This is a actually an Imitation. I used .02 Carbon fiber tissue on the fuse and covered that with silkspan as a filler.
It did help a lot. Imitations have been flying for years with the twisting fuse. There are at least 5 flying in the group I
fly with. It is obviously better to stiffen the fuse. The originals were powered by St .46. Most now are using PA
65 one has PA 61. Mine has a Double Star .54.( the plane pictured above.) These are excellent flying airplanes.
The front end is bulletproof, and with the Carbon fiber covering the fuse it really stiffens it up. Most weigh in between
55-65 oz depending on the power plant. The plane pictured has a foam wing and is scratch built with stab/elevator, rudder flap modifications to make it look like a Chipmunk. The plane is 10 years old and still flies very well.
