  • August 01, 2025, 09:21:47 PM
Author Topic: Home made ajustable leading edge slot cutter  (Read 2051 times)
Offline Tom Perry
« on: November 03, 2006, 07:46:45 PM »
Folks,
Another use for Bull Dog clips and Popcicle Sticks.
This is the leading edge cut for the Maltese Cross Thing in the general forum.
Any questions?
 AP^
Tight lines,
Tom Perry
 Norfolk, Virginia
Notch-o-Libre?
« Reply #1 on: November 03, 2006, 08:46:25 PM »
I've never seen a convincing reason to put a stress riser in the LE, TE or Spars, but some folks like to predetermine where stuff will break.  A small ballpoint pen mark works pretty well and doesn't make a weak spot. I'd consider putting a vertical 1/16" square (one or two) in such a location, or a gusset. The way I see it, if I don't notch these items, I can reduce the size of the LE, Spars, and TE. That should save some weight. The airplane will fly better, and because it flies better, it won't crash as often, tho  SH^**) Steve
Offline minnesotamodeler
  • Me and my Chief Engineer
    • Minnesotamodeler
Re: Home made ajustable leading edge slot cutter
« Reply #2 on: November 04, 2006, 01:45:18 AM »
Very slick notching system. Didn't realize Tom was asking for a critique of the concept of notching.
Thank you, Tom.
--Ray
--Ray
AMA902472
Offline Dennis Moritz
« Reply #3 on: November 04, 2006, 03:54:29 AM »
Always possible to hollow out leading edge between ribs and reduce weight some more. Stress risers in bawsa? They seem too fibrous and discontinuous. When ribs are zapped with good cement, seems to me that would be a strong 3/32". Thin CA fanning out into wood surrounding the joint, would definitely add strength. Wings are prone to break right after the sheeting in the center section, in any case. Or in the center, if the trailling edge lets go. Also, those notched leading edges are out of fashion these days. Aren't they. The saw looks good to me. Nice to jig up an even depth. My last notched leading edge was eyeballed. Not as even a job as the one above. By no means.
Offline Tom Perry
« Reply #4 on: November 04, 2006, 12:13:52 PM »
Thank you, Tom.
--Ray
And here all this time I thought a dado joint was much stronger than a butt joint what with the extra glue surface and all.  I guess a well fitted joint doesn't make up for any potential compression failure on the rear of the leading edge.  I imagine thousands of years worth of woodworkers are turning over in their graves.  :)!
As the Maltese Cross Thing turned out to have a 9.1 oz.  wing loading I thought it turned out to be a snappy little flyer.
Have you seen the last of the flying weather up there yet?
Tight lines,
Tom Perry
 Norfolk, Virginia
Online Crist Rigotti
« Reply #5 on: November 04, 2006, 12:23:30 PM »
Tom,
Did you enjoy the Popcicles?   :)
Nice job BTW
Offline Tom Perry
« Reply #6 on: November 04, 2006, 12:30:58 PM »
Tom,
Nice job BTW
I cheated and bought a bag of them down at the dollar store.   #^
Just lately though my wife has been buying me sugar free Popsicles and fudgecicles and I don't throw the sticks away.
Tight lines,
Tom Perry
 Norfolk, Virginia
« Reply #7 on: November 05, 2006, 03:38:34 PM »
Most of my kits with the notched leading edges- Sterling Navion, Flite Streak, Cosmic Wind, etc.  broke almost anywhere but at the notches.  Clean notches do make for a nice, neat assembly, as long as you get 'em in the right spots.
« Reply #8 on: November 05, 2006, 10:37:52 PM »
Hi Tom,
That is a neat "tool"!
Bill <><
