  • June 19, 2025, 01:08:26 AM
Author Topic: Installing the Wing (Full Fuselage)  (Read 3688 times)
« on: January 31, 2016, 09:51:30 PM »
The wing has a tapered LE and is tapered in thickness so, I can't slide it in from the side. I guess the usual thing to do is cut the bottom out of the fuselage and glue the wing in then glue the fuselage back together? Has anyone just built the fuselage on the wing? Side the sides in from the wing tips then glue the former's in. There would be a slot for the flaps that would be filled in later but maybe better than cutting the plywood doublers in half?
If I brush on 3 coats of nitrate thinned 50/50 then tack down some polyspan lite with nitrate 25/75 would I still be able to epoxy the wing in the fuselage or would I eventually get some kind of delamination or wing joint failure? I've found several posts but no clear consensus on this. I would overlap the polyspan in the middle by 3/4" so the epoxy in the joint would only have to go through one layer polyspan lite but essentially you're still only gluing to nitrate dope.
Would like to cover the wing and fuselage before I mate them but sure don't want it to come apart.
Online Curare
Re: Installing the Wing (Full Fuselage)
« Reply #1 on: January 31, 2016, 10:37:24 PM »
Sounds to me like you're trying to wash the basement windows of your house by digging a hole to put use your ladder.
I.e. the get-around for one problem is twice as convoluted as the original problem.
Or you're describing building an I-beamer.
Greg Kowalski
AUS 36694
« Reply #2 on: February 01, 2016, 07:23:44 AM »
So that's a no one the first question, how about the second?
Offline Paul Wood
« Reply #3 on: February 01, 2016, 09:27:21 AM »
I have done the installation as you suggested. But...only once. Tried it on a '52 Nobler and it worked, but the issue of building the rest of the plane with the wing in the way was a nightmare. I was constantly banging the wing into something while doing the million other steps required to finish the fuselage/tail assemblies. My method of securing the wing into position was to use fiberglass strips and epoxy glued to the inside of the fuselage sides to secure the wing. This leaves the wing/fuselage junction clean for the fillet. I slit the fuselage sides to allow the flap rods to pass thru the fuselage. Filling the slots later was no issue. Hope this works better for you. It was just not worth the wing damage for me.
« Reply #4 on: February 01, 2016, 10:24:22 AM »
I thought everyone built their wings and fuselages separately?
With the fuselage build allowing for access to the control horn wire either before or after it's in place.
Then attaching the wing to the fuselage.
I know of no other way.
« Reply #5 on: February 01, 2016, 10:29:58 AM »
What do you use to fill the gap left by the blade you saw the fuselage with ply, basswood?
« Reply #6 on: February 01, 2016, 10:33:00 AM »
I still do tapered wings the old way.  Cut Fuse bottom out making cuts at an angle.  I also have the flaps already on the wing.  Once wing is in place, glue the cut section back in place.  Use ply scab over the inside of the cut.
Now once wing is in place with some glue and doesn't move, I take strips of fiber glass and epoxy glue on the inside fuse wing joint.  Being as I also have the bell crank posts sticking above and below the wing surface I put my ply plates over the post ends before doing the fiber glass on the wing/fuse joint.  So far no failures.
Offline Fred Underwood
« Reply #7 on: February 01, 2016, 10:39:13 AM »
You might look at Crist's thread,
http://stunthanger.com/smf/gettin-all-amp'ed-up!/2016-electric-stunter-build-log/100/
and previous build threads.
It seems that he slides the wing in.  You can put the flap horn in the fuse and then the wing.  With a small slot to move the horn back out of the way, then you can insert tabs into the wing and adhere.  In past builds, he has joined foam wings with silkspan and dope and glued over.
Fred
352575
Offline Mike Mulligan
    • Mulligan Racing Development
« Reply #8 on: February 01, 2016, 12:44:53 PM »
I use a 1/64 plywood shim to fill this gap. I use a razor saw to cut the fuse, so the gap is minimal to begin with and the 1/64 ply is close to a perfect fit. I back up the cut area with another piece of 1/64 inside the fuse extending about an inch fore and aft of the cut.
Mike Mulligan
AMA 789641
www.Mulliganracing.com Mike@Mulliganracing.com
