  • June 18, 2025, 12:57:10 PM
Author Topic: Never again - again!  (Read 3463 times)
Online Will Hinton
« on: January 17, 2008, 01:18:33 PM »
The last time I had a blind mounting nut turn inside the mount and I had a devil of a time removing the engine I swore I'd never use one of those blasted things again. ~^ ~>
I lied!   I used them on the F9F and when I went to remove the 75 the awful feeling hit me right between the eyes.  Blast it any way, why do I do that to me.  I've built these things since 1956 and you'd think I would stick to what I've learned wouldn't ya? ??? ??? ??? ??? n1 n1 n1 n1
Well, long story short I finally got the engine out, changed the blind nuts to threaded brass inserts and am ready once again to start trimming the beast.  (I also found the tank problem while running around in there.) y1 y1
Never again - again!   HB~> HB~> HB~> HB~> HB~> HB~>
Offline Crist Rigotti
Re: Never again - again!
« Reply #1 on: January 17, 2008, 01:29:01 PM »
Threaded brass inserts forever!
« Reply #2 on: January 17, 2008, 01:40:32 PM »
Anyone got any tips and tactics for the brass inserts?  I've used them a few times but have ended up with the install screw stuck in the threads, or an insert that backs out when I remove the install screw, or a motor mount that splits or strips while threading in the insert.
I've had a few nasty moments with blind nuts too, like the prongs twisting flat or otherwise tearing up the finish on a profile.  Or when they're crossthreaded out of the package.  I've learned to throw the stamped steel blind nuts (from kit hardware packs, and microfasteners) in a special box for use only on extremely light duty parts and I only use the higher quality Dubro blind nuts on important stuff.  Even then sometimes the Dubro blind nuts aren't threaded right or have defects in the teeth.
« Reply #3 on: January 17, 2008, 01:45:12 PM »
FWIW, when I use inserts, I use a really long screw, 4-40 in my case, then I thread a plain nut on the screw, insert that in the insert,(hm hope that makes sense) . after the screw is in the insert almost full depth, I use a wrench and tighten the nut  against the face of the insert, as a jamb nut, then thread the insert into the mount rail. I have even put a washer on it as a depth stop. once it is seated, then hold the screw with your balldriver, and using the wrench loosen the nut, the screw then will thread out with no issues.
Offline Glen Wearden
« Reply #4 on: January 17, 2008, 01:54:18 PM »
I make sure the hole for the insert is not so small that the threads need a lot of force to cut the wood.  I put a thin coat of epoxy on the insert threads, and a little bead of vaseline around the under-edge of the install screw.  The screw should back right out.  Don't put vaseline on the screw threads, or it will be hard to keep the mounting screws from loosening and backing out, even with a lock washer.  Glen
Glen Wearden
« Reply #5 on: January 17, 2008, 02:19:47 PM »
Make sure when you drill the holes for the inserts that you leave enough material. I only use them in 1/2" square rails.
I stopped using blind nuts for engines a long time ago. Just not worth the headache. Wish someone made them from high grade  steel. Might be worthwhile then.
Offline don Burke
« Reply #6 on: January 17, 2008, 03:40:09 PM »
The commercial inserts are intended to go into soft wood.  Putting them into maple or other hardwood is asking for trouble splitting the wood.   I don't like the results when using them for engine screws, they tend to back out after a little use.  The engine vibration seems to loosen them.
I have started making my own inserts from 10-32 flat head brass screws.  I choose screws long enough to go through the core and doublers.  I drill and tap the screw 4-40, then tap the mount 10-32, then countersink the back side, away from the engine.  Installed with a little epoxy from that side they never come loose.  If they stick up a little after installation, I file them flush.  I have used them mainly on profile airplanes where I replace the core between the mounts with basswood or poplar.  But I've also used them on basswood crutches for BTR designs.
don Burke AMA 843
Menifee, CA
Online Will Hinton
« Reply #7 on: January 17, 2008, 04:01:39 PM »
The use of the backing nut to help in the removal is the technique I use for them also.  I am a bit opposite on my installations - I make sure they are very tight when inserting.  I take them in slowly and after they're in place I wick thin CA around the insert.  I have two ships with close to a thousand flights on them and no problems yet.  I just can't imagine what in the world possesed me to use the blind nuts again!?  It has been YEARS!
« Reply #8 on: January 17, 2008, 06:11:43 PM »
I should note that Van Dykes sells a high strength steel blind nut (called a "T" nut). They are generally too big for our purposes though they do sell a 4-40. But they can be modified to work. I've used them once or twice.
« Reply #9 on: January 17, 2008, 06:39:49 PM »
Maybe this should not be in this post, but, I get my blind nuts(T-nuts) from "RTL Fasteners".  For what you pay for 4 of them at the local hobby shop you can get a dozen, or there abouts.  If I have trouble with bolt going in the old trusty tap come into play.  So far have not had any strip out.  DOC Holliday
Offline Jim Thomerson
« Reply #10 on: January 17, 2008, 07:25:31 PM »
If I have blind nuts where I cannot get to them, I make a brass plate and solder it to the blind nuts backsides. I sand the blind nut surface and tin them beforehand.  Once I finish soldering, I drill through the brass plate and run a tap down the blind nut and through the brass plate. If the blind nuts are accessable:  I just put a lock nut on the bolt after I tighten it down.  Seems to work real well.
« Reply #11 on: January 19, 2008, 03:11:54 PM »
   Sorry about the problem, but this is a very strange thing. I have use them to mount engines for the last 30 years, and I never had the slightest problem with blind nuts. This includes some pretty old airplanes. What happens to them?
    On the other hand, brass inserts seem nearly unusable, at least for engine mounting. There's never enough wood to make the pilot hole, and even if you can, you cut away 3/4 of the material, greatly weakening the mount. I've seen a few airplanes with inserts undergo minor crashes and break the motor mounts clean through.
      If the blind nut issue is a real one, I would suggest that nut plates (like the good old days) are a better alternative than brass inserts.
« Reply #12 on: January 19, 2008, 07:51:57 PM »
Brett,
It's often a quality issue. The cheap Great Planes type will spin in the hole and strip very easily. The Dubro type are a bit better, but not hugely. If you use brass inserts, it's best if you put them in 1/2" square mounts to have enough meat to insure you don't crack them. They work fine under those conditions. I like the steel inserts better, but I'm a belt and suspenders kind of guy.
« Reply #13 on: January 19, 2008, 08:13:57 PM »
Like Brett, I've never had a problem with blind nuts in all the years I've been at this, with one acception, I did have one back out of the bearer and had to keep tnsion on it to remove the screw. Overall, I've have perfect results with them.
Offline Ward Van Duzer
« Reply #14 on: January 20, 2008, 09:04:21 AM »
Seems like a matter of insert quality (I guess I got lucky), and your procedure for insertion...
First, I always thread the bolt into the Blind nut (T-Nut if you wish) making sure that I have a clean thread. (sometimes I grind the end of the bolt down a little to ease the bolt into the nut. (Kinda like the end of a tap. Or, run a tap through the nut!).  Secondly, I drill the MM for the bolt. Then I turn the MM over and over-drill the bolt holes (from the bottom) about halfway through the hole in a size that will allow the threaded tube part of the blind nut to fit comfortably into the mount. Don't try to force the nut into a rock hard piece of maple. You will hurt the nut! Then put a little drop or two of epoxy on the flange of the nut and tighten down the bolt. Be sure to watch that the teeth are not crushed on the t-nut as you tighten it up. If they do, replace the nut.
Never had a problem...
W.
Online Will Hinton
« Reply #15 on: January 20, 2008, 10:56:18 AM »
Okay guys, I broke out the dial caliper and checked these babies out.  The 4x40 blind nut barrel is .185 and the barrel, not including the threads, on my brass inserts is .170 so the thought of"overdrilling" doesn't hold water because if we drill a bit undersize for the blind nut it'll be about the same size hole.  The 11/64 hole recommended for the inserts is .171 by the way.
Granted we drill deeper for the inserts than we do for the blind nut, but if the insert is properly coated with epoxy before installing the bond between the barrel and the mount will more than offset any possible weakening.  I have a Twister that has been flown by nearly every guy who has started out locally here, and therefore crashed at every angle by those same guys, even crashed into the pavement at AMA one year by a beginner who lost his own plane the day before with the mounts doing just fine yet.  I usually take such a plane with me in case of a beginner having that need, that year it paid off.  The mounts are much better than the finish, I might add!
I have always installed my blind nuts the way chronicled above, but have had three good airplanes that finally required major surgery to remove the engine and repair the nose.
Now, the blind nut I measured just now is a Great Planes, so the DuBro's may be a bit different, but I can't think they're that much thinner and still have room for the threads.  As to needing to run a tap through them, I've never had to do that with a threaded insert, whether steel or brass.  And there is much longer threads.
So, with all due respect to all who use the blind nuts, wonderful, I can't and won't criticize you. but I'll try to avoid my changing of mind in the future and stick to my inserts.
I hope you're all staying warm and building straight!
Blessings,
Will
« Reply #16 on: January 20, 2008, 01:34:59 PM »
   Hey, no problem, I'm not trying to talk you out of anything, and the fact that I don't have a problem doesn't mean you aren't.
   However, I am not sure where you are getting the blind nuts that big or inserts that small. I got out a DuBro 4-40 blind nut and a DuBro 4-40 threaded insert, and measured. The blind nut clearance hole needs to be 0.154 and .125 deep. The bottom of the threads on the insert is about .165 and body size is a whopping.215. For a pilot hole I would use about a #13 drill, or about .185, all the way through
     Going the next step, if you leave 0 clearance between the beams on a Jett 61, the distance from the center of the bolt to the edge of the beam is ~.168, you have about .075 between the edge of the pilot hole and the edge of the beam. Once you put in the insert it's only .060 from the edge of the beam. That's with 0 clearance between the mounts and the engine which you wouldn't want. And if you look at the other side of the beam, presuming a 1/2x3/8 beam mount, you really only have 42% of the mount cross-section left when you consider that the fibers are cut by the threads. It's basically a .215 hole through a .375 beam.
    I do see one advantage to inserts, and that's that you don't have to worry as much about hitting them when you shape the nose to the spinner. With blind nuts, no extension, and a 2" spinner, I usually hit the flange of the blind nuts when shaping the nose. I ignore it until I am done, just sand them down with everything else. Then I grind them below the surface with a dremel grinder, square off the divot, and glue in some balsa. Then sand it off flush. Once its fiberglassed and silkspanned, never see it again.
    Do as you think best, of course, but I wonder what it is that fails on a blind nut and how your experience is so different from mine.
« Reply #17 on: January 20, 2008, 02:00:12 PM »
I've always measured the barrel before drilling because I'v efound different makers are sifferent sizes and that it depends on which manufacturer the distributor bought them from. That said, when I install them I use my little arbor press and a piece of flat steel 1/8 or 3/16 thick. If in bearrers I put them side by side and push all 4 in at the same time. Then I saturate the area with thin CYA and last put a coat of epoxy over them. Last, after the eopoxy is set, I run a 4-40 tap through them from the opposite side. Then I build the front end. I put them in ply firewalls the same way.
