  • May 26, 2024, 02:35:06 PM
Author Topic: Jigging / Alignment  (Read 2458 times)
Offline Air Ministry .
Jigging / Alignment
« on: February 21, 2018, 10:05:20 PM »
 R%%%%
Re: Jigging / Alignment
« Reply #1 on: February 21, 2018, 10:10:00 PM »
Thees warns for John , Ze Flokeerts .
This is the nose , one bulkead was previously arydited to one side .
Theres three even width 1/2 sheet ( later to be tank floor ) spacers matching formers ,
The Two Planks to keep it Even Pressure & Flat,  And the Alloy piece at bearers on nose , so theyre even vertically .
A pile of boring pictures of the doublers & bearers laminating , if someone whines for it , will post them .
( mayve figured the camera phone, If i remember next time .  :( )
« Reply #2 on: February 21, 2018, 10:13:11 PM »
Now This Ones REALLY Exiting .  ::) ::)  Oh Well . Tragic etc .  H^^
« Reply #3 on: February 22, 2018, 12:30:43 PM »
You need more clamps. LL~ LL~ LL~  One of the reasons I build the motor crutch first, then add fuse sides.
« Reply #4 on: February 26, 2018, 09:41:01 PM »
The Wonders of Modern Technology .
« Reply #5 on: February 26, 2018, 09:42:30 PM »
SRound Peg in a Square Hole .
« Reply #6 on: February 26, 2018, 09:49:19 PM »
The underside'l be planked with 3/16 sht. , curved , and things of that nature .
The 76 Head is further of the beams than a S Tigre 60 or the Stalker 66 ,
thus the ' helmet cowl ' to get the airflow through . We Hope .
Duct the debate with self was wether 1/8 clearance to get air over , of s f a to force air through . Its something like a eigth or three thirty two .
Theres 1/16 Ea Side of the cylinder fins & head .
Intake'l be split , bottom to head alone . Top to fins , C'case though over above and back down and out through 1/2 brass ' exhaust toobs
on the L H side . Which force the nose out under severe pressure , like wind gusts . ask Hoyle .
« Reply #7 on: March 01, 2018, 09:22:03 PM »
Out with the Sandpaper , even bought a brand new medium cut file . o.k. for finishing , but nut as quick, or fierce, as a Bastard Cut .
If you go out at 3 am and get the full moon in the right place, as it peaks out from the clouds, you get this . :-X
« Reply #8 on: March 01, 2018, 09:22:54 PM »
More Artistic Endevours .
« Reply #9 on: March 01, 2018, 09:24:40 PM »
Id tacked the cowl faces with balsa cement , to hold aligned . Bit of perseverance and split on seam with no casulties .
« Reply #10 on: March 01, 2018, 09:28:25 PM »
Will get on to the undercarrage , as a bit perculiar to this . Can then finish under & do ' split top deck ' so its invertable on board
for the ' I ' Beam wing Construction. One Day . The Ideas to get it ready for that , before standing off .
Not the best focus - must be all the daylight on this one .
« Reply #11 on: March 02, 2018, 07:25:17 AM »
Hello Matt
                  Very interesting.post a side view of the fuselage plan to get an idea how is going to look.
        juan
« Reply #12 on: March 03, 2018, 08:34:16 PM »
buenos días
But Thats Not the Fuselage ! . ( Its all right , Ive washed my toes ! .  :-\)
« Reply #13 on: March 03, 2018, 08:42:53 PM »
Shoulda heldthe phone 90 Deg , but w t h .
Is a 112% ? version , 65 inch , of the 57 inch 40/46 version .
Bit Lighter wood as it only has to fly in 20 Kt. air , ands about as big as i think might not take me kite surfing . Wet Field .  :P
The Smaller one was flown in 20 / 25 rough  pounding air , and 30 smooth wind .
 First Flight it was blowing hard but smooth .
21/40 open Ex on a 11 x 4 ,9 mm intake & C'Case pressure .
Then Std. intake . :( or later the HP 40 R P R on the 11 x 5 or 4 if blowing .
Fair bit of 1/8 8 ply ( was 5/32 on the 40 one ) and spruce / bracing .
Idea being you can fly it on downwind , as itll stop there , lines tight , in a gale .
Concept / Layout from 1976 .  H^^
