  • July 04, 2025, 04:20:20 PM
Author Topic: How can I verify that my engine is zero/zero to the design thrust line?  (Read 1209 times)
Offline Perry Rose
After reading the thread about engineered wood I got to thinking about the relation of the engine to the thrust line
depicted on the plans or where you want it to be. I have always carefully placed the engine in the mounts and
drilled holes. What inspection technique verifies that the engine is where it should be and pointed in the right
direction? Also, I have stayed away from engine clamp mounts because they just don't look like they can hold
the engine in place. Do the clamps have a set of pins that fit into the engine lug holes?
Perry Rose
Offline don Burke
Re: How can I verify that my engine is zero/zero to the design thrust line?
« Reply #1 on: September 02, 2007, 10:05:26 AM »
Couple of things.
For in-out thrust
If the fuselage CL is is straight & perpendicular to the wing.  Push in a straight pin at top of the vertical with a long string.  Put a prop on the engine, horizontal.  Use the string to measure to one of the prop tips, and put a mark on the string.  Rotate the prop 180 to eliminate any variations in dia, etc, then measure to the tip on the opposite side.  If the distances are equal the engine thrust line is parallel with the fuse CL in the yaw axis.
Measure from the same prop tip to the LE (straight LE), or TE (straight TE) of the wing on both sides of the fuselage at equal spanwise point.  Equal measurements, 0 engine, as above.  This could work with a tapered LE IF the taper is identical on both sides.
The string can also be used to see if fuselage CL is perpendicular to wing TE (LE). Measure to a point equidistant from fuselage CL on the LE or TE.
For up-down thrust.
An incidence gauge is the best.  Fix the fuselage to a bench, set the wing at O degrees.  Then with a straight edge clamped to the motor mount (engine out) use the gauge to see up or down.
don Burke AMA 843
Menifee, CA
Offline don Burke
« Reply #2 on: September 02, 2007, 10:07:19 AM »
Re: the clamps.  I have never seen a clamp with pins.  There's nothing to say that they couldn't be added.  Only one is needed on one side.
don Burke AMA 843
Menifee, CA
Offline Perry Rose
« Reply #3 on: September 03, 2007, 03:39:51 PM »
Thanks Don, as soon as I read your reply I remembered doing that on r/c pattern planes. I have long sticks made
special for checking engine offset. I checked my Ringmaster and it was real close to perfect, the Twisterized
plane needed a .010 shim under the engine lug to point it straight and the P-51 had a little out thrust so I left it
alone. I have to get to the flying field to test all the changes I've made lately.
Perry Rose
