  • June 19, 2025, 06:47:04 PM
Author Topic: Straightening plywood  (Read 2045 times)
Offline bill marvel
  • Lafayette Esquadrille, St. Louis
« on: March 30, 2008, 07:24:17 PM »
Eric Rule and Pat King have designed a delightful starter airplane called the Texas Trainer.  The wing, landing gear and tail feathers are secured with rubber bands (like the Cox PT-19).  The wing is sheet 1/32nd ply with a few ribs to maintain a uniform shape.  It looks like a tough little critter.  I thought it would be fun to have on hand.
The design calls for the stab, elevator and rudder to be cut from 1/8th ply.  I searched through three LHS for 1/8"X12"X24" UNWARPED or barely warped plywood without luck.  I got a nice clean piece from Sig but it has a 5/8" bow in it.  I know how to straighten a wing warp.  I am not very good at it but at least I know how.
So how do I straighten a piece of plywood?
regards
bill marvel
Bill Marvel, AMA 793835
Welcome to Stunt Hangar
Offline Tom Perry
Re: Straightening plywood
« Reply #1 on: March 30, 2008, 08:13:50 PM »
Try using a heat gun on the concave side.   y1
Tight lines,
Tom Perry
 Norfolk, Virginia
Offline bill marvel
« Reply #2 on: March 30, 2008, 08:57:03 PM »
Tom:
Thanks.  I put the ply sheet on my glass bench top and heated it for about 15 minutes on the concave side (inside of the bend?).  I put a fire brick on each end.  I see if it helped tomorrow.
Ty:
You read my mind.  Thanks.  I can build 5 or 6 stab/elevator/rudders in the time it takes to straighten the plywood, cut it out and epoxy it together.  But, I really do want to salvage this plywood for future projects.  I suspect all the plywood is somewhat warped these days.
regards,
bill marvel
Offline Ralph Wenzel (d)
« Reply #3 on: March 31, 2008, 05:56:21 AM »
In general, plywood cannot be flattened. You can sometimes minimize the bow, twist or cup by long exposure to heat and moisture, but it's never a predictable thing. You can cut the warped sheet into several smaller pieces and edge-join them to get an almost flat surface. Or you can design the structure to minimize the effect of the warp, compensate for (or even use) the warp.
Ralph Wenzel
AMA 495785 League City, TX
Offline Tom Perry
« Reply #4 on: March 31, 2008, 08:16:24 AM »
Tom:
Ty:
regards,
bill marvel
Bill,
My bad I meant the convex side.  or the other side than what you heated.  The Idea is to dry the convex side out a little so the swelling is less.  Sorry bout that  :(
Tight lines,
Tom Perry
 Norfolk, Virginia
Offline bill marvel
« Reply #5 on: March 31, 2008, 10:36:18 AM »
Bill,
Actually, it worked better from the concave side, I think, Tom.  If I lay the ply on a flat surface (outside of the curve down!), weight both ends and apply heat to the middle, it worked better than anything else I have tried.  If I put a sandbag or brick on the outside of the curve to push it down, I have no way to heat the curve.
I think Ralph's idea helps me the most.
"...Or you can design the structure to minimize the effect of the warp, compensate for (or even use) the warp."
It is probably impractical to straighten a 12"X24" piece of plywood at home.  I can cut out the stab and elevator from the least warped area and have much smaller pieces to straighten.  A rudder that is slightly warped can be helpful if the warp is in the right direction.
Since this is a trainer and the idea was to get it together and ready to fly, I think I am going to stop by Hobby Lobby or Michael's and get some of that really dense balsa in 1/8" or 3/16" and make up a spare tail for this bird.
regards and thanks everyone,
bill marvel
Offline John Miller
« Reply #6 on: March 31, 2008, 11:07:04 AM »
Try this for a tough alternative.
Use 3/32" 8 to 10 pound balsa, and laminate 1/64" ply to both sides. Tough as most plywood, and half the weight.
Offline rustler
« Reply #7 on: March 31, 2008, 02:38:29 PM »
If you'r definitely looking for 1/8 ply, you can cut 2 from 1/16 ply. Try to arrange any warps to counteract each other and laminate together with thin epoxy. Weight it down flat and leave overnight to set.
Ian Russell.
Online Crist Rigotti
« Reply #8 on: March 31, 2008, 04:28:36 PM »
What john and rustler said!
Offline Robert McHam
« Reply #9 on: March 31, 2008, 08:48:27 PM »
For durability I would use 1/32" ply (Flat and straight) with 1/32" sheet on either side. I warrant this will be as durable as you could possibly need and it should be lighter as well. I just don't see solid 1/8" ply tail feathers. It is one thing to build durable, another to build like a rock. If it is lite ply then maybe but still...  Overkill?
I would not buy ply as badly warped as you describe. Just doesn't make sense. I would bring it to the attention of the responsible parties and ask him what he would like to use this crud to build and why it was offered for sale if he were not willing to use it himself.
If this were ply that warped after I bought it, I would save it for bulkheads and firewalls  but no more. Certainly for flying surfaces!
There is better ply available. Don't settle for junk! I have never bought ply that was so badly bent. I would not expect anyone else to either.
It really is too much effort for the little result to "fix" warped, bent, or concave ply found in a store. Just pass it by. But do let the owners of this garbage know that it won't sell because of condition.  Ask him if he were building his house if he wanted such poor quality materials making up important structures in his home? I bet not.
off my soap box for now, Robert
Offline Mike Spiess
  • bikemike
  • AMA #4060
« Reply #10 on: April 01, 2008, 09:44:07 AM »
Robert I'm in the construction buissniss and I can tell you years ago all plywood was made stait and square. But that day is gone the standards are set up by the industry themselves and I can bet you will have an impossible time fiding a sheet of strait plywood anywhere. Yes maybe all the stars will line up and a piece will come strait but only with luck as all plywood and partical boards are shiped before completely cured.
You don't stop flying cause your get OLD
You get OLD cause you stopped flying
St Peter MN
Present Master of the Figure 9
