then putting a higher modulus material right down the centerline (on the bending neutral axis) is the least weight efficient and least effective way to do that. That is what Lauri is telling you. If you added something--anything--then sure, you gained a bit of stiffness and strength, but in the least advantageous way.
Adding the material down the center works pretty well for vertical bending resistance because the outer balsa laminations support it and tend to keep the laminate material from buckling--and some of the higher modulus material is out near the beam outer fiber, but who has vertical stiffness issues with a profile?
This type of construction adds to torsional stiffness but is harder to quantify and explain. In other words, it takes engineering language and equations for a composite beam, which is a pain to calculate by hand. (I would be concerned about shear separation at failing loads if this were more important than just a model airplane.) But again, heuristically, using the higher modulus material as the outer fiber of the structure is the only efficient way to do this.
If these concepts are not appreciated, then there really is no purpose in discussing fiber orientation or other design details needed to understand composite structures....
Offline MikeyPratt
« Reply #9 on: September 16, 2021, 09:27:24 AM »
Hi Phillip,
I’ve done a lot of this and tried different ways of doing this, what does work perfectly is slow epoxy (I like the Sig brand slow epoxy, but I’m sure others will work as well).  Start by placing wax paper over a flat building board, then apply the epoxy to the inside face of the fuselage, then spread out the epoxy with an old credit card, this allows to you put a thin even coat to the part.  Place on top of the wax paper and pin in place with small T-Pins by inverting the pins through the edge of the fuselage half at 45 degree angle.  Place the other half on the fuselage on top and weight the assembly down with old books and or weights and allow to cure for at least 18 to 24 hours.  If you have epoxy oozing out of the joint (more than likely you will), wipe off the excess with paper towel and alcohol.
Later,
Mike Pratt
« Last Edit: September 16, 2021, 09:53:47 AM by MikeyPratt »
Offline Mark wood
« Reply #10 on: September 19, 2021, 01:58:59 PM »
I'm a big fan of west systems epoxy for that kind of operation myself. Dave's correct, adding CF in between the balsa plies won't do much for the actual stiffness. A better way would be to put 1/2" caps on top and bottom. Even better would be to uses some super light fiberglass, .75 OZ/yd, on the sides. Glass has a similar stiffness to wood and would tend to not delaminate from buckling under load. Although adding carbon fiber definitely hits the coolness bragging rights factor up a notch. That alone makes it worth doing.
Life is good AMA 1488
« Reply #11 on: September 19, 2021, 04:02:09 PM »
If you have two 1/4" sides to laminate, you have a golden opportunity to cut a trench and lay a CF tube in there.  That will stiffen things.
« Reply #12 on: September 19, 2021, 04:35:57 PM »
Build a full bodied fuselage.
Offline pmackenzie
  • Pat MacKenzie
« Reply #13 on: September 19, 2021, 09:23:14 PM »
There are many valid reasons why he might be building a profile, so not sure how this suggestion  helps ???
You might just as well have said "Buy a Yatsenko". Good advice perhaps, but completely off-point.
MAAC 8177
« Reply #14 on: September 20, 2021, 07:00:46 AM »
It's not off point. Everyone is giving advice about "stiffness."
Save some weight also.
Offline Dan Berry
« Reply #15 on: September 20, 2021, 07:50:02 AM »
Many are giving unsolicited advice.
Adding stiffness was not part of the original question.
I would bet two beers that I know who made the kit in question. I'll bet one beer that I know which kit.
Epoxy is the answer to the original question.
« Reply #16 on: September 20, 2021, 08:17:35 AM »
     Again, proof positive that your reading comprehension skills absolutely suck, or you are just fond of your own "voice" or both!
« Reply #17 on: September 20, 2021, 10:06:43 AM »
Yes, Epoxy, and a chosen material, is the remedy, unfortunately this will add a bit of weight.
Online Brent Williams
« Reply #18 on: September 20, 2021, 12:35:38 PM »
In an X pattern.
Motorman 8)
What size carbon tow are you using for your X reinforcement?  I have some 48K tow that I might try on a profile.
« Reply #19 on: September 20, 2021, 12:55:10 PM »
I an X pattern.
Motorman 8)
Is that on the outside or in-between the two 1/4" halves?
PS:  Just our of curiosity, which is worse in a profile, twist or flex?  I understand the forces that cause flex and it's impact on the flight but I am not sure what causes twist.
Offline MikeyPratt
« Reply #20 on: September 21, 2021, 06:00:54 PM »
Hi Phillip,
I don’t think Phillip asked about carbon fiber, he was asking about gluing to pieces of 1/4” balsa together to form a fuselage.  This works perfectly with slow dry epoxy or Slightly thinned Tite Bond glue (hell, I would bet you could use Gorilla glue to get a good bond).   With the Tite Bond glue it has to set up under the weights a lot longer.
Note:  Place the T Pins through the edges so as not to in the way when placing the second sheet in place.  Good Luck Phillip on building your model.
Mike Pratt
« Reply #21 on: September 22, 2021, 01:16:23 PM »
Well from experience putting my Primary Force together,  Gorilla Glue is the way to go.  Make sure you have a roll of Parchment paper(found in the Baking section of the store) on both sides of the laminate on a very flat surface.  The Gorilla Glue will find every worm hole in the balsa and once it cures the excess can be sanded off and is the lightest glue I have found.  Draw back is the glue does not have a very long shelf life.  Also I think I would break the laminate before it bends. D>K
Offline Dave Moritz
« Reply #22 on: October 03, 2021, 11:36:39 AM »
Gentlemen:
Back to some serious thread drift!  A SIG Skyray kit build for my Winter project, might want to stiffen the fuselage so suggestions needed. Recently, Ken has suggested youth fiberglass arrow shafts embedded top and bottom of half-inch fuse. Not sure how to interpret Lauri's ideas, but am intrigued.
What say ye all?
Dave Mo...
Offline MikeyPratt
« Reply #23 on: October 03, 2021, 02:01:29 PM »
Gentlemen:
What say ye all?
Dave Mo...
Dave,
The Skyray is good the way it is, it’s not that long of a fuse, unless you want to drive post holes.  Most of the crash’s I’ve seen the Skyray’s fuse were pretty much intact, the wing takes the beating for the most part.  A strip of CF down each side of the fuse can help but not really needed.  I’ve seem all kinds of mods to the Skyray 35 some mods work pretty good, and the others not so much, they just added more weight.  When I first designed the Skyray 35, it was to use up the short balsa & plywood that were in the saw room in the plant.
Things that do work well such as;  3/32 balsa ribs, hard balsa spars, extending the span of the elevator 1/2” at each of the stab tips and increasing width & span of the elevator by 1/2”.  If glow powered add a balsa nose cheek from 3/8” or 1/2” balsa from the nose back to the wing spars.  Also, use the landing gear from a Twister or bend your own out of aluminum.
Later,
Mike Pratt
« Reply #24 on: October 03, 2021, 02:49:37 PM »
Dave,
     I have to agree that the plywood wing is suboptimal. On the first significant crash with mine, just about every single plywood part was shattered into multiple pieces, I had a nice monokote bag full of scraps. The fuselage was just cracked lengthwise and the tail was perfectly intact. The balsa version I made to replace it was was *6 ounces* lighter, which only slightly improved the performance with the 20FP, but survived many crashes - at least 50 of varying severity - only finally requiring a serious repair after the monokote had turned to glass and shattered in a mild pancake crash.
    I agree the fuselage is perfectly fine as is, same with the tail surfaces. I recently passed my original model to the next generation. I plan on making a slightly modified replacement, the only consequential change being about 1.5" shorter tail moment, with a correspondingly larger stabilizer to get the same TVC. I have always been running into the pitch rate limit long before I got a stall, so I want to increase the max pitch rate slightly.
« Reply #25 on: October 03, 2021, 04:16:07 PM »
  The Skyray .35's that I have scratch built I used 3/16" balsa for the ribs and kept the same spacing. I had a bunch of strips left over from experiments in cutting my own balsa from planks and this stuff was pretty light but stiff. The first one was built that way about the time the kit came out, and it has been through the mill for all sorts of duty like balloon bust and such, and I have lost track on the number of recover jobs on it. It's still hanging in the garage ready for use if needed! Any future versions will most likely be built the same way but will try the slightly larger stab, haven't tried that yet.
Offline Dave Moritz
« Reply #26 on: October 05, 2021, 10:16:18 AM »
How about some poetry?
This drift brings out the big guns
I'll build it as is...
So let it be written, so let it be done.
Thanks to all!
Dave Mo
Offline Dave Moritz
« Reply #27 on: October 05, 2021, 10:18:38 AM »
PS:
With the balsa ribs!
Dave Mo
« Reply #28 on: October 05, 2021, 12:25:03 PM »
Brett:
What do you use for the control system?  3" or 4" belcrank?  Horn size?
The reason I ask is that I finally finished a bad-luck Peacemaker I started many, many years ago.  It has a stock control system and it flies awful.  I would like to build one that flies well (if that is possible).  It's a sentimental thing....
Thanks!
« Reply #29 on: October 05, 2021, 02:29:39 PM »
I think the Skyray is good just the way it is, and won't be recommending any changes when my wife builds one.
In fact, I built some 40-sized stunt trainers, the "design" effort involved keeping the Skyray's basic aerodynamics (aspect ratio, TVC, etc.) with enough of a scale-up so that the plane would fly well on Schnurle-ported 35 or a Tower 40.  The first one I failed to scale up the fin area correctly and it had yaw problems -- making the fin match the Skyray fin fixed that.  The second one I didn't screw up the fin, and it flew right off the board.
« Reply #30 on: October 05, 2021, 07:22:37 PM »
Brett:
   It's a 3" SIG bellcrank straight out of the kit, and a nylon CG "Large" RC control horn, in the second hole (maybe 3/4" from the hinge line). Stock 3/32 music wire pushrod, unbushed and crimped leadouts.
    The original intent was to build this kit (which I acquired to give me a guide to rebuild someone else's airplane - after I crashed it...) for my work buddies to fly at a picnic, and the expected lifespan was <<1 hour. So I did absolutely nothing other than cut out a new fuselage (which I had used in the other rebuild) and stick it together exactly how it came. Picnic never happened.
    Dixon 40FP, which I never even *ran* before I gave it to someone to use on their Twister, later Fox 35 (disaster, although I beat David in a contest with it), sat for 2-3 years,  L&J Fox 35 with bypass mod at least ran until it started shaking itself apart, next weekend OS 20FP/Circus Hobbies 9.5-4.5, miraculously better. This takes us up to *1996*....
    You get the idea, the notion that it would be flying with more-or-less stock moving parts after closing in on 30 years was the furthest thing from my mind.
     I can't see any compelling reason to use a 4" bellcrank, the control loads are nearly non-existent. It won't hurt anything, of course.
« Reply #31 on: October 05, 2021, 08:01:48 PM »
  Some where in my archives of printed stuff is a sketch where a 4" bell crank was drawn with typical pushrod locations and such and how much throw that had, and superimposed over that was a SIG 3" bell crank and what hole location was needed to mimic those throws. I think the flap push rod hole is 7/16" from the center hole, or something like that. Some one may know for sure. SIG has a tall nylon control horn with as much space as you would need to fine tune the flap and elevator throws as you could want. Between that and adjustable line spacing you can dial in anything you would need to be comfortable.
Offline doug coursey
« Reply #32 on: November 27, 2021, 07:38:26 AM »
is this the stuff that expands when it dries...like foam
AMA 21449
Offline Les Akre
« Reply #33 on: November 28, 2021, 08:18:56 PM »
Hi Phillip
As already mentioned, if I was to glue two pieces together, I would use one of the many laminating epoxies available. If you already have some, then you're good to go. Just park some heavy weight(s) on the glued pieces, over the flattest surface you can find before they set up. I've done this a few times for solid wings as well.
If however, you don't have any laminating resin, it's probably less expensive to just buy a piece of 1/2" balsa and use that.
Les
« Reply #34 on: November 28, 2021, 08:33:00 PM »
Yes Gorilla glue expands. If you don't clamp the parts you'll have a balsa/foam sandwich.
The carpenters Gorilla glue doesn't expand like the regular Gorilla.  It acts just like Titebond only stronger.
« Reply #35 on: December 01, 2021, 01:34:15 PM »
You can't just say "Gorilla Glue" any more and know it's the green urethane foaming stuff.  They have all sorts of glues these days -- green foaming, white foaming (which turns green in the sun after a while), epoxy, aliphatic (Titebond), CA, and I think one or two more.  Plus construction tape.
Offline Fredvon4
  • Central Texas
« Reply #36 on: December 01, 2021, 04:27:11 PM »
Usually when I laminate between Balsa sheets I use epoxy and a top flite wood pecker tool
not sure who sells them any more Tower is a worthless site not for any building stuff
Ebay seller is out of his ever loving mind for one
https://www.ebay.com/p/2255975934
Fred von Gortler IV
« Reply #37 on: December 01, 2021, 06:45:48 PM »
  That seems rather excessive/highly optimistic
    But, if you are using epoxy, poking holes is unnecessary, you have plenty of bond-line strength just gluing the flat pieces together.
   As per the other thread, while the right kind of epoxy is ideal, almost anything that says glue on it will work as long as you are careful about warps. Plenty of these sort of jobs were formerly done with Amrbroid (which is the worst possible choice) and even though it might never dry all the way in the middle of the sheet, it was plenty good enough.
« Reply #38 on: December 01, 2021, 07:29:20 PM »
A brief comment on the original gorilla glue, someone said it doesn't have a good shelf life, and that can be true, bur doesn't have to be.  I use a ton of it in the guitar building process and lose very little to shelf life.  The key is to squeze as much air out of the container as possible before capping.  It goes and goes and.....
Offline Mark wood
« Reply #39 on: December 01, 2021, 07:53:05 PM »
Yeah, but Ambroid had "that smell"....
« Reply #40 on: December 01, 2021, 11:29:15 PM »
    The best smell in the world! And also, great for chewing off your fingers for the next few days. CA is definitely second-rate in that regard.
« Reply #41 on: December 02, 2021, 06:55:46 AM »
Ambroid, it brought out the best in my Mother:  "OPEN THE G.. D... Window".  How many kids do you know that got a window fan for Christmas?
So now we have CA and it brings out the best in my wife: "OPEN THE G.. D... Window".
« Reply #42 on: December 02, 2021, 07:10:34 AM »
Ken: Good one!!!  When I was a kid I got in real trouble after I dropped a jar of clear dope on the floor (oh yeah, it broke!!)
Offline Mark wood
« Reply #43 on: December 02, 2021, 06:46:59 PM »
Yeah, CA just doesn't chew off right.
« Reply #44 on: December 02, 2021, 08:01:55 PM »
I'm going to try that!  Storing it top down works too.  The glue hardens in the cap but you can clean that easily; the stuff in the bottle lasts much longer.
