  • August 02, 2025, 03:27:34 PM
Author Topic: New build,but first, all the wood  (Read 1893 times)
Offline Ty Marcucci
« on: April 04, 2019, 02:06:25 PM »
So  I started to gather all the wood.
« Last Edit: June 24, 2020, 04:05:45 PM by Ty Marcucci »
Ty Marcucci
Offline Dave Holtsclaw
Re: New build,but first, all the wood
« Reply #1 on: April 04, 2019, 07:37:37 PM »
where did you get the laser cut ribs?
Offline Perry Rose
« Reply #2 on: April 19, 2019, 11:49:22 AM »
Mike Griffin has a kit of the Mo'Best cut by RSM. I have an LA .46 in mine I would use a .51 if I was to build another. The .46 flys it very well but a little more power is always good. PAMPA web site has the articles on the plane by Larry Cunningham. Use them to set the plane up.
« Last Edit: April 20, 2019, 07:10:36 AM by Perry Rose »
Offline Perry Rose
« Reply #3 on: April 20, 2019, 07:02:19 AM »
It's not Flying Lines someone made a mistake in the typing.  The articles are in the PAMPA web site under "Building fuselages for strength". Still by Larry Cunningham.
The Mo'Best are 58 inch span 615 sq. in planes. The actual Mk V had a 3/8 fuselage and other refinements. ( on second thought I'm going to read them again, the Mk V may be smaller) Mike Griffin's has a 1/2 inch fuselage and the refinements. !/64 ply sheeting on the sides, all laser cut. The capitol letters on the wing are 3 inches high.
« Last Edit: April 20, 2019, 07:53:30 AM by Perry Rose »
