  • July 16, 2025, 02:00:34 AM
Author Topic: Vinyl Lettering  (Read 941 times)
Offline James Mills
Vinyl Lettering
« on: August 22, 2008, 05:12:32 PM »
 Can you clearcoat vinyl lettering (will be using Urethane clear)?
James
AMA 491167
Offline Richard Grogan
Re: Vinyl Lettering
« Reply #1 on: August 23, 2008, 12:11:32 AM »
Yes, but you need to scuff up the surface a bit so the urethane has something to bite into(The sheen of the vinyl, if you will). What brand/type of urethane are you using?
Long Live the CL Crowd!
                  AMA 85745
Mike Griffin
Re: Vinyl Lettering
« Reply #2 on: August 24, 2008, 09:43:03 PM »
Not sure about urethanes but I have clear coated my vinyl lettering with Lustercote clear and had great results.
