  • June 16, 2024, 04:33:10 PM
Author Topic: Hutch's P-38 Lightning  (Read 29509 times)
Re: Hutch's P-38 Lightning
« Reply #50 on: February 15, 2017, 05:53:09 PM »
Actually it was re painted OD and went to the South Pacific.
 Thanks for that info Jim, interesting stuff!  y1
« Reply #51 on: February 15, 2017, 09:16:02 PM »
Yeah, I don't think the P-38's saw too much action over Germany, and "YIPPEE" probably spent most of it's time posing over Burbank.
   They were extensively used in Europe, as escorts with much longer range than the P-47 or other available airplanes. They were supplanted by P-51 which was a generally better airplane, of course. A lot of the issues they found on the P-38 were because it was in a different performance range that the other existing fighters at the time. In particular it was the first airplane that could easily get into the transonic speed range, and then its pretty thick airfoil was a serious issue that was impractical to completely solve, once they realized the issue.
« Reply #52 on: February 15, 2017, 10:19:53 PM »
 Yeah, now that you mention that Brett I think I recall that the P-38 had some sort of issue with compression of airflow or something at extreme speeds in a dive, rendering the plane uncontrollable and/or unrecoverable.
« Reply #53 on: February 15, 2017, 11:56:54 PM »
   There were two problems, both related to transonic flow. The first- the controls "locking" in a dive at high altitude - was transonic flow over the wing. The airplane would dive at high altitude, where the speed of sound was slower because it was cold, the flow would choke over the top of the wing and the dive just got steeper. At lower altitudes this went away, but by then you are going like a bat out of hell, nearly vertically, and have to try to pull out. Sometimes they got out of it, and other times they didn't. They eventually diagnosed it, and came up with a deployable spoiler for the bottom of the wing, which altered it enough to retain control. The other was a severe buffeting in the stabilizer, which caused by transonic flow over the wing root. they spent a long time trying to solve it as a flutter issue, but the real solution was a large fillet around the pilot's pod.
      What it really needed was a much thinner wing. Then, as now, they wanted a thick airfoil to both improve the turn, provide space for internal parts, and for strength. But the thicker the wing, the more the air is accelerated as it moves around it, so at some speed, it deviates from the assumption of an incompressible fluid, hence a a compressibility problem. By the time they realized that, it was in production and trying to use a thinner airfoil would result in a complete redesign of the airplane.
     There were also substantial difficulties with the Allison engines. The P-38 was one of the few/only airplanes that had all the turbosupercharging intended for the maximum performance version of the engine, and it took a long time to work it all out. The airplane was designed as it was to house all the parts, the two scoops on the booms, for instance, were the turbosupercharger air intakes.
« Reply #54 on: February 16, 2017, 06:39:14 PM »
 More interesting stuff, thanks Brett.  y1
« Reply #55 on: February 16, 2017, 11:13:17 PM »
  You are welcome. Most of what I know about this was detailed very nicely in the late, lamented Lockheed Horizons quarterly magazine/house organ. It included an interview with The Man himself, Kelly Johnson, founder of the Skunk Works, designer of the Lightning, P-80 Shooting Star and it's brothers, the C-130,  F-104, U2, A-12/SR-71, D-21 and D-21B drones, the CL-1200 Lancer (which, had it been built, might have been a tough opponent for an F-15) and many others. ]
« Reply #56 on: February 17, 2017, 01:05:23 AM »
I am not sure if I really understand some of the comments regarding P-38 operations in Europe.  Anyway, just to set the record straight --
In August, 1942, the pilots of a P-38 and a P-40 share credit for the first German aircraft destroyed, a Fw 200 Condor, in the European Theater of Operations by the USAAF off the Icelandic coast,  In North Africa, P-38's saw action against German aircraft and then moved on to other locations in the Mediterranean, including Italy, where they were used against the Italian and German aircraft.  In the Italian theater, P-38 pilots are credited with 608 enemy aircraft destroyed in the air.  In the European theater, P-38's were used for bomber escort starting in November 1943 with significant numbers of victories, were later replaced in this role by P-51's and were then used through D-Day for bombing and strafing missions.  The German pilots called it der gabelschwanz Teufel (the fork-tail devil).
« Reply #57 on: February 17, 2017, 08:15:57 AM »
I cant beleive I forgot/missed this info, I read the book " the Fork tailed devil" about the development of the P-38 and for some reason I simply dont recall it being that active in the european theater,, thanks for bringing this to light Mr. Trostle and Brett
« Reply #58 on: February 17, 2017, 11:04:53 PM »
 I guess what I really meant back there was that I knew the P-38's were used some in Europe, but I've just always associated them more with Pacific operations. Once the P-51 came along things changed pretty quickly though, especially in Europe.
 Thinking about all of this I just tracked down a photo that I recalled from long ago showing a large formation of P-38's decked out with invasion stripes, probably from D-Day or very shortly after. Also, the first P-38 I ever saw in person was in Oshkosh about 1980, all polished aluminum with big red "Der Gabelschwanz Teuful" nose art. Not sure where that one is these days.
« Reply #59 on: March 31, 2017, 09:01:27 PM »
 Well, I haven't touched the '38 for three weeks or better, pretty disappointing and way behind schedule for spring. Picked up a nagging cough that just won't go away and hanging out in a cloud of balsa dust just hasn't sounded fun. Still fighting it, waah, waah, waah...
 Before that though I did get the engines mounted, spinners fit, and the engine nacelles about 98% sanded to shape. Keeping the shapes the same during the process was a bit of a trick, sand on one for a bit, then the other, back to the other, back and forth back and forth. Anyway, getting very close to busting out the silkspan at this point...
« Reply #60 on: March 31, 2017, 09:11:53 PM »
 Comparing the profile outline I started with to my redone version...
« Reply #61 on: April 01, 2017, 09:51:44 AM »
Making matching engine cowls/nacelles/fuselages is a lot of fun isn't it.   If the doctor doesn't clear me and the weather clear up you will be air borne before me.   You construction is looking great.
Offline Michael Boucher
« Reply #62 on: April 05, 2017, 04:20:47 AM »
HI Wayne, I Hope you still don't have the cough. If you do or for the next time, try drinking pineapple juice. It contains four times the stuff in cough medicine to get you to stop coughing. The P-38 is outstanding! All the best, Michael Boucher
AMA 59633
« Reply #63 on: April 05, 2017, 06:45:42 PM »
 Thanks for the tip Michael, I'll keep it in mind. Does it help if you put a little vodka in with it?
« Reply #64 on: October 12, 2017, 08:54:05 PM »
 "Building Season" is fast approaching, back on the '38 soon...
« Reply #65 on: November 03, 2017, 08:56:26 PM »
 ...spent a couple hours sanding and shaping the '38 booms tonight, it's on for the season.  ;D
« Reply #66 on: November 09, 2017, 09:59:31 PM »
 No photo worthy developments but I've officially stepped into Building Season, cleaned up the shop, and have been working on the '38 the past three nights now. Silkspan covering of major components has begun. First up was the twin booms and they are now covered. Next will be getting out the polyspan and covering the wing...  ;D
« Reply #67 on: November 10, 2017, 01:49:08 PM »
Well don't feel lone some.
« Reply #68 on: November 22, 2017, 11:01:06 PM »
 Finished covering the wing tonight, Polyspan from tip to tip. Gotta let it dry overnight then out comes the heat gun.
« Reply #69 on: November 23, 2017, 09:41:13 AM »
Watch that heat gun.  But, it is easy to repair a hole if it pops up or appears.
« Reply #70 on: November 23, 2017, 08:46:42 PM »
 Came out good Doc, got'er pulled down nice and tight with a couple thin spots but no real issues. I still say Polyspan is the only way to go but it definitely takes some finesse with the heat gun.
 Right after that came two good heavy coats of 50/50 Brodak clear...
« Reply #71 on: November 24, 2017, 10:17:46 AM »
Looking good. H^^
Offline Gary Mondry
« Reply #72 on: November 30, 2017, 08:45:13 PM »
You dope with a foam brush???  Doesn't it come apart and leave foam bits on everything?  (apparently not)  Does it take one brush per coat?
AMA 10663
« Reply #73 on: November 30, 2017, 09:51:36 PM »
 I only use the foam brush for adding the clear coats after the covering has been applied. I do everything up to that point with a regular brush. I've found that the clear coats lay out much better and dry smoother and more evenly using a foam brush. The foam brush holds a lot of material too, which allows you to control the flow once you get a feel for it. A two inch brush works very well, as that's pretty close to an average wing bay width.
 At this stage I'm using roughly a 70/30 mixture, 70 thinner, 30 clear. Starting at one wingtip and brushing T/E to L/E you can work your way across a wing pretty quickly. It only took about ten minutes to go across this 60" wing. On open bays I usually only do one coat per session, preferring to allow for a 24 hour drying time between coats.
 As an example, tonight I did what will be the last coat on the wing. I did the bottom side first and then let it dry just enough to be able to flip over, about 20 or 30 minutes. During that waiting period I did another heavy coat on both sides of the fuselage pod. Then I went back and did the top of the wing, all with the same brush, no deterioration. The brush does swell just a little but I haven't had any trouble with them coming apart. You do of course only get one session out of a brush, because you can't clean it. Determined by my local Home Depot, this routine works out to 77 cents per session.
Offline Gary Mondry
« Reply #74 on: December 01, 2017, 11:29:36 AM »
No kidding.  I would never have tried that, convinced that the thinner in the dope would melt the foam before I got done.  Now, maybe...
Thanks, Wayne.
AMA 10663
« Reply #75 on: December 01, 2017, 11:58:00 AM »
I have tried the foam brushes and they do work, but if you get interrupted they don't.  Like wife saying it's time to eat or grand kids need a ride.   Also when I dope a wing I don't do one panel like top side and then the bottom side as such.   Usually start at either tip or center and do a couple of rib bays, flip over and do same rib bays with a couple of extra and flip over.   When done I go to other half of wing.  It was a chore with the B-25 as that is huge plane and I didn't fabricate a paint stand for it.   In fact I brushed the dope out side of the shop to have room to maneuver.  Any way I anxious to see this P-38 of yours in the air. H^^
« Reply #76 on: December 01, 2017, 08:03:43 PM »
  LL~ LL~ LL~
« Reply #77 on: December 01, 2017, 08:28:14 PM »
   This may have been discovered by, and it was almost certainly first described in a nationally-distributed magazine, by none other than the inestimable Dirty Dan Rutherford back in Model Builder magazine.
Offline Gary Mondry
« Reply #78 on: December 01, 2017, 09:34:42 PM »
I'm not surprised.
I miss Dan's creative writing style...
AMA 10663
« Reply #79 on: December 03, 2017, 06:11:33 PM »
I'm not surprised.
   It's just my opinion, and no offense to anyone else, but Dan may be the best model airplane magazine writer I have ever read.  Always entertaining even when he really has nothing to say, verbose but so well-constructed that you don't get the "wall of text" effect, proper grammar, etc.
« Reply #80 on: December 03, 2017, 08:51:45 PM »
     As a collector and reader of model magazines, I have read a few in the last 50 years and would whole heartedly agree with this statement. As a good second place but with a completely different writing style is Dave Thornburg of "Do You Speak Model Airplane" fame. Ted Fancher is right up there also.
Online Dennis Saydak
« Reply #81 on: December 04, 2017, 09:21:03 AM »
Hi Wayne; It's great to see the P-38 project coming along so nicely.  I have to sincerely thank you for taking it on for me while I was unable to because of medical reasons. I'm currently recovering from total hip replacement surgery and looking forward to finally getting active in the hobby again. I plan to be back in the shop in another week and look forward to finally finishing a few stalled projects. I may even get in the shop today to work on a small project.............I need to make me a back scratcher.  y1 y1
Just when you think you're getting ahead in the rat race.....you find the rats just get faster! MAAC 13120L
« Reply #82 on: December 04, 2017, 10:11:03 PM »
 I was wondering where you'd been Dennis, good luck with your recovery and looking forward to some build posts from you.
 BTW, I'd been thinking all along that this thing was 60" span, not sure though if I'd ever even measured it. Getting near ready to attach the fuse pod and booms I had the tape measure out tonight to find wing center and create some reference points, it's actually 65" wingspan.  :o
« Reply #83 on: December 05, 2017, 08:31:55 AM »
Yeah Don likes them big for a twin.   Guess I should measure the B-25.  I know the thing had some work done out side the shop and does span the back seat of my Suburban.
« Reply #84 on: December 11, 2017, 07:39:08 PM »
 ...sanding, filling, priming, sanding, filling, priming, fitting, sanding some more, filling some more, a little primer, sanding, sanding, measuring and checking fits, sanding, filling, sanding, sanding...
« Reply #85 on: December 12, 2017, 11:04:14 AM »
Sounds like there might be nothing left after you get through with it.   ;D
« Reply #86 on: December 12, 2017, 12:09:12 PM »
Now you know why this old man does not have 20 point finishes.  In fact I ask the judges to move back about 20 feet before giving appearance points.
« Reply #87 on: December 13, 2017, 07:50:32 PM »
 Slow progress. The fuse pod is glued to the wing now, but I'm finding the need for a LOT of filling and sanding before the booms will be ready to mount. The fuse pod and twin booms are built up and sheeted in construction and the sheeting on the booms has a lot of high/low spots that showed up after the silkspanning process. The problem boils down to a wood selection issue with the sheeting. I don't know the proper term, but it's like when you get a real soft, almost mushy, piece of wood that even though it's sanded perfectly smooth beforehand it gets all grainy and uneven once the dope and silkspan cures. Once I get them finished up to a satisfactory compromise I'll re-add the new cooling scoops I made and then finally get them mounted to the wing...
« Reply #88 on: December 22, 2017, 08:36:57 PM »
 A little bit getting done here and there. Did the fillet on the outboard side of the fuse pod tonight. Letting it cure overnight and then tomorrow the inboard should get done. The new scoops are also on the booms now and along with their fillets are all sanded, primed, and ready to go. Once the other fillet on the fuse pod is done and cured it'll be time to attach the booms to the wing...then four more fillets...then...
« Reply #89 on: December 25, 2017, 04:18:52 PM »
 the new air scoops...
« Reply #90 on: December 25, 2017, 04:22:21 PM »
 "...two booms-a-curin'..."  ;D
Offline Jim Oliver
« Reply #91 on: December 26, 2017, 09:26:20 AM »
How would two Brodak .25s work for this project?
Jim
Jim Oliver
AMA 18475
« Reply #92 on: December 26, 2017, 12:32:54 PM »
Jim
 Not very well at all IMO. The Hutchinson P-38 design is actually intended for two .25's, like LA's or FP's, but even using those I feel it would have to be built as an absolute featherweight to be a good stunt performer. I've never run a Brodak .25, but I do have experience with the Brodak .15 where I was not at all impressed with the power, I feel the LA and FP .15's are much better engines, at least they have always proven so for me. Judging by the comparison with the .15's I'd assume the same with the Brodak .25's.
 As always, there are a lot of different opinions on all of this, I'm just explaining my own. There is some additional discussion pertaining to power options for this model back toward the beginning of this thread. My version here will be set up with two FP.35's, power will not be a problem.  ;D
Offline George Albo
« Reply #93 on: December 29, 2017, 08:13:55 AM »
Nice fillets. What are you using?
George Albo
« Reply #94 on: December 29, 2017, 07:17:58 PM »
 The fillets are done with SuperFil from Aircraft Spruce, it's great stuff.
 http://www.aircraftspruce.com/catalog/cmpages/superfil.php?gclid=EAIaIQobChMInOCv4NSw2AIVARcBCh27aQA0EAEYASABEgK8ZfD_BwE
« Last Edit: January 04, 2018, 10:13:21 PM by wwwarbird »
Online Crist Rigotti
« Reply #95 on: January 04, 2018, 09:51:06 PM »
Wayne,
Yeah, nice job on the fillets.  Send my best to all.
« Reply #96 on: January 04, 2018, 10:25:14 PM »
Wayne,
 Thanks Crist, and will do.
« Reply #97 on: January 04, 2018, 10:26:33 PM »
 Hey Crist, what do you think of this paint scheme?
Offline George Albo
« Reply #98 on: January 05, 2018, 10:32:06 AM »
« Reply #99 on: January 05, 2018, 09:28:56 PM »
 Finally working on all the tail feathers now, getting the silkspan on at this point. They'll be all primed and sanded and basically ready for color before they get attached...
