Link 1
Stunt Hangar YouTube
P.A.M.P.A.
AMA
Balsa Density Calculator
This topic
This board
Entire forum
Google
Home
Help
Tags
Advertise
Login
Register
July 09, 2025, 04:29:39 AM
1 Hour
1 Day
1 Week
1 Month
Forever
stunthanger.com
Building Tips and technical articles.
Building techniques
(Moderator:
RandySmith
J-B Weld for tanks?
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: J-B Weld for tanks? (Read 2045 times)
FLOYD CARTER
24 supporter
Trade Count:
0
Admiral
J-B Weld for tanks?
on:
March 03, 2014, 02:41:57 PM »
Whoops! Building a tin tank and now I can't get in through the front end cap to fasten the far end of the fuel pickup (copper) and uni-flow tube. So....trying J-B Weld. Any comments?
If it doesn't work, I'll start over and assemble the end caps in the proper order.
F.C.
Logged
AMA #796 SAM #188 LSF #020
Dave_Trible
24 supporter
Trade Count:
0
Admiral
Re: J-B Weld for tanks?
Reply #1 on:
March 03, 2014, 03:02:34 PM »
Floyd I think it would work for a while at least. Way back I used the stuff to make a muffler that held up pretty well and have molded venturis with it. Really long term or permanently mounted tank I'd likely bite the bullet and start over.
Logged
GregArdill
Trade Count:
0
Commander
Reply #2 on:
March 09, 2014, 05:33:37 AM »
A mate of mine used it as an emergency repair when the tank started leaking just before a contest.
It got him through the contest, but I don't know if he later fixed it properly or it continued to seal.
Unless you're going to make the tank accessible I wouldn't risk it. It is epoxy based after all.
Greg
Logged
Noel Corney
Trade Count:
0
Commander
Reply #3 on:
March 10, 2014, 12:16:01 AM »
Have used the 24 hr. cure to assemble carbon fibre tanks, Never had a problem. Noel.
Logged
john e. holliday
25 supporter
Trade Count:
0
Admiral
Reply #4 on:
March 10, 2014, 09:36:18 AM »
If the area of the leak is cleaned inside and out it should work. I have done it once, but I try to do better solder jobs each time. Did use the J-B Weld on a car radiator a hole was punched into. When I got rid of the vehicle several years later it was still solid, no leaks.
Logged
Shawnee, KANSAS 66203
AMA 23530 Have fun as I have and I am still breaking a record.
FLOYD CARTER
24 supporter
Trade Count:
0
Admiral
Reply #5 on:
March 10, 2014, 10:20:39 AM »
I, also, have repaired a leaking radiator with JB Weld. But that is water (and some ethylene glycol) not glo fuel.
Anyway, my plane will have a hatch for access to the tank. It will be an interesting experiment.
Logged
Print
Pages: [
1
Go Up
« previous
next »
stunthanger.com
Building techniques
(Moderator:
RandySmith
J-B Weld for tanks?
