  • July 07, 2025, 05:34:48 AM
Author Topic: Sanding DupliColor primer ?  (Read 1063 times)
Offline Rob Killick
« on: March 12, 2008, 08:54:20 PM »
Hi ,
I've just shot on a Duplicolor prime coat  earlier this evening and was wondering if I should dry sand it , or wet sand ?
The substrate must have been good as the the prime coat looks really nice (hate to sand it down:))
Thanks ,
Rob K.
Rob Killick , MAAC 33300
Re: Sanding DupliColor primer ?
« Reply #1 on: March 12, 2008, 09:28:40 PM »
Hi Rob,
I usually wet sand it, however, it is very low loading (as is loading sand paper grit) and sand well dry as well. Wet sanding also makes it easier to see what you're doing because you can wipe it away where as dust clings. If you've primed it lightly and it looks good, don't sand it unless you're worried about weight. That said, a good work down with 400 grit will produce a good tooth for the color coats to adhere to.
Offline Rob Killick
« Reply #2 on: March 13, 2008, 05:03:35 PM »
Thanks Randy  8)
