hi Tim,
It seems that most either use a method like Tom Morris, or like Brett's. The most I have seen were the "Morris" type. It is sufficient for anything that will last say, oh, 200 years...........
Solid .032 run through the nylon bellcranks do not wear after about 500 flights. (that's the most I personally know of). There was absolutely no evidence of either wearing at that point.
The major problem was in the old unbushed Perfect, Veco, Fox, and early Brodak bellcranks where stranded wire was run through them. The wire would either saw through the aluminum, or the aluminum edge would wear the strands, either way causing a catastrophic failure. The new molded BCs have almost eliminated that, and running stranded wires through the brass does eliminate it.
The problem these days is terminations causing stress risers which fatigue and break the wire.
Big Bear
