  • June 18, 2025, 03:11:40 PM
Author Topic: Is this the right stuff? (pic)  (Read 1939 times)
« on: February 23, 2008, 02:45:57 PM »
Did I get the right primer this time?
Re: Is this the right stuff? (pic)
« Reply #1 on: February 23, 2008, 03:01:54 PM »
Hi Clint,
I have never tried that one.  The one I use (and everyone else I talk to) says Filler/Primer on it.
A different label and a light gray lid.
« Reply #2 on: February 23, 2008, 03:41:17 PM »
No, huh? Well there seems to be a little difference of opinion going on here because this is what Randy R posted in another thread.
Wrong primer for sure. The Truck and Van primer is not what you want. That's why I always tell folks to look for the Filler primer or the Sandable primer, these are the lacquer based products and they have been bullet proof for me.
Sorry for your trouble Clint, but don't give up on the Duplicolor, its great stuff!
 Report to moderator    Logged
Randy Ryan
 The problem I have is that I can't find any of the Filler Primer locally. I don't have time to order anything now and I need some primer.
« Reply #3 on: February 23, 2008, 05:55:48 PM »
Randy Ryan
The sandable primer works great for me, but again, I've only used it under Brodak dope. As near as I can tell, the only difference between this and the filler/primer is the solid content.
« Reply #4 on: February 23, 2008, 06:18:32 PM »
If Randy says that the can you have is what he uses under Brodak's Dope, then it will work.  I have not tried it under any dope or lacquer simply because he primer/filler always works under anything! :-D
But, if it works under Brodak's then it is a lacquer based product, and that is all you need.  And there was no real reason to post.......... LL~ LL~
« Reply #5 on: February 23, 2008, 07:10:20 PM »
The problem is, NONE of the Duplicolor primers say right on the can "this is a lacquer based product". I wish it was that easy.
« Reply #6 on: February 23, 2008, 11:43:37 PM »
Man, that sure looks like a can of the enamel based stuff. I can take a pic of the one can of spray primer I have. But I need to get new batteries for my camera. Sigh....
Offline Balsa Butcher
  • High Desert Flier
« Reply #7 on: February 24, 2008, 08:54:10 AM »
This may work:  Mix up a mixture of talc and dope and thinner (or Randy's filler if you have it). Windy trick: after mixing let settle them pour off.  The poured off stuff is the stuff you will spray.  Spray, sand lightly, use polar grey or silver, or a mix of both as primer.  It may be better than taking a chance with mystery primer.   The filler/primer might not be available in your area.
Pete Cunha
Sacramento CA.
AMA 57499
« Reply #8 on: February 24, 2008, 03:45:57 PM »
you can tell that the can is lacquer based if it contains toluene.
BTW I use the sandable primer as you have pictured for trim as well as base coats.....it is a cool grey.
« Reply #9 on: February 24, 2008, 04:11:28 PM »
The can warning on the back says it contains ketones and toluene.
« Reply #10 on: February 24, 2008, 04:53:31 PM »
Thing is Randy, in the 6 years I've been using Duplicolor, they've changed the can lables at least 3 times. You really have to look close. I picked up a can of the Truck and Van primer because the lable looked the same. I just swiped it up as I passed by the Duplicolor rack. Luckily I noticed it before I used it. I have had luck with it under urethane and epoxy, but its not very freindly to sanding.
« Reply #11 on: February 24, 2008, 04:59:23 PM »
yep - then you are good to go!!!
