  • July 06, 2025, 12:37:46 AM
Author Topic: T/E shear webs  (Read 1592 times)
Offline Bootlegger
T/E shear webs
« on: April 18, 2013, 01:33:11 PM »
  Guy's what is the best way have you found to install trailing edge shear webs?
  Please be specific..
         Thanks.....
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline Doug Moon
Re: T/E shear webs
« Reply #1 on: April 18, 2013, 01:43:25 PM »
Hello,
I measure the inside to inside on the TE sheeting top and bottom right next to where it connects with a rib.
Then I use my blasa stripper and cut a piece of 1/16" at that measured distance.  T
hen I cut it to length bewteen ribs.
Then using my x-acto I place one in place and hit it with thin CA.
Then I move to the next bay and cut it and glue it etc...
Doug Moon
AMA 496454
Dougmoon12@yahoo.com
Re: T/E shear webs
« Reply #2 on: April 18, 2013, 06:31:55 PM »
Hi Brother Gil,
I use the "inside" function on a standard caliper to get the height of my cuts, and use a Stripper like Doug does.  Got this from Mr. Bob Hunt, and there is a post somewhere on the site showing him doing it.
Offline Bootlegger
Re: T/E shear webs
« Reply #3 on: April 20, 2013, 02:38:53 PM »
  Thanks Guy's, I appreciate the help...
Gil Causey
AMA# 6964
Offline Gordon Tarbell
Re: T/E shear webs
« Reply #4 on: April 25, 2013, 09:45:02 PM »
which direction should the grain be running on these bits? I was under the impression that the grain should run top to bottom for max strength effect.
Gordon Tarbell AMA 15019
Offline Jim Thomerson
Re: T/E shear webs
« Reply #5 on: April 26, 2013, 02:14:39 PM »
Top to bottom is probably best.  However, I do them with the grain running lengthwise, and have no complaints.
Re: T/E shear webs
« Reply #6 on: May 06, 2013, 07:45:20 PM »
Top to bottom for a ridgid wing , such as a twin spar , wwith Vertical Grain sheer webs at Mainspar .
For a Flexi Wing , along the span. The SAME as the SPAR .
or we get the dreaded Fokker torsional control revearseal wing warp /  flutter , ' stearage ' . n1
