  • July 09, 2025, 05:44:24 AM
Author Topic: I have been slacking so I started this  (Read 24812 times)
Offline RC Storick
« on: January 05, 2014, 10:10:39 PM »
5 Days ago I started the E Viper 3 same numbers as two. A few changes are battery set back farther and a Stab and Flap system that is new to me. Its been around 50 plus years but takes a lot of work to make them. Sharks use them. The hinges are set into the flaps 1/2 the thickness and the trailing edge is routed out so there are n gaps. Its my first time but I like a challenge. Anyway tomorrow I build the wing. everything is made so it should go together in a few days. It will be light.
Offline Doug Burright
  • Legacy, Brodak kit
Re: I have been slacking so I started this
« Reply #1 on: January 05, 2014, 11:26:45 PM »
Cool! So... You're moving the battery aft, so there won't be a CG shift when the power quits?
Ha ha. Just kidding. Not to mention all the static electricity, when you wipe the plane down after a flight. That's the residual voltage.
I will build it. It's gonna be really difficult to find me with an ARF. I know every bit of my airplane!
« Reply #2 on: January 06, 2014, 06:53:04 AM »
Robert,
Is this along the idea as to what you are doing?
Offline RC Storick
« Reply #3 on: January 06, 2014, 07:15:03 AM »
Robert,
Yes thanks for posting this
steven yampolsky
« Reply #4 on: January 06, 2014, 08:57:21 AM »
These hinges make inset hinglines a breeze to make. Russian modelers(those that don't make everything themselves that is) have been using them for years.
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXET57&P=ML
Offline RC Storick
« Reply #5 on: January 06, 2014, 09:30:05 AM »
I bought 2 sizes of these and they are not loose enough for what I am doing. So I made my own.
« Reply #6 on: January 06, 2014, 02:18:27 PM »
Robert,
Nice framing so far.
What size is your LE stock? Does it taper towards the tip?
Offline RC Storick
« Reply #7 on: January 06, 2014, 02:49:26 PM »
Robert,
All tapers are dictated by the spar. On a beam airplane everything is set to the spar. (bad spar = bad wing) The LE stock is 1/2 X 1 and will be shaped after all the ribs are set. I have devised a new system (at least to me). Its a floating spar. The spar floats in the fuse when jigging and is held in with clips after everything is aligned.
Offline RC Storick
Re: Progress pic
« Reply #8 on: January 09, 2014, 12:52:06 AM »
Things have been moving slow but this is where I am at sense the 1st of the year.
Offline Serge_Krauss
« Reply #9 on: January 09, 2014, 01:00:59 AM »
You're right up to speed, and it looks quite nice!
« Reply #10 on: January 09, 2014, 09:22:39 AM »
Looking good and you are further along than I am with my stuff.
Offline RC Storick
« Reply #11 on: January 09, 2014, 09:36:28 PM »
I was asked to show my hinges. I hope this picture explains how its done. I am still detail sanding the wing and getting all the little stuff done like sewing the ribs. Fuse and wing with tips is 9 ounces.
If you notice there is a C in the trailing edge and a rounded LE of the elevator. The pivot is set back 1/2 the thickness of the elevator and will act like a socket never having any hinge gap.
 Flaps are the same set up with three hinges instead of two. I have a dremel router and I used a 1/4 inch half cutter. I made 2 passes one in each side and then sanded the finish for the C.
I will add that they are at least ten times free'er than regular hinges I have used. They flop. This will be a bushed horn set up. I have tried all the modern stuff and still think some of the old ways are better for me.
« Last Edit: January 09, 2014, 10:29:15 PM by Robert Storick »
« Reply #12 on: January 09, 2014, 09:54:24 PM »
 So you made the hinges then? Can't quite tell, are they plywood?
Offline RC Storick
« Reply #13 on: January 09, 2014, 10:12:46 PM »
Yes with brass bushings
« Reply #14 on: January 09, 2014, 10:29:18 PM »
 Got it.
Offline RC Storick
« Reply #15 on: January 09, 2014, 10:42:59 PM »
Simple hinge
Offline Doug Moon
« Reply #16 on: January 10, 2014, 08:13:44 AM »
I think the way you sew the ribs wit Kevlar thread is really cool!!  Do you CA them at the point of contact with each rib?
Doug Moon
AMA 496454
Dougmoon12@yahoo.com
Offline RC Storick
« Reply #17 on: January 10, 2014, 08:58:51 AM »
Yes and where the X in the center too. Weighs nothing and it 1000 times stronger than balsa
Offline KenP51
  • K Pitts
« Reply #18 on: January 10, 2014, 09:26:36 AM »
Would you show us a close up of the hinge detail, if you can? This looks really neat.  D>K
Ken Pitts
But as for me and my house, we will serve the Lord
Jim Roselle
« Reply #19 on: January 10, 2014, 11:15:07 AM »
I'm pretty new to this, is that what's referred to as an I-beam wing? Is it always done with the spar installed in the fuselage?
Jim
Offline Allan Perret
  • Proverbs
« Reply #20 on: January 10, 2014, 11:20:05 AM »
What about the hinge pins ?   Are you using a long single wire to make the surface removable, or individual pins permanently installed ?
Allan Perret
AMA 302406
Slidell, Louisiana
Offline RC Storick
« Reply #21 on: January 10, 2014, 11:42:18 AM »
When I do the flaps I will do a detailed photo spread. This is not a new thing its from the 40tys (there abouts) and works great.
Offline RC Storick
« Reply #22 on: January 10, 2014, 11:45:52 AM »
Jim
This is a beam wing and mostly done with spar in fuse. It allows perfect alignment of everything. However I guess you could build it out of the fuse but why? Looks complicated but once you have built a few its simple.
Offline KenP51
  • K Pitts
« Reply #23 on: January 10, 2014, 11:46:30 AM »
Thanks Robert
Ken Pitts
Offline RC Storick
« Reply #24 on: January 13, 2014, 09:48:45 AM »
Here is where E Viper 3 is at now.
Offline KenP51
  • K Pitts
« Reply #25 on: January 13, 2014, 10:10:29 AM »
loving them bones. Almost a shame to cover.
« Reply #26 on: January 13, 2014, 11:24:15 AM »
  Is it possible to put up a picture of this detail, or is it covered by now? I'm having trouble visualizing this.
    Thanks a lot,
Offline RC Storick
« Reply #27 on: January 13, 2014, 12:54:23 PM »
    Thanks a lot,
Somewhere on the other viper thread I put up a pic of what it would do but my camera is limited and it blurs.
Offline RC Storick
« Reply #28 on: January 13, 2014, 01:01:01 PM »
Here is a picture
« Reply #29 on: January 13, 2014, 01:58:53 PM »
  Back in the good old days, the lubrication took care of itself. Now, you have to oil them from time to time, even on piped airplanes. The hinge pin will rust if you are not careful.
Offline RC Storick
« Reply #30 on: January 13, 2014, 02:06:24 PM »
Dissimilar metal corrosion sets in and I did think of making the bushings from Nylon. But Nylon would not be as free as the bearing surface would be larger. I want floppers. I guess on the next plane I will make them from oil-lite.
« Reply #31 on: January 13, 2014, 08:16:15 PM »
 Heck, you oughta have it ready to fly by this weekend! n~
Offline MarcusCordeiro
« Reply #32 on: January 14, 2014, 07:25:25 AM »
 8) 8) 8) 8) 8) 8) 8)
Marcus
Live to fly, fly to live
Aces High!
Here comes Marcus, man..."
« Reply #33 on: January 14, 2014, 09:35:05 AM »
I would think that the pressure of the air pushing on the control surfaces would far outweigh the drag of any standard control system. That being said, there is nothing wrong with smooth controls.
Derek
Online Lauri Malila
« Reply #34 on: January 14, 2014, 10:18:01 AM »
I think that the best material (with steel hinge pins) would be cotton reinforced phenolic. Or Tufnol 6F/45 if you don't like the stinky stuff. They are easy to glue and hold oil or grease well.
Yuriy's hinges are similar but molded from some kind of Nylon. No metal bushings needed.
L
« Reply #35 on: January 14, 2014, 10:56:28 AM »
   It's additive. I think you would be very surprised how much effect even a tiny bit of drag makes.
« Reply #36 on: January 14, 2014, 11:11:27 AM »
No, I wouldn't be surprised, I fly solids... But you are right, I didn't think about it that way.
I am "assuming" that Sparky is looking for a way to get around the Netzeband wall.
Derek
Offline RC Storick
« Reply #37 on: January 14, 2014, 11:34:36 AM »
Motor offset and light weights.
« Reply #38 on: January 14, 2014, 12:18:18 PM »
By all means do what you like but it seems to me that motor offset would cause more trim problems than its worth. I build all my planes strait, no rudder or engine offset and no adjustable rudder. I use leadout, and tipweight to trim the plane.
Just my .02
Derek
Offline RC Storick
« Reply #39 on: January 14, 2014, 01:37:52 PM »
Just my .02
Derek
Would you agree that the Shark fly's well? It has 3 degrees Motor offset. Would you agree that Billy's T-Bolts fly's just as well. There again about 3 degrees. The only line tension overhead is off set.. Just my thinking
« Last Edit: January 14, 2014, 05:24:25 PM by Robert Storick »
« Reply #40 on: January 14, 2014, 04:52:29 PM »
 Offset? No offset? It's all personal preference, each individual should just build to fit their own.
 And you all do know that even a plane that's built straight (with no built in offset) still flies as though it has some offset, because it's on a tether.
 Plane is looking great Sparky. y1
« Reply #41 on: January 14, 2014, 10:50:23 PM »
    It won't hurt anything too much, but the offset, trimmed tangent otherwise, gives you virtually nothing overhead or anywhere else, less than 2 ounces over what you would otherwise have. Almost all of the overhead tension comes from centrifugal force - in this case, tension = centrifugal force - weight when you are dead overhead.
    Most of the effect of offset is to create (or null out) the yaw torque by aiming the thrust vector so it passes inboard of the CG. The more offset you have, the more right thrust you need (because the CG will need to be offset to the inboard side of the fuselage). That's the main thing wrong with the All-American, the engine is lined up with the fuselage but the CG is well inboard, so it yaws in at you at takeoff.
    I use around 2 degrees, somewhat indifferently measured, and I have about 3/4" of wing asymmetry. It's very insensitive and of all the unnecessary offsets, thrust line offset is the least objectionable.
Offline RC Storick
« Reply #42 on: January 14, 2014, 11:09:20 PM »
Centrifugal force over head? Come on. The Centrifugal force overhead is less than gravity. Guess I never learn simple physics.
Offline Douglas Ames
« Reply #43 on: January 14, 2014, 11:47:21 PM »
x2! Excellent Engineering.
AMA 656546
Offline KenP51
  • K Pitts
« Reply #44 on: January 15, 2014, 06:27:18 AM »
It's all over my head LL~ LL~ LL~ LL~ LL~ LL~
« Reply #45 on: January 15, 2014, 01:12:36 PM »
Since this is off-topic and further comment on it in this thread is unwelcome, I will post the answer in the Engineering section (it's that dreaded high -now middle - school math).
SK
Offline RC Storick
« Reply #46 on: January 15, 2014, 01:22:29 PM »
SK
Please do I would like to know how much centrifugal force is applied if the engine quits. I would be nice to know the amount of line pull there is overhead dead stick.
« Reply #47 on: January 15, 2014, 03:01:37 PM »
    When your engine quits directly overhead, does it fall straight down at you from the top of the circle?  Of course not, most of the time, that's perfectly recoverable.
    I call shenanigans, this time you are just pulling our legs.
    Of course, when the engine quits, it slows down pretty quickly, so you start losing it rapidly. Particularly if your airplane is too light, the drag is the same as everybody else's airplane, but the momentum is less, so it the acceleration slowing it down is higher. But you have to get down to less than half speed to get the centrifugal force down to zero.
    By the way, my satellite is dead overhead right now, and the engines aren't running, what keeps it from falling straight down into the ocean?
Offline RC Storick
« Reply #48 on: January 15, 2014, 03:04:22 PM »
Either zero gravity or a elliptical orbit around the earth. I don't know. But I do know for sure 3 degrees off set is better than none.
Offline KenP51
  • K Pitts
« Reply #49 on: January 15, 2014, 03:12:22 PM »
I remember a few over head dead sticks. I dove out, a bit scary for sure.
